Jakub19 napisał: Niestety też nie idzie. wyżóciłem go przez okno jak to dobrze ze mieszkam na parterze.....
przykro mi. Ni mam juz pomyslu, moze jeszcze ktos cos pomoze ale chyba kabelek zosaje.
Mimo wszystko zycze powodzenia....
Dorzucam ci kody serwisowe do Samsungow moze popruboj tymi do innych modeli...
*#06# Show IMEI
*#9999# Show Software Version
*#0837# Show Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset,
info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Software Version
*#9998*842# Test Vibrator - Flash the screenlight during 10 sec
and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown
*0003*?# unknown
FOR NEW SGH (R210, T100, A300...)
if code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK!
but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
SGH E700
*2767*688# remove USER CODE and SIMLOCK
SGH V200
Unlocking:
Power on the phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
SGH S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
