Jak zdjąć simlock z SE K800 CID49 za pomocą Setool?
jarni 17 Lis 2007 12:14 3322 4
  • #1 4490491
    jarni
    Ocena: 3
    witam, trafil mi się dzisiaj k800 cid 49 z angielskiej 3. Niby standard ale mam problemik, flash z polakiem przeszedł, info ze rest został odnaleziony też jest ale simlock przez patch nie schodzi, ponizej log:
    v0.914006/UNI
    Card serial:00020172
    Loaded 51 flash descriptors
    Open COM port OK
    ChipID:9900,EMP protocol:0301
    Speed:921600
    Flash ID check:897E
    Flash props sent ok
    OTP LOCKED:1 CID:49 PAF:1 IMEI:3517xxxxxxxxxx CERT:N/A
    FLASH CID:49 COLOR:RED
    Model:K800i
    MAPP CXC article: R1CD001 prgCXC1250568_HUTCHISON_WI
    MAPP CXC version: R1CD001
    Language Package:HUTCH_1
    CDA article: CDA102511/84
    CDA version: R9A
    Default article: cxc1250490
    Default version: R1CD001
    Network LOCKED
    Operator: MULTIPLE
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed:3 secs.
    SERVER SUPPORT ENABLED.
    SERVER CREDITS LEFT/USED: 6/24
    CARD COUNTERS: FLASH 105, UNLOCK 228
    Elapsed:2 secs.
    ALTERNATIVE SECURITY BYPASS ENABLED.
    Open COM port OK
    Speed:921600
    OTP LOCKED:1 CID:49 PAF:1 IMEI:35170xxxxxxxxxx CERT:N/A
    PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
    LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
    Flash ID check:897E
    Flash props sent ok
    bypassing DB2020 security...
    done,restarting...
    Open COM port OK
    Speed:921600
    Trying to launch embedded bootloader...
    Embedded flashloader:
    DB2020_PRELOADER_FOR_SETOOL2
    Flash ID check:897E
    Flash props sent ok
    FOUND: R1CD001_CXC1250568_HUTCHISON_WI
    Restore from:R1CD001_CXC1250568_HUTCHISON_WI
    Switching to USB...
    Phone stays at current interface.
    writing E:\GSM\SETOOL\pakiety\pakiet_K800_cid_49\R1ED001_1250210_GENERIC_WI.ssw.cry
    CURRENT FLASH FILE CID:49
    SSW uses complete hash, hash len is:9100
    Will flash 455 blocks...
    SSW loading returns:0
    writing E:\GSM\SETOOL\pakiety\pakiet_K800_cid_49\R1ED001_CENT_EUROPE_fs.ssw.cry
    SSW uses complete hash, hash len is:4500
    Will flash 225 blocks...
    full sig complete.
    USERCODE RESET TO "0000"
    Searching...
    Firmware lock check determined.
    can't open file ""
    processing error when write
    CSloader version:
    060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G
    loader startup: executed
    loader filesystem startup: executed
    loader GDFS startup: executed
    loader unlock: executed
    writing tpa/preset/custom/C3_PCA_G3v2.cer
    writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
    writing tpa/preset/custom/customize.xml
    writing tpa/preset/custom/DESKTOP_HOOK_2.itm
    writing tpa/preset/custom/Entrust.net Root Certificate.cer
    writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
    writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
    writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
    writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
    writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
    writing tpa/preset/custom/GAMES_HOOK_3.itm
    writing tpa/preset/custom/GTE_CyberTrust_Root.cer
    writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
    writing tpa/preset/custom/Root.cer
    writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
    writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
    writing tpa/preset/custom/ThawtePremium.der
    writing tpa/preset/custom/ThawteServerCA.cer
    writing tpa/preset/custom/Utiroot.cer
    writing tpa/preset/custom/VeriSignClass3Root.cer
    writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
    Phone detached
    Elapsed:825 secs.
    kredyty już mi dwa zjadło, jakieś pomysły?
  • #2 4490495
    poochone
    Ocena: 164
    jak go bedziesz mu wrzucac softa to uzyj opcji unlock after flash cmoplette i powinno ci posc bez problemu
  • #3 4490518
    gomezf1
    Spec od GSM
    Ocena: 19
    can't open file ""
    Sprawdz z inną wersją SW zaznaczając Complete After Flash. użyj innego Moda np. v0.91380096
  • #4 4490544
    fingusio
    Warunkowo odblokowany
    Ocena: 22
    No wlasnie tu raczjej problem jest cos z katalogiem SEToola. Uzyj najnowszej wersji SETool. Przeflashuj na inną wersje w Settings zaznaczając:
    "complete phone...."
    "unlock after flash"
    "use server...."
    "use alternative...."
  • #5 4490565
    jarni
    Ocena: 3
    tak zrobiłem za pierwszym razem i nie poszło ale thx za sugestie. Temat zamykam, po zmianie softu (downgrade :) - dziwne ale simlock przez patch zszedł
