witam! robię jak zawsze, na usb i ufsem - niby wszystko oki, a simlock dalej jest. cztery opcje zaznaczone w setting
v0.914021/UNI
CARD SERIAL: 00010343
Loaded 51 flash descriptors
SERVER SUPPORT ENABLED.
ALTERNATIVE SECURITY BYPASS ENABLED.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
OTP LOCKED:1 CID:51 PAF:1 IMEI:xxxxxx CERT:RED
FLASH CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
CID52 BYPASS PROCEDURE STARTED
Processing part1...
Processing part2...
Processing part3....
OTP LOCKED:1 CID:51 PAF:1 IMEIxxxxxxxxxxx CERT:RED
Flash ID check:897E
Flash props sent ok
REMOVE CABLE FROM PHONE
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
HOLD "C" BUTTON AND ATTACH PHONE
CID52 BYPASS PROCEDURE FINISHED
bypassing security...
Speed:921600
Trying to launch embedded bootloader...
Embedded flashloader:
DB2020_PRELOADER_FOR_SETOOL2
Flash ID check:897E
Flash props sent ok
writing E:\compang dysk d\setool\k550\R6BC002_1250669_GENERIC_LI.ssw
CURRENT FLASH FILE CID:52
SSW uses complete hash, hash len is:9200
Will flash 460 blocks...
SSW loading returns:0
LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
writing tpa/preset/custom/C3_PCA_G3v2.cer
writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
writing tpa/preset/custom/customize.xml
writing tpa/preset/custom/DESKTOP_HOOK_2.itm
writing tpa/preset/custom/Entrust.net Root Certificate.cer
writing tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm
writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
writing tpa/preset/custom/FM_THEMES_HOOK_3.itm
writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
writing tpa/preset/custom/GAMES_HOOK_3.itm
writing tpa/preset/custom/GTE_CyberTrust_Root.cer
writing tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
writing tpa/preset/custom/Root.cer
writing tpa/preset/custom/SEMC_E2E_Root_CA.crt
writing tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
writing tpa/preset/custom/ThawtePremium.der
writing tpa/preset/custom/ThawteServerCA.cer
writing tpa/preset/custom/Utiroot.cer
writing tpa/preset/custom/VeriSignClass3Root.cer
writing tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed:713 secs.
v0.914021/UNI
Speed:921600
Flash ID check:897E
Flash props sent ok
Processing part1...
Processing part2...
Flash ID check:897E
Flash props sent ok
THEN PRESS "READY"
Speed:921600
Flash ID check:897E
Flash props sent ok
Phone detached
Elapsed:713 secs.
Moderowany przez Artech:Temat poprawiłem
