Podczas usuwania simlocka z 8100 skorzystałem z metody:
1. Insert SIM card
2. Go to "Settings" -> "Options" (or Go to "Options" ->" Device" for 9800, 9780 and other OS 6.0)
3. Select "Advanced options" or "Advanced system settings" -> "SIM Card"
4. Type "mepd" (or "meppd" for 8100, 8110, 8120) using your Blackberry keyboard
5. Type "mep" (or "mepd" for 8100, 8110, 8120) then [ALT BUTTON] and the lock level ( 2 or 4)
NOTE: You will not see any text appear on the screen while typing on step 3 and 4.
6. You should be presented with a prompt "Enter Network MEP Code"
7. Enter the Unlock Code and press in the enter/track ball/track pad to confirm
8. Device is now unlocked.
Niestety na kroku 5 mam problem ponieważ nie wyskakuje mi okno do wpisania kodu po mimo wpisania mepd ALT+2 lub 4
Co może być przyczyną?
1. Insert SIM card
