Proszę o analizę SMART dysków.
Wygląda na to że Seagaty do wymiany ale chciał bym się upewnić.
Jeden ma 29 relokowanych sektorów, oba mają po kilka Spin-up retries.
Oba dyski są na gwarancji producenta.
Załączam logi z Victorii.
Model: ST3500320AS
Firmware: SD15
Serial: 5QM384JL
Disk size: 976771055 LBAs 476938 Mb
CHS: 16383/16/63 8063 Mb
SMART: Enabled, Errlog, Selftest
CACHE: Unk.size; L/A=ON; Wr=ON; ok
Support: LBA, DLM, DMA UDMA-6
Erase: ~104 minutes
Security: OFF
ATA-8: SCT, WrUnk, W-R-V
ID Name Value Worst Tresh Raw Health
1 Raw read error rate 119 99 6 230587696 •••••
3 Spin-up time 95 91 0 0 ••••
4 Number of spin-up times 98 98 20 2268 ••••
5 Reallocated sector count 100 100 36 0 •••••
7 Seek error rate 63 56 30 114050877 •••
9 Power-on time 94 94 0 5595 ••••
10 Spin-up retries 100 100 97 6 •••••
12 Start/stop count 98 98 20 2269 ••••
184 End-to-End Error 100 100 99 0 •••••
187 Reported UNC Error 100 100 0 0 •••••
188 Command Timeout 100 99 0 196629 •••••
189 High Fly Writes 91 91 0 9 ••••
190 Airflow Temperature 69 55 45 31°C/87°F ••••
194 HDA Temperature 31 45 0 31°C/87°F ••••
195 Hardware ECC recovered 42 31 0 230587696 ••
197 Current pending sectors 100 100 0 0 •••••
198 Offline scan UNC sectors 100 100 0 0 •••••
199 Ultra DMA CRC errors 200 200 0 0 •••••
In Warranty
Expiration 30-Sep-2013
Model: ST3500320AS
Firmware: SD15
Serial: 9QM26W3K
Erase: ~104 minutes
Security: OFF
1 Raw read error rate 116 93 6 107862662 •••••
3 Spin-up time 95 94 0 0 ••••
4 Number of spin-up times 98 98 20 2371 ••••
5 Reallocated sector count 100 100 36 29 •••••
7 Seek error rate 72 60 30 139906281 •••
9 Power-on time 90 90 0 9553 ••••
10 Spin-up retries 100 100 97 2 •••••
12 Start/stop count 98 98 20 2367 ••••
187 Reported UNC Error 1 1 0 2694 •
188 Command Timeout 100 98 0 327698 •••••
189 High Fly Writes 75 75 0 25 •••
190 Airflow Temperature 71 52 45 29°C/84°F ••••
194 HDA Temperature 29 48 0 29°C/84°F ••••
195 Hardware ECC recovered 44 28 0 107862662 ••
199 Ultra DMA CRC errors 200 200 0 1 •••••
In Warranty
Expiration 12-Mar-2013
Model: SAMSUNG HD642JJ
Firmware: 1AA01113
Serial: S1AFJ90S202985
Disk size: 1250263728 LBAs 610480 Mb
CACHE: 16384k; L/A=ON; Wr=ON; ok
Support: LBA, AAM, APM, DLM, DMA UDMA-6
AAM val: 0 Disabled
APM val: 0 Disabled
Erase: ~110 minutes
Security: OFF
ATA-8: SCT, SFDLM, WrUnk
1 Raw read error rate 100 100 51 0 •••••
3 Spin-up time 87 87 11 4850 ••••
4 Number of spin-up times 97 97 0 3016 ••••
5 Reallocated sector count 100 100 10 0 •••••
7 Seek error rate 253 253 51 0 •••••
8 Seek time perfomance 100 100 15 0 •••••
9 Power-on time 99 99 0 4367 ••••
10 Spin-up retries 100 100 51 0 •••••
11 Recalibration retries 100 100 0 0 •••••
12 Start/stop count 98 98 0 2408 ••••
13 Soft read error rate 100 100 0 0 •••••
183 unknown attribut 100 100 0 0 •••••
184 End-to-End Error 100 100 0 0 •••••
188 Command Timeout 100 100 0 0 •••••
190 Airflow Temperature 72 63 0 28°C/82°F ••••
194 HDA Temperature 72 60 0 28°C/82°F ••••
195 Hardware ECC recovered 100 100 0 23103 •••••
196 Reallocated event count 100 100 0 0 •••••
199 Ultra DMA CRC errors 100 100 0 0 •••••
200 Write error rate 100 100 0 0 •••••
201 Off-track errors count 253 253 0 0 •••••
