Program do sterowania diodami przez port LPT w DOS na starym komputerze
10 Lut 2006 12:29 1911 6
  • #1 2284378
    viki
    Ocena: 3
    możliwe masz źródło. Program steruje wyświetlaczem LCD na t6963c. W define masz załączanie i gaszenie diod połączonych do lpt
    #include <stdio.h>
    #include <stdlib.h>     // rand()
    #include <conio.h>      // inp() outp() kbhit()
    #include <string.h>     // strlen()
    #include <math.h>       // cos(),sin()
    #include <time.h>
     *  LCD Pin ----- PC Port Pin  Status Reg. bit
     *  C/D  (8) <--> (16)
     *  /WR  (5) <--> (1)
     *  /RD  (6) <--> 5V
     *  /CE  (7) <--> (14)
     *  D0  (11) <--> (2)  D0
     *  D1  (12) <--> (3)  D1
     *  D2  (13) <--> (4)  D2
     *  D3  (14) <--> (5)  D3
     *  D4  (15) <--> (6)  D4
     *  D5  (16) <--> (7)  D5
     *  D6  (17) <--> (8)  D6
     *  D7  (18) <--> (9)  D7
     *  GND (2)  <--> (25) GND
     *  FG    (1)  frame ground
     *  +5V   (3)  LCD logic supply
     *  -12V (4)  LCD display contrast
     *  FS    (19) font select
     *  RST   (10) active low
    #define WRHI outp(pcont, (inp(pcont) & 0xfe) ) // take PC 1 HI
    #define WRLO outp(pcont, (inp(pcont) | 0x01) ) // take PC 1 LO
    #define CDHI outp(pcont, (inp(pcont) | 0x04) ) // take PC 16 HI
    #define CDLO outp(pcont, (inp(pcont) & 0xfb) ) // take PC 16 LO
    #define CEHI outp(pcont, (inp(pcont) & 0xfd) ) // take PC 14 HI
    #define CELO outp(pcont, (inp(pcont) | 0x02) ) // take PC 14 LO
    #define DATAIN  outp(pcont, (inp(pcont) | 0x20) ) // 8bit Data input
    #define DATAOUT outp(pcont, (inp(pcont) & 0xdf) ) // 8bit Data output
    /* ----- Definitions concerning LCD internal memory  ------ */
    #define G_BASE 0x0200            // base address of graphics memory
    #define T_BASE 0x0000            // base address of text memory
    #define BYTES_PER_ROW 40         // how many bytes per row on screen
     /* This will be 30 with 8x8 font, 40 with 6x8 font, for both
    		Text & Graphics modes. Font selection by FS pin on LCD module:
    		FS=High: 6x8 font.  FS=Low: 8x8 font.                     */
    #define frand() ((float)rand()/RAND_MAX)
    #define UI unsigned int
    #define UL unsigned long
    void dput(int byte); // write data byte to LCD module
    void cput(int byte); // write command byte to LCD module
    void lcd_setup();    // make sure control lines are at correct levels
    void lcd_init();     // initialize LCD memory and display modes
    void lcd_print(char *string);  // send string of characters to LCD
    void lcd_clear_graph();    // clear graphics memory of LCD
    void lcd_clear_text();     // clear text memory of LCD
    void lcd_xy(int x, int y); // set memory pointer to (x,y) position (text)
    void lcd_setpixel(int column, int row);  // set single pixel in 240x64 array
    #define BASE 0x378     // base address for parallel port LPT1:
    UI pdata = BASE;       // par.port data register
    UI pstatus = BASE+1;   // par.port status register
    UI pcont = BASE+2;     // par.port control register
    #define home() dput(T_BASE%256);dput(T_BASE>>8);cput(0x24); // upper-left
    #define XMAX 239        // limits of (x,y) LCD graphics drawing
    #define XMIN 0
    #define YMAX 63
    #define YMIN 0
    #define PI 3.1415926536
    void main()
    int d1;                 // data from port
    int s1;                 // status register value
    int c1;                 // control register value
    int i;                  // generic counter
    int c;                  // character to write to display
    float x,y;                // coordinates on graphics screen
    float xinc,yinc;
    float r,theta;           // polar coords. for point dV
    float theta_inc;
    unsigned int cc;
    char string[320];        // string to print to display
    char tmpbuf[128];  // time buffer
    	clrscr();
    	printf("LCD setup.\n");
    	printf("Inicjalizacja LCD.\n");
    	printf("<esc> wyjscie.\n");
    	do {  // outer loop: keypress exits
    	/* --- display characters available from LCD's ROM CharGen ------ */
    	 lcd_clear_text();
    	 cput(0x97);  // Graphics & Text ON, cursor blinking
    	 for (c=0;c<10;c++) {
    		lcd_xy(0,0);        // write text from upper left corner
    		strcpy(string, "Siemanko.");
    		lcd_print(string);
    		lcd_xy(0,1);        // first character, second line
    		lcd_print("To jest druga linia.");
    		lcd_xy(5,2);
    		lcd_print("To jest trzecia linia...");
    		lcd_xy(0,3);
    		lcd_print("...a to jest czwarta hi hi.");
    		lcd_xy(10,5);
    		lcd_print("Nacisnij klawisz.");
    		lcd_xy(0,7);
    		lcd_print("Naskrobane przez Vikiego");
    		/* Set time zone from TZ environment variable. If TZ is not set,
    		 * PST8PDT is used (Pacific standard time, daylight savings).
    		tzset();
    		/* Display DOS-style date and time, in refresh loop */
    		for (i=0;i<500;i++) {
    			lcd_xy(22,0);
    			_strtime( tmpbuf );
    			lcd_print( tmpbuf );  // DOS-style time
    			lcd_print(" ");       // intervening space
    			_strdate( tmpbuf );
    			lcd_print( tmpbuf );           // DOS-style date
    			if (kbhit()) break;
    	 if (kbhit()) break;
    	/* ------ bouncing line graphics "screensaver" demo ---------- */
       lcd_clear_graph();        // fill graphics memory with 0x00
       cput(0x98);  // Graphics ON, Text OFF
       x=(XMAX-XMIN)/2;
    	 y=(YMAX-YMIN)/2;
       r=0.3; theta = 2*PI*frand();
       theta_inc = (0.01 * frand()) - 0.005;
       for (c=0;c<12000;c++) {
         lcd_setpixel((int)x,(int)y);       // draw pixel on LCD screen
         xinc = r*cos(theta);
         yinc = r*sin(theta);
         theta += theta_inc;
         x += xinc;
         y += yinc;
         if (x>XMAX) {x=XMAX; theta = PI-theta;}
         if (y>YMAX) {y=YMAX; theta = -theta;}
         if (x<XMIN) {x=XMIN; theta = PI-theta;}
    		 if (y<YMIN) {y=YMIN; theta = -theta;}
         if (kbhit()) break;
         } // end for(c)
      if (kbhit()) getch();
      } while (!kbhit());
    } // end main
    void lcd_clear_graph()    // clear graphics memory of LCD
    int i;
     dput(G_BASE%256);
     dput(G_BASE>>8);
     cput(0x24);       // addrptr at address G_BASE
     for (i=0;i<2560;i++) {
          dput(0); cput(0xc0);               // write data, inc ptr.
     } // end for(i)
    } // end lcd_clear_graph()
     int i;
     home();
     for (i=0;i<1930;i++)
    	 dput(0x00);
    	 cput(0xc0);
    } // lcd_clear_text()
    void lcd_print(char *string)  // send string of characters to LCD
    int i;
    int c;
      for (i=0;i<strlen(string);i++) {
          c = string[i] - 0x20;     // convert ASCII to LCD char address
    			if (c<0) c=0;
          dput(c);
          cput(0xc0);               // write character, increment memory ptr.
    	} // end for
    } // end lcd_string
    void lcd_setpixel(int column, int row)  // set single pixel in 240x64 array
    int addr;       // memory address of byte containing pixel to write
      addr =  G_BASE + (row*BYTES_PER_ROW)  + (column/6);
      dput(addr%256); dput(addr>>8); cput(0x24);  // set LCD addr. pointer
      cput(0xf8 | (5-(column%6)) );  // set bit-within-byte command
    } // end lcd_setpixel()
    void lcd_xy(int x, int y)  // set memory pointer to (x,y) position (text)
    int addr;
    	addr = T_BASE + (y * BYTES_PER_ROW) + x;
    } // lcd_xy()
    void lcd_setup()  // make sure control lines are at correct levels
     CEHI;  // disable chip
     WRHI;  // disable writing to LCD
     CDHI;  // command/status mode
     DATAOUT; // make 8-bit parallel port an output port
    } // end lcd_setup()
    void lcd_init()  // initialize LCD memory and display modes
     dput(G_BASE%256);
     dput(G_BASE>>8);
     cput(0x42);       // set graphics memory to address G_BASE
     dput(BYTES_PER_ROW%256);
     dput(BYTES_PER_ROW>>8);
     cput(0x43);  // n bytes per graphics line
     dput(T_BASE%256);
     dput(T_BASE>>8);
     cput(0x40);       // text memory at address T_BASE
     cput(0x41);  // n bytes per text line
     cput(0x80);  // mode set: Graphics OR Text, ROM CGen
     cput(0xa7);  // cursor is 8 lines high
     dput(0x27);
     dput(0x07);
     cput(0x21);  // put cursor at (x,y) location
    	      // (For cursor to be visible, need to set up position)
    } // end lcd_init()
    void dput(int byte) // write data byte to LCD module over par. port
    	outp(pdata, byte);          // write value to data port
    	CDLO;
    	WRLO;         // activate LCD's write mode
    	CELO;                       // pulse enable LOW > 80 ns (hah!)
    	CEHI;                       // pulse enable LOW > 80 ns (hah!)
    } // end dput()
    void cput(int byte) // write command byte to LCD module
    	outp(pdata, byte);  // present data to LCD on PC's port pins
    	CDHI;         // control/status mode
    	WRLO;         // activate LCD write mode
    	CELO;         // pulse ChipEnable LOW, > 80 ns, enables LCD I/O
    	CEHI;         // pulse ChipEnable LOW, > 80 ns, enables LCD I/O
    } // cput()
    • T6963c.c (10.23 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #3 2284496
    viki
    Ocena: 3
    w borland c++, ale nie o to chodzi
    ważne jest tylko to
    a outport i inport znajdziesz w dowolnym kompiolatorze
    proponuje troszkę poszukać, poczytać...
  • #5 2284540
    KwoiteK
    Ocena: 10
    prosze http://rudy.mif.pg.gda.pl/~reichel/showcat.php?id=2
    zerknij tez na elektrode na download. nie pamietam dokladnie ale tak bylo cos podobnego
    kiedys sam sie bawilem w takie rzeczy. prosrty programik w pascalu i chodzilo ladnie. Borland c++ hm... zlitujcie sie. to tak jakby w piaskownicy bawic sie spycharkoladowarka HSW ;).
    Zycie jest po to zeeby sobie je umilac
  • #7 2289701
Poszukiwano programu do sterowania diodami podłączonymi do portu LPT działającego w systemie DOS na bardzo starym komputerze. W odpowiedziach udostępniono fragmenty kodu w języku C, wykorzystujące funkcje inp() i outp() do bezpośredniego sterowania portem LPT, z przykładami przypisania pinów LCD t6963c do portu PC. Sugerowano kompilację kodu w Borland C++ lub Pascalu, podkreślając, że funkcje outport i inport są dostępne w większości kompilatorów. Podano link do zasobów z gotowymi programami i przykładami na stronie rudy.mif.pg.gda.pl oraz elektrodzie, gdzie można znaleźć proste programy do sterowania portem LPT w DOS. Autor potwierdził zamknięcie tematu po otrzymaniu pomocnych materiałów.
