Dostałem K800i
SeTool wykrywa go jako K700i
Flash itp nie pomógł.
Log z Inde..
v0.915040/UNI
2009-08-10 09:50:10 CARD SERIAL:
2009-08-10 09:50:10 Loaded 51 flash descriptors
2009-08-10 09:50:13 SIGNED MODE (USING SERVER)
2009-08-10 09:50:13 CFG:10000000000000
2009-08-10 09:50:17 ChipID:9900,EMP protocol:0301
2009-08-10 09:50:18 erom_readvar: error reading unit 1/851
2009-08-10 09:50:18 error while reading SIMLOCK SIGNATURE unit
2009-08-10 09:50:18 phone was tampered with other software
2009-08-10 09:50:18 SECURITY UNITS CAN'T BE READ !
2009-08-10 09:50:18 DAMAGED FIRMWARE,GDFS OR EMPTY PHONE
2009-08-10 09:50:18 CONTINUE ON YOUR OWN RISK
2009-08-10 09:50:18
2009-08-10 09:50:18 PHONE STATE: "RETAIL"
2009-08-10 09:50:18 FLASH CID: 0052
2009-08-10 09:50:18 Speed:921600
2009-08-10 09:50:18 Flash ID check:897E
2009-08-10 09:50:18 Flash props sent ok
2009-08-10 09:50:18 OTP: LOCKED:1 CID:51 PAF:1 IMEI:357315XXXXX CERT:RED
2009-08-10 09:50:18 FLASH CID:52 COLOR:RED
2009-08-10 09:50:23
2009-08-10 09:50:23 Model (from GDFS):K700
2009-08-10 09:50:23 MAPP CXC article: R8BF003 prgCXC1250210_GENERIC_WI
2009-08-10 09:50:23 MAPP CXC version: R8BF003
2009-08-10 09:50:23 Language Package: C_ASIA
2009-08-10 09:50:23 CDA article: CDA102568/7
2009-08-10 09:50:23 CDA version: R6A
2009-08-10 09:50:23 Default article: cxc1250490
2009-08-10 09:50:23 Default version: R1KG001
2009-08-10 09:50:23 PROVIDER: 000-00
2009-08-10 09:50:23 SIMLOCKS NOT DETECTED
2009-08-10 09:50:23
2009-08-10 09:50:23 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
2009-08-10 09:50:23
2009-08-10 09:50:23 BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
2009-08-10 09:50:23
2009-08-10 09:50:23 Elapsed: 10 secs.
TP:
2009-08-10 12:10:38 TESTPOINT REPAIR STAGE #1 STARTED
2009-08-10 12:10:40 ChipID:9900,EMP protocol:0301
2009-08-10 12:10:40 Speed:921600
2009-08-10 12:10:41 OTP: LOCKED:1 CID:51 PAF:1 IMEI:XXXX
CERT:N/A
2009-08-10 12:10:41 FLASH CID:52 COLOR:RED
2009-08-10 12:10:42 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
2009-08-10 12:10:42 PREPARING...
2009-08-10 12:10:47 ATTACH TP #1 AND PRESS "READY"
2009-08-10 12:10:47 ...
2009-08-10 12:11:01 RELEASE TP #1 AND PRESS "READY"
2009-08-10 12:11:01 ...
2009-08-10 12:11:06 TP #1 LOOKS OKAY
2009-08-10 12:11:36 can't get packet start.
2009-08-10 12:11:36 NOT EXPECTED ANSWER, TP #1 INCORRECT
2009-08-10 12:11:37 Elapsed: 58 secs.
No i tak się męczę i to nic nie daje:P
Po włączeniu telefonu ekran miga na biało, nie jest po zalaniu, stawiałem po COM (RJ45)
Czy to aby napewno wina SW ?
Jakieś pomysły
Dostałem K800i
Log z Inde..
v0.915040/UNI
2009-08-10 09:50:18
2009-08-10 09:50:23
2009-08-10 09:50:23
2009-08-10 09:50:23
2009-08-10 09:50:23
TP:
CERT:N/A
Jakieś pomysły
