Support Intel Pentium ÒII / III And CeleronTM Slot 1 Processor
Support Socket 370 For Intel CeleronTM PPGA/FCPGA Processor
VIA 82C693A , 82C596B APOLLO Pro -133 AGPset
Support 66/75/83/100/112/124/133/150 MHz Bus Frequency For CPU Host Clock
Support Ultra DMA 66 Mode
Support 3 Banks of DRAM From 8Mbyte to 1.5GByte Main Memory
PC'99 Ready & PC'99 Colorful I/O Ports Design
Support USB Controller & PS/2 Mouse , Standard IR (infrared) Functio
Provide extra " three-wire" fans connectors
Y2K Compliant
ACPI Supporting For OS Directed Power Management
Moden Ring remote wake up
Power Button Ride (Instant off or Delay 4 second power off)
RTC alarm wake up
Wake on LAN For OS
Support software suspend & power off (Windows 95 or Windows98)
SPECIFICATION
Processor
Intel PentiumÒ II / III , CeleronTM Slot1 Processor Optimized For 100 / 133 MHz Front Side Bus Frequency
Can't Use Slot1 And Socket 370 Processor Together
Chipset
VIA 82C693A / 82C596B APOLLO Pro -133 Chipset
CMI8738 PCI 3D Audio Chipset (For 993AS)
CPU Bus Frequency
Support Jumper Select 66.7/100/133 MHZ CPU Bus Frequency Default Selection
CPU Bus Frequency , Choose 66 / 75 / 83 / 100 / 103 / 112 / 124 / 133 /150 MHZ in BIOS Setup
DIP Switch Selection CPU Ratio From 2X to 8X
AGP SLOT
Support AGP VGA Card for 533Mbytes/sec data transfer rate and 66MHz Bus clock improve graphic function
Expansion Slot
Four 32-bit PCI Bus Master Slots
One 16bit ISA Bus Slot
System Memory
Support 3 Banks of SDRAM From 8MByte to 1.5GByte
3 X 168-pins DIMM Scockets (3.3V)
Support EDO (66MHz Only) & SDRAM (66MHz/100MHz/133MHz)
Support ECC or Parity Check
On Board IDE
Support 2 X IDE Connectors for up to 4 IDE Drives
Support PIO Mode 3 and Mode 4 and Bus Master IDE DMA, Mode 4 Timing for up to 16M Bytes/s
Support " Ultra DMA 66 " Synchronous DMA Mode transfer rate up to 66M Bytes/s
Support LS-120 / ZIP Device
On Board Ultra I/O
2 X USB Connectors
1 X Standard IR Connector (SIR)
2 X Serial Ports (16550 Fast UART Compatible)
1 X Parallel Port (EPP and ECP Capabilities)
1 X Floppy Disk Connector (Supports 2 Floppy Drives)
1 X PS2 Mouse / PS2 Keyboard Connector
2 X Three Wire FAN Connector (Include CPU FAN)
1 X LINE IN Connector (For 993AS)
1 X LINE OUT Connector (For 993AS) 1 X MIC Connector (For 993AS)
1 X Game Port Connector (Support Two Joysticks , For 993AS)
1 X SPDIF IN And OUT Connector (For 993AS)
1 X Panasonic Analog Audio CD Music line Connectors (For 993AS)
1 X Sony Analog Audio CD Music line Connectors (For 993AS)
On Board USB
2 X USB Ports Connector
Support USB Keyboard & USB Mouse
Power Saving
ACPI/APM Power Management
Modem Ring Remote Wake up
RTC Alarm Wake up
Support Software Suspend & Power off (Windows 95/98)
Wake on LAN For OS
Support Power Button Ride (Instant off or Delay 4 second power off)
Power Supply
Support 20-pin ATX power supply (ATX-PW)
BIOS
Award BIOS , Support DMI , Green , P&P Function
2MByte Flash ROM
Support Full Screen Logo
Dimension
ATX Form Factor with 30.5cm X 19cm
