Jak naprawić uwaloną Nokię N70 po nieudanym flashowaniu?
domonik26 24 Gru 2007 03:40 2885 12
  • #1 4619166
    domonik26
    Witam , przez swoje niedopatrzenie "uwalilem" nokie n70 , mianowice przed flaschowanie nie zaznaczylem "downgrade" po tym zabiegu nokia umarla , nie wstaje . Czym ja postawic ? Mam UFS+HWK , JAF+P-KEY
    odczyt z ufsa :
    1ST BOOT : C0,0C [Rm-84]
    OMAP ID : 17100701
    OMAP MODE : 00
    OMAP PBID : FE6EA5D9FBD36DFE802070BAFB57CC0C3B817023
    OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
    OMAP ROID : AB5E4ADB27A06946
    RAPx ID : 000000010000022600010006000C192101002200
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx PBID : 0A300202A9295F518BFE26F67086B005C622B4CC
    RAPx MODE : 00
    RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
    RAPx ROID : F28A211FCEA7B19D
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
    00000000: 02 00 00 00 00 F1 72 ......r
    ERR: CMT 2ND Boot CMT 2ND CERT Mismatch
    IMAGE : RM84_50737301.C0
    Process Failed, Repowering Mobile
    odczyt z jafa :
    Boot'owanie telefonu...
    APE Boot Data:
    Asic ID: 17100701
    Asic Mode ID: 00
    Asic Public ID: FE6EA5D9FBD36DFE802070BAFB57CC0C3B817023
    HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0A300202A9295F518BFE26F67086B005C622B4CC
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 6B6F4E5C -> Unknown flash chip
    CMT Flash Data: 69615C50686F656E69785C50726F6475
    Error finding cmd loader...
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    Failed to backup CRT...
    Backing up SIMLOCK data...
    Ustawianie trybu LOCAL...
    Błąd! Przerwano!
    Failed to backup LCK...
    Manual mode selected, version can't be checked!
    APE Boot Data:
    Asic ID: 17100701
    Asic Mode ID: 00
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Flash ID: 4C41434F -> Unknown flash chip
    CMT Flash Data: 2E2E2E0D0A42B3B964212050727A6572
    Error finding cmd loader......
    niewiem jak ja postawic ?
    dziekuje za pomoc
    gg:1711291
  • #2 4619167
    myrkysfara
    Wgraj wysza wersje, lub ta co byla.
  • #3 4620569
    domonik26
    jakies inne pomysly ? proba wgrania najnowszego oprogramowania nic nie daje
  • #4 4620807
    fingusio
    Warunkowo odblokowany
    Ocena: 22
    Zaznaczyc opcje DEAD, i przez USB przeflashowac - jak troszke masz umiejętnosci to 100% ja postawisz.
    Oczywiscie mowa o JAFie :)
  • #5 4620877
    domonik26
    umiejetnosci jakies mam ale po usb nie widzi telefonu , po podlaczeniu zaznaczeniu i wybraniu softu klikam na flash i wciskam wlacznik w telefonie , niestety nic to nie daje
  • #6 4621297
    arem
    Ocena: 278
    JAF kabel 7 pin FBUS wersja taka jak była w fonie lub wyższa zaznaczona opcja Factory Default i musi wstać .
    Pozdr świątecznie :-))
  • #7 4621309
  • #8 4621865
    gsm-raf
    Ocena: 6
    A czym ja uwaliles? Jezeli usf to stawiaj ja Usf. Sprubuj wgrac same mcu na najwyzsza wersie zmniejsz predkosc na najnizsza i jak nacisniesz flash to botuj ja wlacznikiem Jak wgra sie mcu zczytaj info powinien wejsc w local mode i wtedy downgrand na nizsza. Ja tak sie z jedna n70meczylem i poszla
  • #9 4623995
    tricolore
    mialem czasem takie dziwne problemy. stawianie takich grzmotow jak N70 najlepiej jednak wychodzi UFSem. najnowsza wersja softu.
    aaa.. sprawdz, czy kabel NA PEWNO dobrze styka...
  • #10 4632341
    domonik26
    niestety nic nie pomaga , dalej trup , moze jakies inne pomysly ?
    dzieki za zainteresowanie
  • #11 4632636
    AxeMan
    Ocena: 12
    Masz adapter do UFSa, robisz to na pięciopinowym kablu, czy na jakim ?
  • #12 4635635
    domonik26
    Witam , mam adapter do UFSa , mam kable pieciopinowe i siedmiopinowe , robie z przelotka i bez ale to nic nie daje telefon nie wstaje
  • #13 4636735
    AxeMan
    Ocena: 12
    Spróbuj na 7 pinowym, zaznacz Dual line i zaznacz, żeby zrobił resety.
Problem dotyczy uszkodzonej Nokii N70 po nieudanym flashowaniu, gdzie nie zaznaczono opcji downgrade, co spowodowało, że telefon nie uruchamia się. Próby wgrania najnowszego oprogramowania nie przyniosły efektu. Zalecane jest użycie narzędzia JAF z opcją DEAD oraz kabla USB, jednak telefon nie jest wykrywany przez komputer. Sugerowano również użycie kabla 7-pin FBUS z zaznaczoną opcją Factory Default lub kabla 10-pin oraz wgranie najwyższej dostępnej wersji oprogramowania. Wskazano, że najlepszym narzędziem do przywracania N70 jest UFS z najnowszym softem, zwracając uwagę na poprawne styki kabla i adaptera (5-pin lub 7-pin). Proponowano wgranie samego MCU na najniższej prędkości, uruchomienie flashowania z wciśniętym włącznikiem, co powinno umożliwić wejście w tryb lokalny i wykonanie downgrade. Dodatkowo, przy użyciu UFS zalecano zaznaczenie opcji Dual line i resetów. Mimo wielu prób telefon pozostaje nieaktywny, co wskazuje na konieczność dokładnej kontroli połączeń i konfiguracji narzędzi flashujących.
