Firmware for Blaupunkt BA32H4142LEB TPD.MS6683.PB763 CX315DLEDM
theleserv 23 Paź 2025 18:25 492 0
  • #1 21729480
    theleserv
    Poziom 6  
    Ocena: 2
    Dear Sirs,
    Can I have the firmware for Blaupunkt BA32H4142LEB, MB:TPD.MS6683.PB763, panel: CX315DLEDM?
    I need the upgrade method too.
    I saw this topic on the site, but it is already closed. I tried to upgrade with the files posted by crazycavan (completed by stacho57), but the upgrade does not start. Maybe I am doing something wrong?
    The TV has OK voltages, but it does not come out of standby either from the keyboard or from the remote control.
    Thanks in advance.
    AI: Could you please describe the exact steps you followed when attempting the firmware upgrade (for example, how you prepared the USB stick, which files you used, and what button combinations you tried)?
    I have a 4 GB stick with an LED, formatted as FAT32. I use this USB stick only for TVs. I used both versions, crazycavan's version with 4 files and stacho57's version with 6 files. I tried to initiate the upgrade with the Power key pressed for 5-10 s and AC and with the CH- key held down for 5-10 s and then AC.
    AI: When you power on the TV or attempt the firmware upgrade, do you see any lights, messages, or changes on the screen, or does it remain completely unresponsive?
    Nothing has changed, the red standby LED is on. The LED on the stick does not light up.
