witam -tuner HYUNDAI HSS-1100 R co to jest za wynalazek czy mozna go edukowac prosz o jakieś wskazówki z góry dzięki.
Czy wolisz polską wersję strony elektroda?
Nie, dziękuję Przekieruj mnie tamCytat:1x Nagravision Cardreader, .... Channels, 4-digit Display, S/PDIF (coax), 2x SCART, 2x Audio, DiSEqC 1.0/1.2, Loopthrough, Modulator, SU via RS-232, Power 30 W (Stand-by 10 W), Size: 335x58x267 mm
Cytat:Feature
DVB/MPEG-2 Compliant
Multi-Function
Excellent Performance
Frendly User Interface
Specification
¢ºCore Hardware
- CPU : STi5518
- Flash ROM : 2MByte
- SDRAM : 8MByte
- EEPROM : 8MByte
¢ºTuner & Channel
- Input Connector : IEC 169-2, Male / Female
- Frequency Range : 48 ~ 860MHz
- Input Impedance : 75§Ù unbalance
- Signal Level : -20 to +30dBm
- IF Frequency / IF Bandwidth : 8MHz
¢ºMPEG Transport Stream A/V Decoding
- Transport Stream : MPEG-2 (ISO 13818)
- Profile Level : MPEG-2 MP@ML
- Input Rate : Max. 15Mbit/s
- Aspect Ratio : 4:3, 16:9
- Video Resolution : 720 x 576
- Audio Decoding : MPEG 1 Layer ¥°&¥±
- Audio Mode : Streo/Joint streo/Mono
- Sampling Rate : 32, 44.1 and 44.8KHz
¢ºA/V & Data In/Out
- TV Scart : Video Output(CVBS, RGB, Y/C) ¡¤ Audio Output(L,R)
- VCR Scart : Video Output(CVBS) ¡¤ Audio Output(L,R) / Video Input(CVBS,RGB) ¡¤ Audio Input(L,R)
- Video : RCA/Cinch, Video Output(CVBS)
- Audio L/R : RCA/Cinch, Volume and Mute Control(16 bits DAC, Max. 2Vrms)
- RS-232C : Transfer rate 115kbps, 9 pin D-sub type
- Return Path : PSTN Modem
- SPDIF : Digital Audio/Cinch
¢ºRF Modulator (Option)
- RF Connector : 75§Ù , IEC 169-2, Male / Female
- Frequency / Output Channel : 470MHz to 860MHz / CH 21 ~ 69 for the Remodulator
- TV Standard : PAL B / G / I selectable by Menu
¢ºPower Supply
- Input Voltage : AC 90 ~ 264V
- Type : SMPS
- Standby Power : Max 10W
- Protection : Separate Internal Fuse, The input shall have lighting protection
¢ºCAM
- CAS : NAGRAVISON
¢ºPhysical Specification
- Size (W x H x D) : 335x58.5x267
- Weight (Net) : 2.1Kg
