Jak zablokować stronę gamezer.com na kilku przeglądarkach jednocześnie?
grzegorzsawczak 04 Sty 2008 19:17 4067 4
  • #1 4657397
    grzegorzsawczak
    Ocena: 14
    Taki bład pojawia się jak kolega sobie pogra w gierke internetową online.
    Jak można zablokować koledze dostęp do tej strony jak nie ma innego rozwiązania?
    http://gamezer.com/ - tą strokę zblokować i srawa rozwiązana.
    Jak ją zablokować dla kilku przeglądarek jednocześnie?
    BCCode : c2     BCP1 : 00000007     BCP2 : 00000CD4     BCP3 : 028E0009
    BCP4 : 813EA6A8     OSVer : 5_1_2600     SP : 2_0     Product : 256_1
    C:\DOCUME~1\user\USTAWI~1\Temp\WERab49.dir00\Mini010408-01.dmp
    C:\DOCUME~1\user\USTAWI~1\Temp\WERab49.dir00\sysdata.xml
    • WER26f2.dir00.rar (23.1 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #2 4657481
    fipik
    Problem: Another reader complains about a system that reboots unexpectedly at random times and then presents an error message when WinXP starts again.
    Error Message: "The system has recovered from a serious error. C:\Windows\Minidump020404-01.dmp C:\Docume~1\Darle~1\Locals~1\Temp\Wer5E.tmp.diroo\sysdata.xml"
    Solution: This error message reveals a problem with a memory dump (an inventory of the contents of computer memory; sometimes referred to as a minidump). It seems the OS created a memory dump file but forgot about it, so it's attempting to create the file again. The resulting conflict leads to a serious error and the sudden system meltdown.
    The minidump error is sometimes associated with an outdated video driver (a program that facilitates communication between a hardware component and the rest of the system), so one potential solution is to download a driver update for the video card. The reader can get one by visiting the Support or Downloads area of the card manufacturer's Web site. An updated driver may take care of the problem, but regardless of whether it does, we also recommend downloading the WinXP patch that Microsoft released to combat memory dump problems. The reader can get the update by visiting http://www.microsoft.com
    /downloads/details.aspx?displaylang=en&FamilyID=3D41A046-0E2C-429F-8F40-F30014ADC3BB and clicking Download in the upper-right section of the page. Next, he should access the Windows Update site and install WinXP SP1a from the list of critical updates.
    Just for good measure, the reader should take a moment to purge his system of the minidump and Sysdata.xml files by deleting them from the C:/DOCUMENTS AND SETTINGS and C:/WINDOWS folders, respectively. He can restart the computer when the files are gone.
    Sory, że tak cytuje ale wydaje się być że to podobny (jak nie ten sam) problem.
    Sprawdź! Jak nie to, to naprawdę nie wiem.
    http://forums.pcpitstop.com/index.php?s=&showtopic=151803&view=findpost&p=1458674
    jankolo
    Spoczywaj w Pokoju
    Ocena: 587
    Może odpowiedni wpis do pliku hosts załatwi sprawę?
    Pieron
    Ocena: 84
    prosta sprawa
    firewall i blokujesz IP strony dla przegladarek
    np. Outpost firewall
  • #5 10413796
    grzegorzsawczak
    Ocena: 14
    Powyższe odpowiedzi rozwiązały problem choć użyłem netlimiter 3 pro.
