Wgrywanie pliku OPT.BIN do TV Philips bez programatora - jak to zrobić?
lunapark 10 Paź 2024 19:55 501 1
  • #1 21258173
    lunapark
    Ocena: 14
    Co zrobić aby TV Philips wgrał do NVM plik OPT.BIN (lub w inne obszary, np: env).
    Temat dotyczy wielu typów, nie trzeba programować pamięci zewnętrzenie czy otwierac TV.
    Pomijam temat programatorów Philipsa i ich dostępu do obszarów pamięci oraz nazw plików znanych wąskiemu gronu.
    Dostąp do poleceń UBOOT równiez pozwala na manipulację:
    mt5890 #
    addboot - addboot - append environment variables 'bootargs'
    base - print or set address offset
    bdinfo - print Board Info structure
    bootm - boot application image from memory
    bootp - boot image via network using BOOTP/TFTP protocol
    chpart - change active partition
    cmp - memory compare
    cp - memory copy
    crc32 - checksum calculation
    delboot - delboot - del environment variables 'bootargs'
    dhcp - boot image via network using DHCP/TFTP protocol
    eboot - eboot - boot from EMMC device
    env - environment handling commands
    erase - erase FLASH memory
    ext4load- load binary file from a Ext4 filesystem
    ext4ls - list files in a directory (default /)
    ext4write- create a file in the root directory
    fatinfo - print information about filesystem
    fatload - load binary file from a dos filesystem
    fatls - list files in a directory (default /)
    flinfo - print FLASH memory information
    fsinfo - print information about filesystems
    fsload - load binary file from a filesystem image
    go - start application at address 'addr'
    help - print command description/usage
    iminfo - print header information for application image
    load - load - load configuration from an environment variable
    loop - infinite loop on address range
    md - memory display
    mm - memory modify (auto-incrementing address)
    mmc - MMC sub system
    mmcinfo - display MMC info
    mtdparts- define flash/nand partitions
    mtest - simple RAM read/write test
    mw - memory write (fill)
    nm - memory modify (constant address)
    ping - send ICMP ECHO_REQUEST to network host
    printenv- print environment variables
    protect - enable or disable FLASH write protection
    reloadenv- reloadenv - reload default environment variables
    reset - Perform RESET of the CPU
    saveenv - save environment variables to persistent storage
    setenv - set environment variables
    tftpboot- boot image via network using TFTP protocol
    upgrade - upgrade - Upgrade Linux kernel/rootfs using USB
    usb - usb - USB sub-system
    usbboot - usbboot - boot from USB device
    Wracając do plików na pendrive, podczas wgrywania NVM.BIN część pamięci EEPROM jest zablokowana podczas tej operacji.
    Zresztą tak samo dla AQ.BIN, PQ.BIN (te wgrywane są do partycji).
    USB_ROOT_PATH : /mnt/usb_0
    SYSTEM_EEPROM_SIZE : 16384
    OPTION_SYSTEM_EEPROM_SIZE : 32
    OPTION_ADDRESS : 0x 3a0
    PROTECT AREA : Y
    EEPROM UPGRADE NVM.BIN : O ===> NVM.BIN
    EEPROM UPGRADE OPT.BIN : X
    EEPROM UPGRADE NVM.EED : X
    USB_UPGRADE_FILE_PREFIX_FILENAME:QM16XE_U
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <== O
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4d <== O
    protect/0x0210/0x4/0xf ==>4b a8 05 00 1c 5a 6b d1 ef f1 6e 1c 5a 6b d1 ef <== X
    protect/0x0220/0x0/0x1 ==>f1 6e 00 00 00 00 00 00 00 00 00 00 00 00 00 00 <== X
    Odpowiedź O = overwrite
    Jak nazwa wskazuje (OPT) plik ten jest szeroko używany w innych systemach, może podczas wgrywania ma odbezpieczony dostęp do obszarów PROTECT przez co uzyskamy dostęp do odwrócenia obrazu, załączenia pełnego UART itp.
  • #2 21333843
    terranowa23
    Poziom 8  
    >>21258173 Jestem laikiem i nie rozumiem tego, a chciałbym wgrać soft do Philips 65PUS9809, bo zgasł i nie mogę włączyć. Szybko miga czerwona dioda.
