Witam wszystkich.
Kupilem na allegro laptopa dell d420.
Mam problem , gdyż na poczatku (przy podlaczonym kablu do ladowania)
przy starcie systemu pojawia sie komunikat:
["The AC power adapter type cannot be determined. Your system will operate slower and the battery will not charge. Please connect a Dell 90W AC adapter or higher for best system operation."]
Jest to oryginalna ladowarka z AC (oczywiscie odpowiednia do modelu)
Wyczytalem ze ludzie maja ten sam problem z orginalnym chargerem i jest rozwiazanie.
Pewna osoba na jakims angielskim forum napisala:
Rozumiem tylko tyle ze obwiazal czyms ten kabel , przy koncu?
Jesli ktos jest w stanie mi pomoc to z gory dziekuje.
Cytat:I had the same problem, My other Dell charger would work fine but the original one that came with this laptop would always throw an error message indicating that the adapter wasn't recognized. None of the suggestions on any of the forums worked.
So I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it on for a few seconds - And now the laptop recognizes the adapter, charges and works fine! If you push the power pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the wires near the pin of the power chord, or with the adapter inside the laptop.
Try it, worked for me!
