problemy ShowImg podczas kompilacji z DigiKam plugin
piotrst08 11 Lis 2004 16:59 795 2
  • #1 978017
    piotrst08
    Ocena: 3
    nie moge skompilowac showimg z pluginami digiakm, ktore zainstalowaly sie bez problemu. Przedstawiam logi z kompilacji:
    ./configure --enable-digiKam-plugin
    checking build system type... i686-pc-linux-gnu
    checking host system type... i686-pc-linux-gnu
    checking target system type... i686-pc-linux-gnu
    checking for a BSD-compatible install... /usr/bin/ginstall -c
    checking for -p flag to install... yes
    checking whether build environment is sane... yes
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking for style of include used by make... GNU
    checking for gcc... gcc
    checking for C compiler default output file name... a.out
    checking whether the C compiler works... yes
    checking whether we are cross compiling... no
    checking for suffix of executables...
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for gcc option to accept ANSI C... none needed
    checking dependency style of gcc... gcc3
    checking how to run the C preprocessor... gcc -E
    checking for g++... g++
    checking whether we are using the GNU C++ compiler... yes
    checking whether g++ accepts -g... yes
    checking dependency style of g++... gcc3
    checking whether g++ supports -Wmissing-format-attribute... yes
    checking whether g++ supports -Wundef... yes
    checking whether g++ supports -Wno-long-long... yes
    checking whether g++ supports -Wnon-virtual-dtor... yes
    checking whether g++ supports -fno-exceptions... yes
    checking whether g++ supports -fno-check-new... yes
    checking whether g++ supports -fno-common... yes
    checking whether g++ supports -fexceptions... yes
    checking how to run the C++ preprocessor... g++ -E
    checking whether g++ supports -O0... yes
    checking whether g++ supports -Wl,--no-undefined... yes
    checking whether g++ supports -Wl,--allow-shlib-undefined... yes
    not using lib directory suffix
    checking for a sed that does not truncate output... /bin/sed
    checking for egrep... grep -E
    checking for ld used by gcc... /usr/i486-slackware-linux/bin/ld
    checking if the linker (/usr/i486-slackware-linux/bin/ld) is GNU ld... yes
    checking for /usr/i486-slackware-linux/bin/ld option to reload object files... -r
    checking for BSD-compatible nm... /usr/bin/nm -B
    checking whether ln -s works... yes
    checking how to recognise dependent libraries... pass_all
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking dlfcn.h usability... yes
    checking dlfcn.h presence... yes
    checking for dlfcn.h... yes
    checking for g77... g77
    checking whether we are using the GNU Fortran 77 compiler... yes
    checking whether g77 accepts -g... yes
    checking the maximum length of command line arguments... 32768
    checking command to parse /usr/bin/nm -B output from gcc object... ok
    checking for objdir... .libs
    checking for ar... ar
    checking for ranlib... ranlib
    checking for strip... strip
    checking if gcc static flag works... yes
    checking if gcc supports -fno-rtti -fno-exceptions... no
    checking for gcc option to produce PIC... -fPIC
    checking if gcc PIC flag -fPIC works... yes
    checking if gcc supports -c -o file.o... yes
    checking whether the gcc linker (/usr/i486-slackware-linux/bin/ld) supports shared libraries... yes
    checking whether -lc should be explicitly linked in... no
    checking dynamic linker characteristics... GNU/Linux ld.so
    checking how to hardcode library paths into programs... immediate
    checking whether stripping libraries is possible... yes
    checking for shl_load... no
    checking for shl_load in -ldld... no
    checking for dlopen... no
    checking for dlopen in -ldl... yes
    checking whether a program can dlopen itself... yes
    checking whether a statically linked program can dlopen itself... yes
    checking if libtool supports shared libraries... yes
    checking whether to build shared libraries... yes
    checking whether to build static libraries... no
    configure: creating libtool
    appending configuration tag "CXX" to libtool
    checking for ld used by g++... /usr/i486-slackware-linux/bin/ld
    checking whether the g++ linker (/usr/i486-slackware-linux/bin/ld) supports shared libraries... yes
    checking for g++ option to produce PIC... -fPIC
    checking if g++ PIC flag -fPIC works... yes
    checking if g++ supports -c -o file.o... yes
    checking for shl_load... (cached) no
    checking for shl_load in -ldld... (cached) no
    checking for dlopen... (cached) no
    checking for dlopen in -ldl... (cached) yes
    checking whether a program can dlopen itself... (cached) yes
    checking whether a statically linked program can dlopen itself... (cached) yes
    appending configuration tag "F77" to libtool
    checking for g77 option to produce PIC... -fPIC
    checking if g77 PIC flag -fPIC works... yes
    checking if g77 supports -c -o file.o... yes
    checking whether the g77 linker (/usr/i486-slackware-linux/bin/ld) supports shared libraries... yes
    checking for msgfmt... /usr/bin/msgfmt
    checking for gmsgfmt... /usr/bin/msgfmt
    checking for xgettext... /usr/bin/xgettext
    checking if C++ programs can be compiled... yes
    checking for strlcat... no
    checking if strlcat needs custom prototype... yes - in libkdefakes
    checking for strlcpy... no
    checking if strlcpy needs custom prototype... yes - in libkdefakes
    checking for main in -lutil... yes
    checking for main in -lcompat... no
    checking for crypt in -lcrypt... yes
    checking for socklen_t... socklen_t
    checking for dnet_ntoa in -ldnet... no
    checking for dnet_ntoa in -ldnet_stub... no
    checking for inet_ntoa... yes
    checking for connect... yes
    checking for remove... yes
    checking for shmat... yes
    checking for sys/types.h... (cached) yes
    checking for stdint.h... (cached) yes
    checking for poll in -lpoll... no
    checking CoreAudio/CoreAudio.h usability... no
    checking CoreAudio/CoreAudio.h presence... no
    checking for CoreAudio/CoreAudio.h... no
    checking if res_init needs -lresolv... yes
    checking if res_init is available... yes
    checking for killpg in -lucb... no
    checking for int... yes
    checking size of int... 4
    checking for short... yes
    checking size of short... 2
    checking for long... yes
    checking size of long... 4
    checking for char *... yes
    checking size of char *... 4
    checking for shl_unload in -ldld... no
    checking for size_t... yes
    checking size of size_t... 4
    checking for unsigned long... yes
    checking size of unsigned long... 4
    checking sizeof size_t == sizeof unsigned long... yes
    checking crt_externs.h usability... no
    checking crt_externs.h presence... no
    checking for crt_externs.h... no
    checking for _NSGetEnviron... no
    checking for vsnprintf... yes
    checking for snprintf... yes
    checking for X... libraries /usr/X11/lib, headers .
    checking for IceConnectionNumber in -lICE... yes
    checking for libXext... yes
    checking for pthread_create in -lpthread... yes
    checking for extra includes... no
    checking for extra libs... no
    checking for libz... -lz
    checking for libpng... -lpng -lz -lm
    checking for libjpeg6b... no
    checking for libjpeg... -ljpeg
    checking for perl... /usr/bin/perl
    checking for Qt... libraries /usr/lib/qt/lib, headers /usr/lib/qt/include using -mt
    checking for moc... /usr/lib/qt/bin/moc
    checking for uic... /usr/lib/qt/bin/uic
    checking whether uic supports -L ... yes
    checking whether uic supports -nounload ... yes
    checking if Qt needs -ljpeg... no
    checking for rpath... yes
    checking for KDE... libraries /opt/kde/lib, headers /opt/kde/include
    checking if UIC has KDE plugins available... yes
    checking for KDE paths... defaults
    checking for dcopidl... /opt/kde/bin/dcopidl
    checking for dcopidl2cpp... /opt/kde/bin/dcopidl2cpp
    checking for mcopidl... /opt/kde/bin/mcopidl
    checking for artsc-config... /opt/kde/bin/artsc-config
    checking for kde-config... /opt/kde/bin/kde-config
    checking for meinproc... /opt/kde/bin/meinproc
    checking for xmllint... /usr/bin/xmllint
    checking if digiKam-plugin support is wanted for ShowImg... yes
    checking digikam/albummanager.h usability... no
    checking digikam/albummanager.h presence... no
    checking for digikam/albummanager.h... no
    configure: WARNING: No Digikam plugins support for ShowImg
    checking konq_operations.h usability... yes
    checking konq_operations.h presence... yes
    checking for konq_operations.h... yes
    checking for stdlib.h... (cached) yes
    checking for GNU libc compatible malloc... yes
    checking for error_at_line... yes
    checking for working memcmp... yes
    checking whether time.h and sys/time.h may both be included... yes
    checking sys/time.h usability... yes
    checking sys/time.h presence... yes
    checking for sys/time.h... yes
    checking for unistd.h... (cached) yes
    checking for alarm... yes
    checking for working mktime... no
    checking whether lstat dereferences a symlink specified with a trailing slash... yes
    checking whether stat accepts an empty string... no
    checking for strftime... yes
    checking whether utime accepts a null argument... yes
    checking for floor... no
    checking for gettimeofday... yes
    checking for memmove... yes
    checking for memset... yes
    checking for mkdir... yes
    checking for rmdir... yes
    checking for strdup... yes
    checking for strncasecmp... yes
    checking for utime... yes
    checking for strstr... yes
    checking fcntl.h usability... yes
    checking fcntl.h presence... yes
    checking for fcntl.h... yes
    checking for sys/time.h... (cached) yes
    checking utime.h usability... yes
    checking utime.h presence... yes
    checking for utime.h... yes
    checking for ptrdiff_t... yes
    checking for an ANSI C-conforming const... yes
    checking for inline... __inline__
    checking whether time.h and sys/time.h may both be included... (cached) yes
    checking for stdbool.h that conforms to C99... yes
    checking for _Bool... yes
    checking for ranlib... (cached) ranlib
    checking whether struct tm is in sys/time.h or time.h... time.h
    checking for size_t... (cached) yes
    checking if doc should be compiled... yes
    checking if po should be compiled... yes
    checking if showimg should be compiled... yes
    configure: creating ./config.status
    fast creating Makefile
    fast creating doc/Makefile
    fast creating doc/da/Makefile
    fast creating doc/de/Makefile
    fast creating doc/en/Makefile
    fast creating doc/es/Makefile
    fast creating doc/et/Makefile
    fast creating doc/fr/Makefile
    fast creating doc/it/Makefile
    fast creating doc/sv/Makefile
    fast creating po/Makefile
    fast creating showimg/Makefile
    fast creating showimg/digikamplugins/Makefile
    fast creating showimg/icons/Makefile
    fast creating showimg/khexedit/Makefile
    fast creating showimg/mimetypes/Makefile
    fast creating showimg/misc/Makefile
    fast creating showimg/pics/Makefile
    config.pl: fast created 18 file(s).
    config.status: creating config.h
    config.status: config.h is unchanged
    config.status: executing depfiles commands
    Configure results:
    Digikam plugins for ShowImg: no
    You are missing the Digikam headers and libraries
    The Digikam plugins won't be compiled.
    Installation direcory is /opt/kde
    Good - your configure finished. Start make now
    Prosze o rade!
  • #2 978022
    Kolobos
    Spec od komputerów
    Ocena: 10460
    Digikam-devel i libs masz? bo przeciez jest napisane ze tego Ci brakuje :-)
  • #3 981005
    piotrst08
    Ocena: 3
    mam zainstalowane libs w /opt/kde/lib a co do devel to nie wiem o co w sumie chodzi, ale digikam zainstalowalo sie bez problemow, jak rozwniez dodatkowe pluginy do digikam
