Anylogic - wyłącza się po uruchomieniu, błąd EXCEPTION_ACCESS_VIOLATION
wislaa19 23 Paź 2011 11:57 1710 0
  • #1 10056324
    wislaa19
    Witam, mam pewien problem z programem Anylogic (program do tworzenia symulacji), otóż gdy go uruchamiam po władowaniu się aplikacji zaraz się zamyka i w folderze Anylogica wyskakuje plik tekstowy z opisanym błędem:
    # A fatal error has been detected by the Java Runtime Environment:
    # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6904b03e, pid=4004, tid=1864
    # JRE version: 6.0_25-b06
    # Java VM: Java HotSpot(TM) Client VM (20.0-b11 mixed mode windows-x86 )
    # Problematic frame:
    # C [sisgl770.dll+0x4b03e]
    # If you would like to submit a bug report, please visit:
    # http://java.sun.com/webapps/bugreport/crash.jsp
    # The crash happened outside the Java Virtual Machine in native code.
    # See problematic frame for where to report the bug.
    --------------- T H R E A D ---------------
    Current thread (0x5409f400): JavaThread "AWT-EventQueue-0" [_thread_in_native, id=1864, stack(0x58e30000,0x58f30000)]
    siginfo: ExceptionCode=0xc0000005, reading address 0x00000018
    Registers:
    EAX=0x58fe195c, EBX=0x00000068, ECX=0x58fe1978, EDX=0x00000004
    ESP=0x58f2f55c, EBP=0x58f2f564, ESI=0x58fe18c0, EDI=0x00000000
    EIP=0x6904b03e, EFLAGS=0x00210297
    Top of Stack: (sp=0x58f2f55c)
    0x58f2f55c: 00000000 58fe195c 58f2f598 6904a2c0
    0x58f2f56c: 00000017 00000068 00000000 58fe195c
    0x58f2f57c: 00000001 00000068 00000017 00000000
    0x58f2f58c: 58fe18c0 58fe1da8 00000004 58f2f5d8
    0x58f2f59c: 69046261 00000017 00000068 00000000
    0x58f2f5ac: 58fe18c0 58fe18c0 58f61780 6904647b
    0x58f2f5bc: 003d7858 6904959b 00010000 00000000
    0x58f2f5cc: 00157928 00000000 000502a6 58f2f604
    Instructions: (pc=0x6904b03e)
    0x6904b01e: f4 01 00 00 89 88 54 03 00 00 b0 01 c2 14 00 55
    0x6904b02e: 8b ec 8b 45 14 56 8b b0 30 04 00 00 57 8b 79 44
    0x6904b03e: 83 7f 18 00 75 46 a1 c0 0f 3b 69 8b 08 6a 00 8d
    0x6904b04e: 55 14 52 6a 00 50 ff 51 10 85 c0 74 07 b9 b8 5e
    Register to memory mapping:
    EAX=0x58fe195c is an unknown value
    EBX=0x00000068 is an unknown value
    ECX=0x58fe1978 is an unknown value
    EDX=0x00000004 is an unknown value
    ESP=0x58f2f55c is pointing into the stack for thread: 0x5409f400
    EBP=0x58f2f564 is pointing into the stack for thread: 0x5409f400
    ESI=0x58fe18c0 is an unknown value
    EDI=0x00000000 is an unknown value
    Stack: [0x58e30000,0x58f30000], sp=0x58f2f55c, free space=1021k
    Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
    C [sisgl770.dll+0x4a2c0]
    C [sisgl770.dll+0x46261]
    C [OPENGL32.DLL+0x19aad] wglSwapLayerBuffers+0x758
    C [OPENGL32.DLL+0x19c5f] wglMakeCurrent+0x8a
    C [jogl.dll+0x1beb] Java_com_sun_opengl_impl_windows_WGL_wglMakeCurrent__JJ+0x18
    j com.sun.opengl.impl.windows.WGL.wglMakeCurrent(JJ)Z+0
    j com.sun.opengl.impl.windows.WindowsGLContext.makeCurrentImpl()I+135
    j com.sun.opengl.impl.GLContextImpl.makeCurrent()I+56
    j com.sun.opengl.impl.windows.WindowsGLDrawableFactory$1.run()V+31
    j java.awt.event.InvocationEvent.dispatch()V+11
    j java.awt.EventQueue.dispatchEventImpl(Ljava/awt/AWTEvent;Ljava/lang/Object;)V+21
    j java.awt.EventQueue.access$000(Ljava/awt/EventQueue;Ljava/awt/AWTEvent;Ljava/lang/Object;)V+3
    j java.awt.EventQueue$1.run()Ljava/lang/Void;+12
    j java.awt.EventQueue$1.run()Ljava/lang/Object;+1
    v ~StubRoutines::call_stub
    V [jvm.dll+0xfad0b]
    V [jvm.dll+0x18c241]
    V [jvm.dll+0xfad8d]
    V [jvm.dll+0xbb634]
    C [java.dll+0x102f] Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2Ljava_security_AccessControlContext_2+0x17
    j java.security.AccessControlContext$1.doIntersectionPrivilege(Ljava/security/PrivilegedAction;Ljava/security/AccessControlContext;Ljava/security/AccessControlContext;)Ljava/lang/Object;+28
    j java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V+46
    j java.awt.EventDispatchThread.pumpOneEventForFilters(I)Z+204
    j java.awt.EventDispatchThread.pumpEventsForFilter(ILjava/awt/Conditional;Ljava/awt/EventFilter;)V+30
    j java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/awt/Conditional;Ljava/awt/Component;)V+11
    j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Conditional;)V+4
    j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditional;)V+3
    j java.awt.EventDispatchThread.run()V+9
    V [jvm.dll+0xfad0b]
    V [jvm.dll+0xfaeb1]
    V [jvm.dll+0xfaf0b]
    V [jvm.dll+0xb5549]
    V [jvm.dll+0x118f44]
    V [jvm.dll+0x140a8c]
    C [MSVCR71.dll+0x9565] endthreadex+0xa0
    C [kernel32.dll+0xb713] GetModuleFileNameA+0x1b4
    Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
    j java.security.AccessController.doPrivileged(Ljava/security/PrivilegedAction;Ljava/security/AccessControlContext;)Ljava/lang/Object;+0
    --------------- P R O C E S S ---------------
    Java Threads: ( => current thread )
    =>0x5409f400 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=1864, stack(0x58e30000,0x58f30000)]
    0x53963c00 JavaThread "Worker-3" [_thread_blocked, id=996, stack(0x552d0000,0x553d0000)]
    0x54308400 JavaThread "AWT-Shutdown" [_thread_blocked, id=1772, stack(0x558f0000,0x559f0000)]
    0x52f67800 JavaThread "Autosave" daemon [_thread_blocked, id=944, stack(0x58d10000,0x58e10000)]
    0x541c9800 JavaThread "Worker-2" [_thread_blocked, id=360, stack(0x554f0000,0x555f0000)]
    0x542b2400 JavaThread "Java indexing" daemon [_thread_blocked, id=432, stack(0x557f0000,0x558f0000)]
    0x540ca400 JavaThread "Worker-1" [_thread_blocked, id=428, stack(0x556f0000,0x557f0000)]
    0x5407c400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=376, stack(0x555f0000,0x556f0000)]
    0x54253400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=392, stack(0x553f0000,0x554f0000)]
    0x53969800 JavaThread "Worker-0" [_thread_in_native, id=192, stack(0x54d20000,0x54e20000)]
    0x54051800 JavaThread "Worker-JM" [_thread_blocked, id=2044, stack(0x54c20000,0x54d20000)]
    0x543fc000 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=4092, stack(0x53e90000,0x53f90000)]
    0x53884400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=4068, stack(0x53d90000,0x53e90000)]
    0x5387c400 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=4064, stack(0x53c90000,0x53d90000)]
    0x53897400 JavaThread "State Saver" [_thread_blocked, id=4060, stack(0x53b90000,0x53c90000)]
    0x53879400 JavaThread "Framework Active Thread" [_thread_blocked, id=4056, stack(0x53a90000,0x53b90000)]
    0x52f30400 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4032, stack(0x535a0000,0x536a0000)]
    0x52f2d800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4028, stack(0x534a0000,0x535a0000)]
    0x52f28c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=4024, stack(0x533a0000,0x534a0000)]
    0x52f27800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4020, stack(0x532a0000,0x533a0000)]
    0x52f19800 JavaThread "Finalizer" daemon [_thread_blocked, id=3560, stack(0x531a0000,0x532a0000)]
    0x52f14c00 JavaThread "Reference Handler" daemon [_thread_blocked, id=4016, stack(0x530a0000,0x531a0000)]
    0x003e6400 JavaThread "main" [_thread_in_native, id=4008, stack(0x00030000,0x00130000)]
    Other Threads:
    0x52f11000 VMThread [stack: 0x52fa0000,0x530a0000] [id=4012]
    0x52f3b400 WatcherThread [stack: 0x536a0000,0x537a0000] [id=3668]
    VM state:not at safepoint (normal execution)
    VM Mutex/Monitor currently owned by a thread: None
    Heap
    def new generation total 15104K, used 1755K [0x02a20000, 0x03a80000, 0x17f70000)
    eden space 13440K, 13% used [0x02a20000, 0x02bd6d28, 0x03740000)
    from space 1664K, 0% used [0x038e0000, 0x038e0000, 0x03a80000)
    to space 1664K, 0% used [0x03740000, 0x03740000, 0x038e0000)
    tenured generation total 33416K, used 19333K [0x17f70000, 0x1a012000, 0x42a20000)
    the space 33416K, 57% used [0x17f70000, 0x192517c8, 0x19251800, 0x1a012000)
    compacting perm gen total 35840K, used 35756K [0x42a20000, 0x44d20000, 0x52a20000)
    the space 35840K, 99% used [0x42a20000, 0x44d0b118, 0x44d0b200, 0x44d20000)
    No shared spaces configured.
    Code Cache [0x009a0000, 0x00d40000, 0x029a0000)
    total_blobs=1855 nmethods=1536 adapters=254 free_code_cache=29781568 largest_free_block=192
    Dynamic libraries:
    0x00400000 - 0x0040d000 C:\Program Files\AnyLogic 6 University\AnyLogic.exe
    0x7c900000 - 0x7c9b1000 C:\WINDOWS\system32\ntdll.dll
    0x7c800000 - 0x7c8fd000 C:\WINDOWS\system32\kernel32.dll
    0x7e360000 - 0x7e3f1000 C:\WINDOWS\system32\USER32.dll
    0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll
    0x5d520000 - 0x5d5ba000 C:\WINDOWS\system32\COMCTL32.dll
    0x77dc0000 - 0x77e6c000 C:\WINDOWS\system32\ADVAPI32.dll
    0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll
    0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
    0x77c00000 - 0x77c58000 C:\WINDOWS\system32\MSVCRT.dll
    0x72000000 - 0x7200d000 C:\Program Files\AnyLogic 6 University\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502\eclipse_1406.dll
    0x77bf0000 - 0x77bf8000 C:\WINDOWS\system32\VERSION.dll
    0x6d8a0000 - 0x6db4f000 C:\Program Files\AnyLogic 6 University\jre\bin\client\jvm.dll
    0x76b20000 - 0x76b4e000 C:\WINDOWS\system32\WINMM.dll
    0x7c340000 - 0x7c396000 C:\WINDOWS\system32\MSVCR71.dll
    0x6d850000 - 0x6d85c000 C:\Program Files\AnyLogic 6 University\jre\bin\verify.dll
    0x6d3d0000 - 0x6d3ef000 C:\Program Files\AnyLogic 6 University\jre\bin\java.dll
    0x76be0000 - 0x76beb000 C:\WINDOWS\system32\PSAPI.DLL
    0x6d890000 - 0x6d89f000 C:\Program Files\AnyLogic 6 University\jre\bin\zip.dll
    0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
    0x769a0000 - 0x76a55000 C:\WINDOWS\system32\USERENV.dll
    0x6ff40000 - 0x6ff95000 C:\WINDOWS\system32\netapi32.dll
    0x6d6b0000 - 0x6d6c3000 C:\Program Files\AnyLogic 6 University\jre\bin\net.dll
    0x71a50000 - 0x71a67000 C:\WINDOWS\system32\WS2_32.dll
    0x71a40000 - 0x71a48000 C:\WINDOWS\system32\WS2HELP.dll
    0x719f0000 - 0x71a30000 C:\WINDOWS\System32\mswsock.dll
    0x76f10000 - 0x76f37000 C:\WINDOWS\system32\DNSAPI.dll
    0x76fa0000 - 0x76fa8000 C:\WINDOWS\System32\winrnr.dll
    0x76f50000 - 0x76f7d000 C:\WINDOWS\system32\WLDAP32.dll
    0x76fb0000 - 0x76fb6000 C:\WINDOWS\system32\rasadhlp.dll
    0x746d0000 - 0x7471c000 C:\WINDOWS\system32\MSCTF.dll
    0x6d6d0000 - 0x6d6d9000 C:\Program Files\AnyLogic 6 University\jre\bin\nio.dll
    0x77110000 - 0x7719b000 C:\WINDOWS\system32\OLEAUT32.DLL
    0x774d0000 - 0x7760d000 C:\WINDOWS\system32\ole32.dll
    0x66780000 - 0x667d8000 C:\WINDOWS\system32\hnetcfg.dll
    0x71a30000 - 0x71a38000 C:\WINDOWS\System32\wshtcpip.dll
    0x54e20000 - 0x54e8e000 C:\Documents and Settings\Wisłocki\.AnyLogicUniversity\Config\org.eclipse.osgi\bundles\181\1\.cp\swt-win32-3735.dll
    0x76380000 - 0x763c9000 C:\WINDOWS\system32\comdlg32.dll
    0x773c0000 - 0x774c3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\COMCTL32.dll
    0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
    0x7c9c0000 - 0x7d1de000 C:\WINDOWS\system32\SHELL32.dll
    0x76360000 - 0x7637d000 C:\WINDOWS\system32\IMM32.dll
    0x74d40000 - 0x74dab000 C:\WINDOWS\system32\USP10.dll
    0x771a0000 - 0x7724b000 C:\WINDOWS\system32\WININET.dll
    0x77a70000 - 0x77b06000 C:\WINDOWS\system32\CRYPT32.dll
    0x77b10000 - 0x77b22000 C:\WINDOWS\system32\MSASN1.dll
    0x54ef0000 - 0x54f0d000 C:\Documents and Settings\Wisłocki\.AnyLogicUniversity\Config\org.eclipse.osgi\bundles\181\1\.cp\swt-gdip-win32-3735.dll
    0x54f90000 - 0x55136000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.5512_x-ww_dfb54e0c\gdiplus.dll
    0x5b1d0000 - 0x5b208000 C:\WINDOWS\system32\uxtheme.dll
    0x6d0b0000 - 0x6d1fb000 C:\Program Files\AnyLogic 6 University\jre\bin\awt.dll
    0x72f90000 - 0x72fb6000 C:\WINDOWS\system32\WINSPOOL.DRV
    0x6d2e0000 - 0x6d32f000 C:\Program Files\AnyLogic 6 University\jre\bin\fontmanager.dll
    0x559f0000 - 0x559fe000 C:\Documents and Settings\Wisłocki\.AnyLogicUniversity\Config\org.eclipse.osgi\bundles\51\1\.cp\os\win32\x86\localfile_1_0_0.dll
    0x74c30000 - 0x74c5c000 C:\WINDOWS\system32\oleacc.dll
    0x76050000 - 0x760b5000 C:\WINDOWS\system32\MSVCP60.dll
    0x55c90000 - 0x55f62000 C:\WINDOWS\system32\xpsp2res.dll
    0x76350000 - 0x76355000 C:\WINDOWS\system32\msimg32.dll
    0x55250000 - 0x552c6000 C:\Program Files\AnyLogic 6 University\plugins\org.j3d.opengl.swt.win32.x86_0.7.0\jogl.dll
    0x5f190000 - 0x5f25c000 C:\WINDOWS\system32\OPENGL32.DLL
    0x5c8f0000 - 0x5c911000 C:\WINDOWS\system32\GLU32.dll
    0x736f0000 - 0x7373b000 C:\WINDOWS\system32\DDRAW.dll
    0x73b50000 - 0x73b56000 C:\WINDOWS\system32\DCIMAN32.dll
    0x69000000 - 0x6940e000 C:\WINDOWS\system32\sisgl770.dll
    VM Arguments:
    jvm_args: -XX:MaxPermSize=256m -Xmx1024M -vm C:\Program Files\AnyLogic 6 University\jre\bin\javaw
    java_command: <unknown>
    Launcher Type: generic
    Environment Variables:
    PATH=C:/Program Files/AnyLogic 6 University/jre/bin/client;C:/Program Files/AnyLogic 6 University/jre/bin;C:/Program Files/AnyLogic 6 University/jre/lib/i386;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\AnyLogic 6 University;
    USERNAME=Wisłocki
    OS=Windows_NT
    PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 13, GenuineIntel
    --------------- S Y S T E M ---------------
    OS: Windows XP Build 2600 Dodatek Service Pack 3
    CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
    Memory: 4k page, physical 1045604k(244916k free), swap 2517264k(1810700k free)
    vm_info: Java HotSpot(TM) Client VM (20.0-b11) for windows-x86 JRE (1.6.0_25-b06), built on Apr 14 2011 01:04:32 by "java_re" with MS VC++ 7.1 (VS2003)
    time: Sun Oct 23 11:07:01 2011
    elapsed time: 18 seconds
    Nie mam pojęcia o co tutaj chodzi, bardzo proszę o jakąkolwiek pomoc, gdyż potrzebuję ten program do stworzenia symulacji.
