Witam! Mam d-linka-300 dir ver.A1 Flashowałem na dd-wrt Niestety po odpaleniu router się resetuje!Brak połączenia po lanie! Putty po rs lączy się z routerem ale nie ma w konsoli zachęty Redboot. Oto logi.:
Linux version 2.6.23.17 (root@dd-wrt) (gcc version 4.1.1) #5266 Mon Jul 28 20:44 :08 CEST 2008
CPU revision is: 00019064
mem setup
Determined physical RAM map:
memory: 01000000 @ 00000000 (usable)
User-defined physical RAM map:
Built 1 zonelists in Zone order. Total pages: 4064
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 rootfstype=squashf s noinitrd mem=16M
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 64 (order: 6, 256 bytes)
Using 92.000 MHz high precision timer.
console [ttyS0] enabled
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 13060k/16384k available (2203k kernel code, 3324k reserved, 292k data, 1 24k init, 0k highmem)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
Found board config at 0xa83f0000
Radio config found at offset 0xf8(0x1f8) (a83f00f8)
Generic PHY: Registered new driver
NET: Registered protocol family 2
Time: MIPS clocksource has been installed.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
gpio_proc: module loaded and /proc/gpio/ created
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
squashfs: version 3.0 (2006/03/15) Phillip Lougher
io scheduler noop registered
io scheduler deadline registered (default)
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0xb1100003 (irq = 37) is a 16550A
serial8250 serial8250.0: unable to register port at index 0 (IO3f8 MEM0 IRQ4): - 28
serial8250 serial8250.0: unable to register port at index 1 (IO2f8 MEM0 IRQ3): - 28
serial8250 serial8250.0: unable to register port at index 2 (IO3e8 MEM0 IRQ4): - 28
serial8250 serial8250.0: unable to register port at index 3 (IO2e8 MEM0 IRQ3): - 28
Infineon ADM6996: Registered new driver
Marvell 88E6060: Registered new driver
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
scanning for root partition
[0x00000000]
[0x00010000]
[0x00020000]
[0x00030000]
[0x00040000]
[0x00050000]
[0x00060000]
[0x00070000]
[0x00080000]
[0x00090000]
[0x000A0000]
[0x000B0000]
[0x000C0000]
[0x000D0000]
[0x000E0000]
[0x000F0000]
[0x00100000]
found squashfs at 100000
found RedBoot partition at [0xBFC00000]
found linux partition at [0xBFC30000]
Creating 8 MTD partitions on "spiflash":
0x00000000-0x00030000 : "RedBoot"
0x00030000-0x003d0000 : "linux"
0x00100000-0x003b0000 : "rootfs"
0x003b0000-0x003d0000 : "ddwrt"
0x003d0000-0x003e0000 : "nvram"
0x003e0000-0x003f0000 : "FIS Directory"
0x003f0000-0x00400000 : "board_config"
0x00030000-0x003e0000 : "fullflash"
watchdog hb: 20 ISR: 0x20 IMR: 0x8 WD : 0x1ba84b94 WDC: 0x0
ar2315_wdt_init using heartbeat 20 s cycles 800000000
watchdog hb: 20 ISR: 0x20 IMR: 0x88 WD : 0x2fa9dfda WDC: 0x0
u32 classifier
Actions configured
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
ctnetlink v0.93: registering with nfnetlink.
IPv4 over IPv4 tunneling driver
GRE over IPv4 tunneling driver
ip_tables: (C) 2000-2006 Netfilter Core Team
ClusterIP Version 0.8 loaded successfully
TCP bic registered
TCP cubic registered
TCP westwood registered
TCP highspeed registered
TCP hybla registered
TCP htcp registered
TCP vegas registered
TCP scalable registered
NET: Registered protocol family 17
Welcome to PF_RING 3.2.1
(C) 2004-06 L.Deri <deri@ntop.org>
NET: Registered protocol family 27
PF_RING: bucket length 128 bytes
PF_RING: ring slots 4096
PF_RING: sample rate 1 [1=no sampling]
PF_RING: capture TX No [RX only]
PF_RING: transparent mode Yes
PF_RING initialized correctly.
PF_RING: registered /proc/net/pf_ring/
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
decode /dev/mtdblock2
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 124k freed
ar2315_wdt: starting watchdog w/timeout 20 seconds
watchdog hb: 20 ISR: 0x20 IMR: 0x89 WD : 0x2fad08bf WDC: 0x0
Algorithmics/MIPS FPU Emulator v1.5
test pattern is FFFFFFFF
eth0: Atheros AR231x: 00:24:01:af:f8:74, irq 4
ar2313_eth_mii: probed
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:00)
ath_hal: module license 'Proprietary' taints kernel.
Reset ICPLUS Phy
Start Autonegotiation
Port 0, Negogiation timeout
Port 1, Negogiation timeout
Port 2, Negogiation timeout
Port 3, Negogiation timeout
Port 4, Negogiation timeout
Port 5, Negogiation timeout
Setup VLANS
sh: cannot create /proc/sys/net/ipv4/tcp_westwood: nonexistent directory
sh: cannot create /proc/sys/net/ipv4/tcp_vegas_cong_avoid: nonexistent directory
sh: cannot create /proc/sys/net/ipv4/tcp_vegas_alpha: nonexistent directory
sh: cannot create /proc/sys/net/ipv4/tcp_vegas_beta: nonexistent directory
br0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
device vlan0 entered promiscuous mode
device eth0 entered promiscuous mode
sh: cannot create /proc/sys/dev/wifi0/compression: nonexistent directory
ath0
Interface doesn't accept private ioctl...
compression (8BE0): Invalid argument
ff (8BE0): Invalid argument
Invalid command : scandisable
SET failed on device ath0 ; Invalid argument.
device ath0 entered promiscuous mode
br0: port 2(ath0) entering learning state
br0: port 1(vlan0) entering learning state
br0: topology change detected, propagating
br0: port 2(ath0) entering forwarding state
br0: port 1(vlan0) entering forwarding state
SIOCGIFFLAGS: No such device
CPU 0 Unable to handle kernel paging request at virtual address 2bfd1b2a, epc == c00d8120, ra == c00da4fc
Oops[#1]:
Cpu 0
$ 0 : 00000000 10009400 0000ffff 2bfd1b26
$ 4 : 0000ffff c0107c40 00000000 00280400
$ 8 : 00000024 00000002 00000002 82848b96
$12 : 2aaae804 2ac5a7bc 2ac5dfac 2ab7af05
$16 : 80a22c46 808a83a0 80c9c3a0 808ba000
$20 : 808a8b58 808ba1cf 00000000 00016826
$24 : 00000002 2aaa9464
$28 : 80e2a000 80e2bb58 c0110000 c00da4fc
Hi : 00000000
Lo : 00000000
epc : c00d8120 Tainted: P
ra : c00da4fc Status: 10009403 KERNEL EXL IE
Cause : 30800008
BadVA : 2bfd1b2a
PrId : 00019064
Modules linked in: ath_ahb ath_hal(P) ar2313
Process startservices (pid: 217, threadinfo=80e2a000, task=803a1088)
Stack : 802e0000 00000001 80a22c36 808a83a0 c00da4fc 808a8b58 c00f7338 80000000
80b39ac0 80b682a8 808ba000 808a8b58 8097ebe0 808a83a0 80c9c3a0 80934000
c00da860 c00da844 00000000 00000001 ffffffea 803a1088 80a22c28 80c9c3a0
808a83a0 80c9c3a0 808ba000 80998800 00000000 c00c5738 000200d2 00000000
00000001 00000044 00001000 c0000000 80332ca0 00000001 000200d2 00000000
Call Trace:[<c00da4fc>][<c00f7338>][<c00da860>][<c00da844>][<c00c5738>][<c00d21c c>][<802b8860>][<8008b604>][<8008d6fc>][<80042a40>][<800bea74>][<80043164>][<800 95c88>][<802b8860>][<8004ec48>][<800a1f50>][<800a1f30>][<800a3d98>][<800604a8>][ <80060444>][<802b88a0>][<802b8860>][<802b8894>][<8004e29c>][<802b8860>][<8005f06 8>][<800b0544>][<800a6e2c>][<800a6e0c>][<802649a8>][<80069128>][<80069120>][<800 6af24>][<8006af24>][<80043140>][<8004c0d0>]
Code: 3402ffff 10620002 3404ffff <90640004> 8fbf0010 00801021 03e00008 27bd 0018 3c02c00f
Kernel panic - not syncing: Fatal exception in interrupt
Rebooting in 1 seconds..
Czy ktoś pomoże?
