Nokia 6233 - błąd przy wgrywaniu softu JAF 1.98.28, jak naprawić?
kilerfosa 12 Wrz 2007 10:10 1536 4
  • #1 4275106
    kilerfosa
    Ocena: 21
    Nokia 6233 dostałem ją do polaka. W trakcie wgrywania softu wywaliło błąd. Soft wgrywany jafem 1.98.28 . Teraz przy probie wgrania softu wywala taki komunikat :
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_30005.100.mcusw
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_3005.10.ppm_c
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_30005.10.image_tmo_nl2
    APE Variant file: NONE
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_3005.10.ppm_b
    CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_30005.10.image_b
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    Loader version: 01.16.00 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35972800105922_CRT_backup_950129.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup LCK...
    Manual mode selected, version can't be checked!
    Booting phone...
    Error sync the phone...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Saved to C:\Program Files\ODEON\JAF\ProgData\35972800105922_CRT_backup_955129.rpl
    Backup CRT OK!
    Reading IMEI...
    Failed! Aborting!
    Booting phone...
    jak postawic tą nokie ?
    Z góry dzieki za pomoc.
  • #2 4275186
    xxxmalyxxx
    Ocena: 6
    zainstaluj nowsza wersje JAF Setup 1.98.31 i sprobuj jeszcze raz
  • #3 4275195
    kilerfosa
    Ocena: 21
    z tego co widze to na serwerze odeon ostatnia wersja to 1.98.30 ... po zainstalowaniu jaf wywala identyczny komunikat
  • #4 4275279
    xxxmalyxxx
    Ocena: 6
    jast taka wersja jak pisze tylko trzeba poszukac a jakim kablem to robisz?
  • #5 4275725
    kilerfosa
    Ocena: 21
    Kabel pod jafa do n6234 oraz kabelkiem USB . Zaznaczona opcja USB dead ....
    pod kablem usb wywala taki komunikat :
    ...................Loader Sent!
    Stage 2 starting..........................................................Loader Sent!
    Stage 3 starting..........Phone prepared OK!
    Waiting for the phone to boot...
    Phone is in flash mode...
    CMT blocks: 1418, APE blocks: 0
    Erasing cmt...
    Send CFG...
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_30005.100.mcusw...
    Erasing cmt zone 00000000 - 000006BF ...
    Erasing cmt zone 000006C0 - 0000FFFF ...
    Erasing cmt zone 00010000 - 0007FFFF ...
    Erasing cmt zone 000A0000 - 0021FFFF ...
    Erasing cmt zone 00220000 - 011DDFFF ...
    Erasing cmt zone 011DE000 - 011DEFFF ...
    Erasing cmt zone 011DF000 - 011DFFFF ...
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_3005.10.ppm_b...
    Erasing cmt zone 011E0000 - 016DFFFF ...
    Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-145\rm123_145_30005.10.image_b...
    Erasing cmt zone 016E0000 - 01E7FFFF ...
    Erasing cmt zone 01E80000 - 01FDFFFF ...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Rebooting...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    MCUSW: (null)
    APESW: (null)
    VariantSW: (null)
    Prodcode:
    DCT4/BB5 counter: 1406
    Done!
    Telefon wiesza sie na ekranie startowym ......
