Maksymalny procesor dla płyty Commate P3/370A z slotem 1 i socketem 370?
Accura 15 Sty 2006 03:12 2921 1
  • #1 2182029
    Accura
    Ocena: 30
    Czy ktoś miał doczynienia z tą płytą, chodzi mi o to jaki max.procek tam będzie chodził.Płyta ma slot 1 i socket 370:?:
    Domik
    Opis funkcji z manuala:
    ftp://ftp.tcommate.com.tw/P2_serial_MB/p3370avp/
    CPU: - Supports Intel Socket 370, Celeron, Pentium II and Pentium III 66/100/133MHz Front Side Bus Processors. (P3/370A-V supports 66/100MHz FSB Processors only).
    Chipset: - VIA VT82C693 & VT82C596A for P3/370A-V.
    - VIA VT82C693A & VT82C596B for P3/370A-VP.
    DIMM: - Supports 3.3V EDO or SDRAM in 3 168-pin banks, each bank consists of 1x168-pin 64-bit DIMM socket, which can support memory sizes of 8/16/32/64/128/256 MB modules. P3/370A-VP can also support 512KB memory.
    - Supports up to a maximum of 768MB system memory. (P3/370A-VP supports up to 1.5GB system memory)
    IDE: - Dual channel PIO and PCI Bus Master IDE ports support up to 4 EIDE devices for HDD or CD-ROM
    - Supports PIO Mode 4 with data transfer rate up to 14 MB/Sec
    - Supports Ultra DMA 33/66 (UDMA) with data transfer rate up to 33/66 MB/Sec (P3/370A-V supports DMA 33 only)
    BIOS: - Award BIOS V.4.51 with built-in Anti-Virus, DMI support, and green function (Plug-and-Play BIOS)
    - Supports CD-ROM, SCSI, and LS120/ZIP boot up
    I/O Devices: - One FDD control port supports two of the 5.25” or 3.5” floppy drives up to 2.88 MB.
    - Two high-speed 16550 UART compatible serial ports
    - One parallel ports with ECP/ EPP compatibility.
    - One PS/2 mouse port
    - One PS/2 Keyboard connector
    IR Port: - One IrDA/ASKIR compatible Infrared interface port. (Cable optional)
    USB Ports: - Two Universal Serial Bus (USB) ports support up to 127 peripheral devices.
    Sound (optional) : - ALS4000 PnP Sound Chip
    - Built-in 3D Sound Effect Processor
    - AC-Link Interface
    - Built-in ALSFM synthesizer
    - PPMI Power Management
    - Enhanced normal & digital game port
    - 16-bit full-duplex for concurrent recording and playback
    - Compatible with DirectSound, DirectSound3D, Blaster, Sound Blaster Pro, and Sound Blaster 16 Emulation
    - PC98 Specifications Compliant
    - PCI Bus Master for PCI Audio/PCI 2.1/2.2 Compliant PCI Interface
    - Support DDMA, Avance Legacy Support for legacy DMAC Emulation
    - 64-Voice Wavetable Synthesis w/DLS-1 Support
    - Support Sound Blaster ADPCM decompression
    - Sample record/playback rates up to 48KHz
    ATX Power: - Supports Modem remote Ring-On function
    - Supports software power off function
    - Supports RTC Wake-Up.
    - Supports Wake up on LAN.
    Expansion Slots: - Four 32-bit PCI expansion slots
    - One 16-bit ISA expansion slots
    - One 32-bit AGP expansion slot
    Operating System: - Supports Windows 95/98/2000, Windows NT, MS-DOS V6.22, OS/2, Novell, Unix, SCO UNIX...
    Dimension: - 305 mm x 170 mm ATX Form factor
    chyba wszystko jasne jaki maks proc wejdzie jeśli ona obsługuje fsb 133.
