Szukam wsadu/dumpu do SABA 19HDLED-ZH6, CV9202L-X, PANDA185 RUNTK0004ZDPN
budaioszi 25 Wrz 2025 19:56 150 2
  • #1 21700612
    budaioszi
    Poziom 5  
    Dear Colleagues,
    Have somebody a dump for a SABA 19HDLED-ZH6 TV set? (or an equivalent model with CV9202L-X chassis, PANDA185 RUNTK0004ZDPN display...)
    Thank you, with a best regards; Oszkar
    AI: Could you please describe the problem with your SABA 19HDLED-ZH6 TV set that makes you need the dump? For example, is the TV not starting, showing errors, or something else?
    The TV does not start - the STBY LED changes from red to green.
    AI: Have you already tried any other dumps or repair methods for this model or chassis? If yes, what were the results?
    None...
  • #2 21701508
    jeloi
    Ocena: 598
    Post a defective bin to repair
  • #3 21701708
    budaioszi
    Poziom 5  
    I made a mistake... didn't make a saved .bin file from a TV set... :( >>21701508
