Błąd programowania Atemga32 z Megaload - komunikat Error occured aborted
kmkm2 26 Lut 2011 20:57 710 0
  • #1 9208760
    kmkm2
    Ocena: 15
    Zrobiłem wszystko zgodnie z dokumentacją, ale podczas próby zaprogramowania wyskakuje komunikat Error occured aborted.... . poniżej konfiguracja z pliku main.c
    / *->Do the same thing in assembly.s<-*
    // This setup is for a MEGA8,  You must make changes for your MCU
    // DO NOT REMOVE THIS LINE !!!
    #define RAMPZ (*(volatile unsigned char *)0x00)
    // Your MCU header file
    #include "iom32v.h"
    // Temporary buffer size in byte. Check in the table it's written 32 word, so it's 64 byte
    #define PageSize         64
    // It's written in the Bootloader section of your datasheet. Check this table for the M8
    // it's ZPAGEMSB 5 + 1  = 6
    #define NSHIFTPAGE       6
    // Define wath is the name of the interrupt register.  It's different from
    // one MCU to another
    #define INTVECREG        GICR
    // Your MCU frequancy
    #define XTAL        	 8000000
    // UART you are bootloading on
    #define UART        	 0
    // UART BaudRate
    #define BAUDRATE         9600
