MySQL 5.0 – błąd w definicji tabeli DOKUMENTY, literówka w AUTO_INCREMENT
mesiah 25 Maj 2006 23:27 1602 3
  • #1 2663962
    mesiah
    Ocena: 5
    /* Database name: Hotel */
    /* DBMS name: MySQL 5.0 */
    DROP TABLE IF EXISTS GOSCIE;
    DROP TABLE IF EXISTS DOKUMENTY;
    DROP TABLE IF EXISTS OBYWATELSTWA;
    DROP TABLE IF EXISTS REZERWACJE;
    DROP TABLE IF EXISTS POKOJE;
    DROP TABLE IF EXISTS Wyposazenie;
    CREATE TABLE OBYWATELSTWA (
    Id INT NOT NULL AUTO_INCREMENT,
    Nazwa VARCHAR(45) NOT NULL,
    Kod VARCHAR(3) NOT NULL,
    CONSTRAINT OBYWATELSTWA_Id_pk PRIMARY KEY(Id)
    CREATE TABLE Wyposazenie(
    TV ENUM( 'Y', 'N') NOT NULL,
    Radio ENUM( 'Y', 'N') NOT NULL,
    Klimatyzacja ENUM( 'Y', 'N') NOT NULL,
    Sejf ENUM( 'Y', 'N') NOT NULL,
    Barek ENUM( 'Y', 'N') NOT NULL,
    CONSTRAINT Wyposazenie_Id_pk PRIMARY KEY(Id)
    CREATE TABLE DOKUMENTY (
    Rodzaj_dokum VARCHAR(45) NOT NULL,
    CONSTRAINT DOKUMENTY_Id_pk PRIMARY KEY(Id)
    CREATE TABLE POKOJE (
    Wyposazenie_Id INT NOT NULL REFERENCES Wyposazenie(Id),
    Nr_pokoju NUMERIC(2) NOT NULL,
    Nr_pietra NUMERIC(1) NOT NULL,
    Ilu_osobowy NUMERIC(1) NOT NULL,
    Cena_za_pokoj NUMERIC(7,2) NOT NULL,
    CONSTRAINT POKOJE_Id_pk PRIMARY KEY (Id)
    CREATE TABLE GOSCIE (
    DOKUMENTY_Id INT NOT NULL REFERENCES DOKUMENTY(DOKUMENTY_Id),
    OBYWATELSTWA_Id INT NOT NULL REFERENCES OBYWATELSTWA(OBYWATELSTWA_Id),
    Nazwisko VARCHAR(45) NOT NULL,
    Imie VARCHAR(20) NOT NULL,
    Data_urodz DATE NOT NULL,
    Plec VARCHAR(10) NOT NULL,
    Nr_dokum VARCHAR(10) NOT NULL,
    Ulica VARCHAR(45) NOT NULL,
    Nr_domu VARCHAR(20) NOT NULL,
    Miejscowość VARCHAR(45) NOT NULL,
    Kod_Pocztowy VARCHAR(6) NOT NULL,
    CONSTRAINT GOSCIE_Id_pk PRIMARY KEY (Id)
    CREATE TABLE REZERWACJE (
    POKOJE_Id INT NOT NULL REFERENCES POKOJE(POKOJE_Id),
    GOSCIE_Id INT NOT NULL REFERENCES GOSCIE(GOSCIE_Id),
    Data_od DATE NOT NULL,
    Data_do DATE NOT NULL,
    CONSTRAINT REZERWACJE_Id_pk PRIMARY KEY (Id)
    ENGINE = InnoDB;
    COMMIT;
    INSERT INTO OBYWATELSTWA VALUES(1, 'Polska' , 'PL');
    INSERT INTO OBYWATELSTWA VALUES(2, 'Niemcy', 'DE' );
    COMMIT;
    INSERT INTO REZERWACJE VALUES(1, '2004-12-21', '2004-12-31');
    INSERT INTO REZERWACJE VALUES(2, '2005-07-14', '2005-07-31');
    I
    COMMIT;
    INSERT INTO GOSCIE VALUES(1, 'Grzegorczyk', 'Adam', '1978-06-07', 'Men', 'AC1586243', 'Mickiewicza', '16', 'Rzepin', '69-110');
    INSERT INTO GOSCIE VALUES(2, 'Kowalczyk', 'Piotr', '1974-05-27', 'Men', 'DD7571986', '', '75', 'Rzepin', '69-110');
    COMMIT;
    INSERT INTO DOKUMENTY VALUES(1, 'Dowod osobisty');
    INSERT INTO DOKUMENTY VALUES(2, 'Paszport');
    COMMIT;
    INSERT INTO POKOJE VALUES(1, '1', '1', '3', '299.00');
    INSERT INTO POKOJE VALUES(2, '3', '12', '2', '199.00');
    COMMIT;
    INSERT INTO Wyposazenie VALUES(1, 'Y', 'Y', 'Y', 'N', 'Y');
    INSERT INTO Wyposazenie VALUES(2, 'Y', 'N', 'Y', 'N', 'Y');
    COMMIT;
    Prosze o pomoc w sprawie powyższej bazy danych. Problem polega na tym ze jak chce ją załadowac to bez problemu wgrywa tabele DOKUMENTY, OBYWATELSTWA i Wyposazenie. Kiedy wgrywa pozostałe tabele to wyskakuje bład "ERROR 1136 (21S01): Column count doesn't match value count at row 1 ". Może ktoś wie gdzie popełniłem błąd i mi pomoże.
  • #2 2664464
    kosmita
    Ocena: 136
    Zwrócony komunikat świadczy o niezgodności listy pól z wartościami. Rekord nie został dodany.
    Nie wypełniasz wszystkich pól które zadeklarowałeś.
    przykład:
    deklarujesz 5 pól wypełniasz 3
    spróbuj wprowadzać dane tak:
    INSERT INTO REZERWACJE( Id, Data_od, Data_do ) VALUES ( 1, '2004-12-21', '2004-12-31' );
  • #3 2665586
    mesiah
    Ocena: 5
    Dzieki za pomoc , ale to nic nie pomogło. Zacząłem inaczej próbować. MAm dwie tabele DOKUMENTY , GOSCIE i jak je połączyć . Spróbowałem tak jak poniżej i cały czas wyskakuje mi taki sam błąd jak wcześniej.
    Rodzaj VARCHAR(45) NOT NULL,
    CONSTRAINT DOKUMENTY_Id_pk PRIMARY KEY(Id),
    KEY DOKUMENTY_Rodzaj_uk (Rodzaj)
    DOKUMENTY_Id INT NOT NULL,
    ALTER TABLE GOSCIE ADD CONSTRAINT GOSCIE_DOKUMENTY_Id_fk FOREIGN KEY (DOKUMENTY_Id) REFERENCES DOKUMENTY (Id);
    COMMIT;
    COMMIT;
  • #4 2698604
    Dydzio
    Poziom 30  
    Ocena: 43
    przykład:
    pokojeID i gościeID sa NOT NULL!!! Nie mogą być puste!!! Musisz je wypełnić!!!
