Jaki procesor do Matsonic 7112c dla lepszej wydajności zamiast Celeron 466?
hugo987 22 Mar 2006 18:58 1299 3
  • #1 2445030
    hugo987
    Ocena: 23
    Witajcie jaki mozna włozyc do tej płyty procesor aby troszke zwiekszyc wydajnosc kompa.
    Obecnie jest celeron 466
    Pozdrowienia
  • #2 2445187
    K!lleR
    Ocena: 131
    PROCESSOR
    Slot 1 / socket 370 supports any one of the following processors:
    Pentium® III processor
    450/500/550/600
    Pentium® II processor
    233/266/300/333/350/400/450
    Celeron® processor
    266/300/333/366/400/433/466/500MHz
    CHIPSET
    VIA 82C693A & 82C596B Chipset With 133/100/66MHZ FSB
    PnP Ultra I/O - Winbond W83977EF-AW
    CMI8738 PCI 3D Audio/HSP 56K V.90 Fax/Modem
    System Hardware Monitor Chip - GL520SM
    CACHE
    None (CPU Embedded)
    MEMORY (8MB-768MB)
    Three 168-pin DIMM sockets for 3.3V SDRAM (Ready for PC100/PC133)
    Support ECC with parity checking function
    Maximum: 768MB(Registered)
    SYSTEM BIOS
    Award 2Mb Flash EEPROM
    Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
    I/O INTERFACE
    Supports Plug and Play I/O function
    One - EPP/ECP mode parallel port
    Two - 16550 high-speed serial I/O ports
    Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
    Dual PCI IDE interfaces - supports four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 33/66 )
    PS/2 Keyboard and PS/2 Mouse Connectors
    ATX Power Supply Connector
    Audio Ports(Line-in, Line-out, Mic-in, CD-in and Game Port)
    Two sets of USB connector
    3D PCI AUDIO ONBOARD
    SB 16/PRO compatible with DirectSound 3D support HRTF 3D Positional Audio Technology with full duplex stereo Supports 44.1K digital audio-in (SPDIF)
    56K FAX/MODEM ONBOARD
    Supports V.90Fax/ModemStandard for your internet Communication
    OTHER
    IrDA ASKIR Header
    Green, HDD, Power indicator LED Connectors
    CPU Fan, Power Fan and Chassis Fan Headers
    LAN Card Wake Up/Internal Modem Ring Wake-Up Headers
    BUS ARCHITECTURE
    1 AGP Slot
    4 PCI Slots
    2 ISA Slots (One shared)
    FORM FACTOR AND LAYERS
    ATX Size (304.8mmx220mm), 4 layers
  • #3 2448104
    hugo987
    Ocena: 23
    witam
    a czy jak załoze procesor P III 670
    to czy bedzie jakas róznica
  • #4 2448159
    K!lleR
    Ocena: 131
    Max PIII 600MHz
