MSI P45 neo2-FR - Zbiór BIOS-ów, wersje BETA i Performance-BIOS
Pultan 24 Maj 2011 23:08 6658 2
  • #1 9541242
    Pultan
    Poziom 30  
    Ocena: 27
    Jeśli ktoś poszukuje biosów do tej płytki to zamieszczam swój zbiór:)
    BETA i oficjalne Biosy --> A7512IMS.3xx
    Performance-BIOS --> A7512IMS.P3x
    A7512IMS.300
    First BIOS Release.
    A7512IMS.310
    Update CPU Micro Code.
    A7512IMS.310 --> A7512IMS.321
    Fix Memory-Z show error message when using some EPP-1066MHz DDR2.
    Update some code for oemboard 205.
    Arrangement of All Voltage item.
    Fix system will hang D0h when OC.
    Modify VTT Auto Voltage to 1.2V.
    Change E8X00 CPU Auto SMIOC mode.
    Patch E8X00 CPU Auto setting NB GTL REF Voltage can't be restore when change CPU.
    Fix some PCIE 2.0 card will display no video after install driver.
    Add dual logo function.
    A7512IMS.324 --> A7512IMS.325
    Fix Keep UUID function.
    Fix the system hang "Wait..." when enter BIOS setup menu.
    Init CPU VID to max value to avoid CPU Vcore adjument confuse if EIST disable.
    Added a hook to vaild PCIE configuration cycles after reset.
    A7512IMS.320
    Improved memory compatibility.
    A7512IMS.320 --> A7512IMS.331
    Patch DRAM capability as follow: (1066MHz kingstonKHX8500D2K2/ kingstonKHX9200D2K2/Patriot)
    Support E8XXX and QXXXX MP CPU.
    Add MCH Drive Configure item for user to OC memory.
    Patch the system can't resume from S3 or S4 when using ATI 4780!Á2 VGA card.
    Fix the system keep restarting when booting after enable TCG/TPM support.
    A7512IMS.331 --> A7512IMS.332
    Fixed the issue: when an ATI 3870x2 VGA Card be pluged on the PCIE Slot1, and another VGA Card exist, the ATI 3870x2 VGA Card could not lighten the Screen.
    Patch the system hang when running CrossFire with R4870-T2D512 OC in Vista.
    Change the DMI type02 Product Name as Market name.
    A7512IMS.332 --> A7512IMS.333
    Update CPU emodule to '8.00.12_CPU-P4_3F.12'.
    Update 4GBPlus to '8.00.01_4GBPLUS-1.00.08'.
    Update Intel PPM DT to '8.00.14_IPPMDT_01.03-Beta2'.
    Fix the Intel "Top swap bit" issue.
    Fix DDR2 voltage and data error when S3 resume.
    A7512IMS.330
    Support L2 function.
    Support 1000GB HDD.
    • A7512IMS333.7z (572.87 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS332.7z (582.99 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS330.7z (573.4 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS326.7z (582.58 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS325.7z (582.5 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS323.7z (578.71 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS321.7z (630.71 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS320.7z (582.5 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS310.7z (576.46 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS300.7z (574.48 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #2 9541255
    Pultan
    Poziom 30  
    Ocena: 27
    2 porcja biosów
    A7512IMS.341 --> A7512IMS.342
    Fix using E8400 CPU(SLB9J),the temperature shows higher than actually detecting.
    Fix the system hang when boot up and show E9h with Corsair DDR2-1066 2GB*4.
    Fix the system hang when set Kingston DDR2-1066 2GB*4 run in 1066MHz.
    Add "MSI BIOS setup flash" function
    A7512IMS.340
    A7512IMS.340 --> A7512IMS.353
    Add Intel Virtualization Technology Option
    Patch DDR2-1200(OCZ2RPR12002G) 2GB*2 capability run in 1200MHz
    Remove Ati VGA card bootblock video support to avoid sytem hang at 20h/2eh if insert some Ati VGA card.
    A7512IMS.353 ---> 354 ---> A7512IMS.355
    Fix system can not detect PCI-E x1 frame grabber card.
    FIX The system would freeze or restart all the time after adjusting CPU FSB as 400MHz.
    A7512IMS.358
    Latest Beta ??
    A7512IMQ MOA 320
    Special Bios for MOA series Mainboards
    A7512IH7 301
    • A7512IMQ MOA 320.7z (555.34 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IH7 301.7z (579.85 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS358.7z (579.8 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS355.7z (579.61 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS354.7z (579.69 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS353.7z (579.3 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS351.7z (579.25 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS342.7z (578.97 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMS340.7z (579.05 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #3 9541262
    Pultan
    Poziom 30  
    Ocena: 27
    3 porcja i ostatnia
    A7512ICI.301
    A7512ICI.302
    Chinese Custom BIOS
    DPC Latency Fixed
    A7512IMS.P32
    A7512IMS.P35 --> A7512IMS.P36
    Fix GOODRAM memory RST fail issue.
    Add the solution about some motherboard hang 9B issue.
    Update CPU microcode for cpuid=10677h and 106C2h.
    Fix the system keep resetting when adjust QX9650 CPU ratio*10 and CPU voltage above 1.54V.
    Fix temperature show error when it less than 0 degree.
    A7512IMS.P37 --> A7512IMS.P38
    Patch the system hang when running CrossFire with R4870-T2D512 OC in Vista.Change the DMI type02 Product Name as Market name.
    A7512IMS.P38 --> A7512IMS.P39
    Update CPU emodule, 4GBPlus emodule and Intel PPM DT emodule.
    Fixed the APS Function Fail after the OS resume from S3.
    Add patch to avoid AHCI detect incrrect issue.
    Support the /L2 (load cmos default) function while using AFUD4252 flash utility.
    Fix the 1000G HDD detect error in post2 (only show 100G).
    Update MRC 250.
    • A7512ICI302.7z (578.35 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512ICI301.7z (572.4 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMSP39.7z (574.06 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMSP38.7z (583.64 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMSP36.7z (583.14 KB) Musisz być zalogowany, aby pobrać ten załącznik.
    • A7512IMSP32.7z (631.7 KB) Musisz być zalogowany, aby pobrać ten załącznik.
