Cześć
Jestem początkujący z Arduino. Ktoś wie jak naprawić ten błąd?
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
{0,1,2,3,4},
{5,6,7,8,9},
{10,11,12,13,14},
{15,16,17,18,19},
{20,21,22,23},
struct rotariesdef {
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
{0,1,24,25,0},
{2,3,26,27,0},
{4,5,28,29,0},
{6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
// R_START (00)
{R_START_M, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CCW_BEGIN
{R_START_M | DIR_CCW, R_START, R_CCW_BEGIN, R_START},
// R_CW_BEGIN
{R_START_M | DIR_CW, R_CW_BEGIN, R_START, R_START},
// R_START_M (11)
{R_START_M, R_CCW_BEGIN_M, R_CW_BEGIN_M, R_START},
// R_CW_BEGIN_M
{R_START_M, R_START_M, R_CW_BEGIN_M, R_START | DIR_CW},
// R_CCW_BEGIN_M
{R_START_M, R_CCW_BEGIN_M, R_START_M, R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
// R_START
{R_START, R_CW_BEGIN, R_CCW_BEGIN, R_START},
// R_CW_FINAL
{R_CW_NEXT, R_START, R_CW_FINAL, R_START | DIR_CW},
// R_CW_BEGIN
{R_CW_NEXT, R_CW_BEGIN, R_START, R_START},
// R_CW_NEXT
{R_CW_NEXT, R_CW_BEGIN, R_CW_FINAL, R_START},
// R_CCW_BEGIN
{R_CCW_NEXT, R_START, R_CCW_BEGIN, R_START},
// R_CCW_FINAL
{R_CCW_NEXT, R_CCW_FINAL, R_START, R_START | DIR_CCW},
// R_CCW_NEXT
{R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
JOYSTICK_TYPE_JOYSTICK, 32, 0,
false, false, false, false, false, false,
false, false, false, false, false);
void setup() {
Joystick.begin();
rotary_init();}
void loop() {
CheckAllEncoders();
CheckAllButtons();
void CheckAllButtons(void) {
if (buttbx.getKeys())
for (int i=0; i<LIST_MAX; i++)
if ( buttbx.key.stateChanged )
switch (buttbx.key[i].kstate) {
case PRESSED:
case HOLD:
Joystick.setButton(buttbx.key[i].kchar, 1);
break;
case RELEASED:
case IDLE:
Joystick.setButton(buttbx.key[i].kchar, 0);
break;
void rotary_init() {
for (int i=0;i<NUMROTARIES;i++) {
pinMode(rotaries[i].pin1, INPUT);
pinMode(rotaries[i].pin2, INPUT);
#ifdef ENABLE_PULLUPS
digitalWrite(rotaries[i].pin1, HIGH);
digitalWrite(rotaries[i].pin2, HIGH);
#endif
unsigned char rotary_process(int _i) {
unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
unsigned char result = rotary_process(i);
if (result == DIR_CCW) {
Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
if (result == DIR_CW) {
Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
Arduino:1.6.12 (Windows 10), Płytka:"Arduino Micro"
ARDUINO_BUTTON_BOXV2:95: error: expected ')' before ',' token
ARDUINO_BUTTON_BOXV2:96: error: no matching function for call to 'Joystick::Joystick()'
In file included from C:\Users\konra\Desktop\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino:8:0:
C:\Users\konra\Documents\Arduino\libraries\Joystick\src/Joystick.h:7:17: note: candidate: Joystick::Joystick(int, int, int)
public: Joystick(int, int, int);
C:\Users\konra\Documents\Arduino\libraries\Joystick\src/Joystick.h:7:17: note: candidate expects 3 arguments, 0 provided
C:\Users\konra\Documents\Arduino\libraries\Joystick\src/Joystick.h:6:7: note: candidate: constexpr Joystick::Joystick(const Joystick&)
class Joystick {
C:\Users\konra\Documents\Arduino\libraries\Joystick\src/Joystick.h:6:7: note: candidate expects 1 argument, 0 provided
C:\Users\konra\Documents\Arduino\libraries\Joystick\src/Joystick.h:6:7: note: candidate: constexpr Joystick::Joystick(Joystick&&)
ARDUINO_BUTTON_BOXV2:96: error: expected unqualified-id before numeric constant
C:\Users\konra\Desktop\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function 'void setup()':
ARDUINO_BUTTON_BOXV2:101: error: expected unqualified-id before '.' token
Joystick.begin();
C:\Users\konra\Desktop\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function 'void CheckAllButtons()':
ARDUINO_BUTTON_BOXV2:122: error: expected unqualified-id before '.' token
ARDUINO_BUTTON_BOXV2:126: error: expected unqualified-id before '.' token
C:\Users\konra\Desktop\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function 'void CheckAllEncoders()':
ARDUINO_BUTTON_BOXV2:157: error: expected unqualified-id before '.' token
ARDUINO_BUTTON_BOXV2:160: error: expected unqualified-id before '.' token
exit status 1
Ten raport powinien zawierać więcej informacji jeśli w
File -> Preferencje zostanie włączona opcja "Pokaż
szczegółowe informacje podczas kompilacji"[/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
//BUTTON BOX
//USE w ProMicro
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#define NUMROWS 5
#define NUMCOLS 5
{0,1,2,3,4},
{5,6,7,8,9},
{10,11,12,13,14},
{15,16,17,18,19},
{20,21,22,23},
byte pin1;
byte pin2;
int ccwchar;
int cwchar;
{0,1,24,25,0},
{2,3,26,27,0},
{4,5,28,29,0},
{6,7,30,31,0},
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
// R_START (00)
// R_CCW_BEGIN
// R_CW_BEGIN
// R_START_M (11)
// R_CW_BEGIN_M
// R_CCW_BEGIN_M
#else
// R_START
// R_CW_FINAL
// R_CW_BEGIN
// R_CW_NEXT
// R_CCW_BEGIN
// R_CCW_FINAL
// R_CCW_NEXT
#endif
void setup() {
Joystick.begin();
rotary_init();}
void loop() {
CheckAllEncoders();
CheckAllButtons();
case PRESSED:
case HOLD:
break;
case RELEASED:
case IDLE:
break;
#endif
class Joystick {
Joystick.begin();
exit status 1
