Napięcia są w porządku sprawdzałem jak i inne podzespoły tzn.procek, RAM, grafika jest zintegrowana.
Przestawiłem NV SATA Controller na DISABLED i włożyłem płytkę instalacyjną z wgranymi sterownikami SATA i takie oto błędy wyskakują:po włożeniu 1 płytki:
a po włożeniu 2 płytki to:
co mam jeszcze zrobić??
Modele tych sterowników:
1.v10.11
Added
- I8\ Intel RST DriverVer=09/13/2010,10.0.0.1046 (replaces .ini [I4] section)
- IT\ IT8212 ATA/ATAPI controller to existing RAID drivers.
- IT1\ IT8211 ATA/ATAPI controller DriverVer=02/29/2008,1.3.4.2
- L0\ LSI SAS2 2xxx Adapter DriverVer=07/30/2010,2.00.35.00
.ini section for [N7r] requested here:
http://forum.driverpacks.net/viewtopic.php?id=4875
Updated
- L4\ LSI Logic MegaRAID SAS 8xxx RAID Controller (XP) from DriverVer=02/14/2008,2.20.0.32 to 08/09/2010,4.31.1.32
- L5\ LSI Logic MegaRAID SAS 8xxx RAID Controller (2k3) from DriverVer=12/03/2007,2.20.0.32 to 08/09/2010,4.31.1.32
- L6\ Intel/LSI MegaRAID SAS/SATA from DriverVer=06/26/2008,11.02.0626.2008 to 06/14/2010,13.21.0614.2010
- M5\ Marvell 91xx AHCI SATA 6G Controller to DriverVer=08/27/2010,1.0.0.1045
Fixed M5\ .ini section to include bus extender
v10.11r3
Added
Updated
- 3C\ AMCC 3ware 9xxx SATA/SAS RAID Controller from DriverVer = 12/04/2006,3.00.02.090 to 03/24/2009,3.00.04.070
v10.11r2
Added
Fixed
- M5\ .ini section to include bus extender
v10.11r1
Added
v10.11.01
Added
Updated
v10.10
Fixed
.ini entries for [M] and [M5] for dual .sys loading.
Removed [T] .ini entry to fix ICH7M BSOD.
Added
- AM9\ AMD SATA AHCI Controller DriverVer=03/24/2010, 3.2.1548.37
Updated
- ADB\ Adaptec/ICP/IBM/SUN/AOC SATA/SAS RAID (W2K/WXP) from 02/08/2008, 5.2.0.15728 to 08/05/2010, 5.2.0.17911
- ADC\ Adaptec/ICP/IBM/SUN/AOC SATA/SAS RAID (W2K3) from 07/10/2008, 5.2.0.16120 to 08/05/2010, 5.2.0.17911
- I5\ Updated Intel from v9.1.2.1008 package.
- J\ JMicron JMB36X RAID from DriverVer=08/10/2010, 1.17.58.2 to 09/07/2010, 1.17.59.0
- M4\ Marvell 64xx/63xx SAS Controller from 01/27/2009,3.1.0.22 to 10/27/2009,3.1.0.2407
- S2\ Silicon Image ATA/133 from 11/13/2007, 1.2.30.0 to 07/28/2009, 1.2.30.1
- S2A\ Silicon Image ATA/133 Medley Raid from 05/31/2002, 1.0.1.7 to 04/01/2010, 1.0.7.0
v10.09
Repacked using 32MB 7zip dictionary size.
Added
- C4\ Compaq\HP Smart Array SAS/SATA DriverVer=02/22/2010,6.20.0.32
- H11\ Highpoint RocketRAID 62x SATA DriverVer=06/15/2010, 1.2.10.615
- H12\ Highpoint RocketRAID 64x SATA DriverVer=12/31/2009, 1.0.9.1231
- N6r\ NVIDIA nForce 6 SATA/RAID DriverVer=11/12/2008,10.3.0.46 (no .ini entries)
- N7\ NVIDIA nForce 7/8 SATA/AHCI DriverVer=04/09/2010,11.1.0.43 (no .ini entries)
- N7r\ NVIDIA nForce 7/8 SATA/RAID DriverVer=04/09/2010,11.1.0.43 (no .ini entries)
- V4\ VIA StorX Storage Controller DriverVer = 04/30/2010,7.0.7600.105
Updated
- AM0\ AMD SATA Controller SB600, SB700, SB800(AHCI Mode)
Updated to DriverVer=05/05/2009,1.2.0.125 (AHCI)
- AM1\ AMD SATA Controller SB600, SB700, SB800(IDE Mode)
Updated to DriverVer=07/08/2009,5.2.0.57 (IDE)
- H1\ Highpoint RocketRAID 174X SATA
Updated to DriverVer=10/23/2007, 2.0.7.1023
- H1s\ Highpoint RocketRAID 174X SATA
- H5\ Highpoint RocketRAID 2220 SATA
Updated to DriverVer=10/26/2007, 1.9.7.1026
- H8\ Highpoint RocketRAID 2300 SATA
Updated to DriverVer=06/11/2009, 2.3.9.611
- H10\ Highpoint RocketRAID 3xxx/4xxx SATA
Updated to DriverVer=04/28/2009, 1.2.28.28
- I4\ Intel Rapid Storage Technology
Updated to Driver 03/03/2010,9.6.0.1014
- IT\ IT8212 ATA RAID controller
Updated to DriverVer=09/17/2007,1.7.2.9 (last version, phased out)
Updated to DriverVer=08/10/2010, 1.17.58.2
- M\ Marvell 61xx RAID Controller
Updated to DriverVer=01/27/2010,1.2.0.7300
- M3\ Marvell Serial ATA Gen 1,2,3 PCI-X Adapter
Updated to DriverVer=09/10/2006,3.6.3.3
Updated to DriverVer=06/30/2010,1.0.0.1042
- N6\ NVIDIA nForce 6 SATA/AHCI
Updated to DriverVer=11/12/2008,10.3.0.46 (and modified .ini for txtsetup)
- SS\ SiS 180/181 RAID Controller
Updated to DriverVer=05/03/2005,5.1.1039.1090
- SS1\ SiS 0182/1182 RAID Controller
Updated to DriverVer=01/11/2007,5.1.1039.2110
- V\ VIA RAID Controller
Updated to 02/23/2010, 5.1.7600.593 (5.90A)
- V3\ VIA SATA/PATA IDE controller
Updated to 08/13/2009,7.0.7000.294 (2.90A)
Fixed
- I\ Restored original txtsetup.oem, .cat & .inf files.
- I2\ Restored original txtsetup.oem, .cat & .inf files.
- I3\ Restored original txtsetup.oem, .cat & .inf files.
- I4\ Restored official iastor4.sys (v8.9.0.1023)
- I5\ Replaced missing ICH4 drivers
Fixed .ini so won't overload Win2k memory limit.
Renamed \N8\ to \N2\ (Nforce 2/3/4)
Fixed wrong HWID in .ini [AD4] PCI\VEN_1044&DEV_A501&SUBSYS_C06610(xx)
v10.09r1 13 Sep 2010
v10.08b1 28 Aug 2010
Removed
- J1\ JMicron JMB38X SD/MMC Host Controller DriverVer=08/24/2010, 1.0.48.1
Moved to 3dp "Misc" to update folder X\J\
v10.08.09 22 Aug 2010
Updated
- J1\ JMicron JMB38X SD/MMC Host Controller DriverVer=07/27/2010, 1.0.47.3
Added
v10.08.08 12 Aug 2010
Fixed
organized Intel sections of .ini to remove any HWID overlap.
v10.08.07 10 Aug 2010
Updated
Added
v10.08.06 9 Aug 2010
Updated
Updated to DriverVer=07/13/2010, 1.17.57.1
Added
- J1\ JMicron JMB38X SD/MMC Host Controller DriverVer=05/26/2010, 1.0.45.0
Fixed
10.07.15 nightly COMPSTUFF
Updated
-[I4] Intel Matrix Storage from 01/08/2010,8.9.6.1002 to Intel Rapid Storage Technology Driver 03/03/2010,9.6.0.1014
10.06.16 COMPSTUFF
-UPDATED
J
DriverVer=01/27/2010, 1.17.55.0
10.05.29 Mr_Smartepants
Compressed folder names
10.05.22 nightly COMPSTUFF
Updated
-[I4] Intel Matrix Storage from 08/07/2009,8.9.2.1002 to 01/08/2010,8.9.6.1002
10.02.21 nightly Jeff aka OverFlow (Feb 21 2010)
Moved PCI\VEN_8086&DEV_27C5&CC_0106 back to [I3] from [I4]
10.01.25 nightly Jeff aka OverFlow (Jan 25 2010)
[D3]
Perc2 is a replacement driver for XP, and 2k3
Fixed
10.01.24 nightly Jeff aka OverFlow (Jan 24 2010)
updated
Replacement drivers that were missing HWIDs
(If a driver is a replacement it MUST replace all HWIDs supported by the previous driver
dpti2o [AD4]
- verified
adpu160m [AD5]
- restored hwid
PCI\VEN_9005&DEV_0081
symc8xx [C] ms_1
- need special case for a single driver that replaces two or more native drivers...
- Fixed, simply assign no HWIDs to one or more (ms_X) section(s)
- combined old ms_2 and ms_3 into ms_1
symc810 [C] ms_2
- see above. replaced.
sym_hi [C] ms_3
- ms_2 is also replaced
-- see section for example!
mraid35x [L2]
-missing / added
PCI\VEN_8086&DEV_1960&SUBSYS_0493101E
PCI\VEN_8086&DEV_1960&SUBSYS_0475101E
-Lost Hwids? Not referenced / listed in MRAID35X.inf.
These were previously left behind by BASE (not removed or added)
the driver should still work for these HWIDs but they are not specifically listed in MRAID35X.inf.
the updates to BASE 10.x will remove these from txtsetup. They might need to be re-added to the mass ini,
however they should be picked up / covered by the super-generic PCI\VEN_101E&DEV_9060 that IS still listed
(they are probably just redundant)
PCI\VEN_8086&DEV_1960&SUBSYS_04671028
PCI\VEN_8086&DEV_1960&SUBSYS_11111028
PCI\VEN_8086&DEV_1960&SUBSYS_11111111
PCI\VEN_8086&DEV_1960&SUBSYS_11121111
PCI\VEN_8086&DEV_1960&SUBSYS_03A2113C
PCI\VEN_8086&DEV_1960&SUBSYS_04711028
PCI\VEN_8086&DEV_1960&SUBSYS_04931028
[L11]
-Change ms_1_exc_skipIfOS="w2k3" to ms_1_exc_skipIfOS="w2k3,wxp" Mraid2k only supports Win2k
At least according to the L6MRAIDX.inf - again it may work, but it is definately not supported.
This may need to be changed back. Note: Two of these HWIDs were originaly / natively listed for [L2]
- native mraid35x lists PCI\VEN_101E&DEV_1960&SUBSYS_04931028 and PCI\VEN_101E&DEV_1960&SUBSYS_04711028.
dac2w2k [L3] ms_1
dac960nt [L3] ms_2
-Lost Hwids? Not referenced / listed in any infs in this folder.
the driver may still work for these HWIDs but they are not specifically supported any inf.
the updates to BASE 10.x will remove them from txtsetup. They might need to be re-added to the mass ini,
PCI\VEN_1069&DEV_0001
PCI\VEN_1069&DEV_0002
PCI\VEN_1069&DEV_0010
ultra [P8]
-the native driver supports specific HWIDS that are not listed in the replacement drivers section
These were previously left behind by BASE (not removed or added) they may need to be re-added.
PCI\VEN_105A&DEV_4D68&CC_0180
PCI\VEN_105A&DEV_4D30&CC_0180
PCI\VEN_105A&DEV_0D30&CC_0180
PCI\VEN_105A&DEV_4D38&CC_0180
Similar versions of these HWIDs are included in the driver inf and mass.ini and may suffice.
ql12160 [Q4]
-the native driver supports a specific HWID that is not listed in the replacement drivers section
These were previously left behind by BASE (not removed or added) it may need to be re-added.
PCI\VEN_1077&DEV_1216&SUBSYS_01078086
siside [SIS3]
-Not a replacement driver for XP. fixed.
viaide [V3]
- verified
-[PD] [REQ] Promise Fasttrak TX4200 Win2k3 support
commented out the skip w2k3 line in the MassStorage.inf
http://forum.driverpacks.net/viewtopic.php?id=4027
909r6 (1 September 2009)
Updated
-[J] JMicron from 02/19/2009, 1.17.47.11 to 08/11/2009, 1.17.50.2
-[M] Marvel 61xx RAID from 07/22/2008,1.2.0.60 to 08/06/2009,1.2.0.7100
-[I4] Intel Matrix Storage from 06/04/2009,8.9.0.1023 to 08/07/2009,8.9.2.1002
New
-[I7] Intel(R) iSCSI Setup Driver 07/01/2009,2.1.11.3
908129 (29 August 2009)
Renamed folders for 3Ware storage controllers
-[3] is now 3ware Escalade 6000 Storage Switch
-[3B] is now AMCC 3ware 7000/8000 Series ATA RAID
-[3C] is now AMCC 3ware 9000 Series SATA RAID/SAS
Fixed
-in INI file re-added section for AMCC 3ware 9000 Series
-INI file to Reflect new ordering & naming of 3Ware dirs as above
Updated
-[3B] AMCC 3ware 7000/8000 Series ATA RAID from 05/13/2004,1.15.00.014 to 04/08/2008,1.15.00.052
908r5 (24 August 2009)
Changed
-[I4] Added OEM file (JakeLD)
-[AM2] Added OEM file (JakeLD)
New
-[M5] Marvell 9xxx AHCI SATA Controller (JakeLD)
-[PD] Promise FastTrak TX4200/TX4300 11/08/2005, 2.06.0.311 (GregB)
Fixed
-[I5] Removed obsolete files (JakeLD)
-[P] Fixed service name in INF (GregB)
-Renamed duplicated sys file along with their service name in [I2],[I3],[I4].[NV4],[NV4IN],[NV5],[SA],[SA2],[SB2],[SB3],[SB4].[SB5] (GregB)
908r4a (17 August 2009)
Fixed
-Reordered 3Ware drivers in INI file (mindwwarper)
[3C] becomes first
[3B] remains same second
[3] becomes third
907r3 (30 July 2009)
Fixed
-[M] Marvel 61xx RAID, replaced x64 driver by the i386
Changed
-[P4K] & [P4S] removed, covered by the [P4] driver
907r2 (28 July 2009)
Updated
-[M] Marvel 61xx RAID from 07/22/2008,1.2.0.60 to 02/08/2009,1.2.0.68
-[V3] VIA SATA/PATA from 12/05/2008,6.0.6000.275 to 04/02/2009,6.0.6001.282 [5.24a]
-[J] JMicron from 02/19/2009, 1.17.47.11 to 07/17/2009, 1.17.49.4
-[I5] Intel Chipset 9.1.1.1015
-[P4S] Promise FastTrak S150 SX4 from 05/20/2004, 2.00.00.25 to 09/27/2004, 2.00.64.23 (ef)
-[AR] ARECA ARC-1210 SAS RAID from 03/22/2007,6.20.00.14 to 04/04/2007,6.20.00.15
-[M4] Marvell 64xx/63xx SAS from 12/06/2007,2.1.0.11 to 01/27/2009,3.1.0.22
-[AM2] AMD AHCI Compatible RAID 7xx from 08/30/2008, 3.1.1540.81 to 03/17/2009, 3.1.1540.127 [Catalyst 9.7]
Fixed
-Changed [AM] & [AM1] sections to fix a BSOD with AMD IDE driver (cfp)
New
-[H4], [H4K], [H4S] Highpoint RocketRAID 26xx SAS 05/13/2009, 1.1.9.513 (alur)
-[D3] Dell PERC 2, 2/Si, 3/Si, 3/Di 02/25/2004, 2.8.0.6085
-[ADD] ADAPTEC/HP Embedded G5 SATA RAID 11/29/2007,1.4.17015.0
907r1 (12 July 2009)
Updated
-[I4] Intel Matrix Storage to 06/04/2009,8.9.0.1023 (SamLab)
906n2 (21 June 2009)
Updated
-[I4] Intel Matrix Storage from 04/27/2009,8.8.2.1001 to 04/10/2009,8.9.0.1015 (SamLab)
906n1 (9 June 2009)
Fixed by SamLab - Undo this changes:
-[AM1] AMD PCI SATA/IDE from 10/11/2007,5.1.0.8 to 06/18/2008,5.1.0.8
-[N7] Nvidia nForce 11/12/2008,10.3.0.46
-[N5] and [N6] Removed; covered by [N7]
Updated
-[I4] Intel Matrix Storage from 09/12/2008,8.6.0.1007 to 04/27/2009,8.8.2.1001 (SamLab)
905r2 (15 Mat 2009)
-Removed DP*.inf from L8
-Added L8r folder with older SYMMPI.INF - version XP.10
-Restored support for legacy Controlers dropped in newer
-SYMMPI.INF - version XP.11 in L8
-Fixed VMWare support
905r1 (10 May 2009)
Fixed
-All Intel INI sections were redone from scratch
-[I4] fixed errors in dpsI4.inf
-Added AHCI support for PCI\VEN_8086&DEV_24D1&CC_0106 and PCI\VEN_8086&DEV_2651&CC_0106
-[AM3] Removed duplicate hwids covered by [AM2]
-[L10] Downgraded to the last signed driver 03/20/2006,1.21.15.00
-[AD5] Removed "%" sign
-[S4] Removed PCI\VEN_1002&DEV_436E&SUBSYS_436E1002, PCI\VEN_1002&DEV_4379&SUBSYS_43791002 and PCI\VEN_1002&DEV_437A&SUBSYS_437A1002 ; covered by [S5]
New
-[P6K] Promise SATA150 TX Series IDE for Windows 2000 06/12/2003, 1.00.0.27
-[P6S] Promise SATA150 TX Series IDE for Windows 2003 06/12/2003, 1.00.0.27
-[TOS] Toshiba RAID 02/20/2007, 1.10.0016
Updated
-[L8] LSI Logic SAS 3000/Dell SAS 5X/6I from 06/03/2008,1.28.03.00 to 07/09/2008,1.28.03.01
-[AM2] AMD AHCI Compatible RAID 7xx from 03/07/2008, 3.1.1540.50 to 08/30/2008, 3.1.1540.81
-[I4] Intel Matrix Storage from 09/12/2008,8.6.0.1007 to 02/11/2009,8.8.0.1009
-[J] JMicron JMB36X\37X from 12/18/2008, 1.17.45.04 to 02/19/2009, 1.17.47.11
-[I5] Intel Chipset SATA/IDE 9.1.0.1012
-[ADC] ADAPTEC/ICP/IBM/SUN/AOC SATA/SAS RAID from 02/08/2008,5.2.0.15728 to 07/10/2008,5.2.0.16120
-[P7] Promise SATAII150/SATA300 TX from 06/30/2005, 1.00.0.33 to 05/16/2007, 1.00.0.39
Na drugiej płytce wgrałem sterowniki do instalki :Sata_Pakiet_v2
Czy ktoś może mi pomóc???
Dodano po 38 [minuty]: Czy te sterowniki na stronie producenta są sterownikami do dysków SATA??
to znajduje się w grupie sterowników RAID
NVIDIA NVIDIA MCP61/MCP68 SATA RAID Driver (Preinstall driver, press F6 during Windows* setup to read from floppy)
Pliki do pobrania:
Europa(Rosja): ftp / http · Europa · Ameryka · Azja · Azja(Chiny)
Windows XP
Bo może spróbować ten sterownik ściągnąć i tylko ten dorzucić poprzez nlite do płytki instalacyjnej???
Proszę o pomoc
