REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
HOLD "C" BUTTON AND ATTACH PHONE
CID52 BYPASS PROCEDURE FINISHED
bypassing security...
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Trying to launch embedded bootloader...
Embedded flashloader:
DB2020_PRELOADER_FOR_SETOOL2
Flash ID check:897E
Flash props sent ok
writing C:\serwis\SEtool3\K800\CID52\R1KG001_FS_CENT_EUROPE_WI_RED_CID52.ssw
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:4580
Will flash 229 blocks...
SSW loading returns:0
full sig complete.
USERCODE RESET TO "0000"
Searching...
Firmware lock check determined.
LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G
loader startup: executed
CSloader refused to start GDFS services,error is:29
loader GDFS startup failed, that is fatal
Elapsed:524 secs.
mam zaznaczone:
complete phone after flash
unlock after flash
use server
enable alternative security bypass
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
full sig complete.
Searching...
Elapsed:524 secs.
mam zaznaczone:
unlock after flash
use server
