[Rozwiązano] Jak uzyskać kod z pliku do radia RCD210 ULVWMP3 1K0035156B VWZAZ1K po zakupie używanego?
Bahmut_airsoft 22 Sty 2026 18:58 282 3
  • #1 21816669
    Bahmut_airsoft
    Hi, guys! I need help with the code for RCD210 ULVWMP3 1K0035156B
    VWZAZ1K
    Thanks.
    AI: Do you have any proof of ownership or original documents for this radio?
    No.
    AI: Can you tell us why you need the code (for example, after battery replacement, or did you buy the radio used)?
    I bought the radio used.
    • M24C16-volina_caddy crd210.BIN (2 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    chippy
    Ocena: 235
    your code is 0956
  • #3 21817043
    Bahmut_airsoft
    >>21816680 Thanks, bro! It worked))
  • #4 21817064
    damiancz
    Moderator Radia Samochodowe
    Ocena: 1409
    Rozwiązano = zamykamy
