Nokia 6303 RM-443 - czerwony napis CONTACT SERVICE po włączeniu
sewer29 13 Lip 2012 10:25 2547 9
  • #1 11100681
    sewer29
    Ocena: 40
    Nokia 6303 RM-443 po włączeniu wyświetla na moment czerwony napis CONTACT SERVICE i gaśnie,zczytuje się normalnie ,kontakty odzyskałem,phoenix też fleszuje ją z sukcesem.W środku jak nowa żadnych śladów zalania itp.
  • #2 11100710
    jayu0
    Poziom 37  
    Ocena: 141
    Self test, analiza superdongle.
  • #3 11100712
    FIsiu_
    Ocena: 295
    Albo uwalone SECURITY albo CPU+FLASH reball/wymiana.
  • #4 11100990
    sewer29
    Ocena: 40
    analixa securiti cyclonem
    Reading Security Block...
    Security block OK and saved to "RM-443_xxxxxxxxxxxxxxxxxxx_2012-07-13_114917.SecurityBlock.PM"
    Step 1 : Testing SIMLOCK
    SIMLOCK SEFLTEST PASSED OK!
    Step 2 : Testing SECURITY
    -- SECURITY PROBLEM --
    Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
    To repair it, simply slick "SX4 Authorization / SD Repair" button.
    After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
    Additionaly, Checking HWC/CCC Certs...
    Booting CMT...
    CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
    CMT_EM_ASIC_ID: 00000295
    CMT_EM_ASIC_ID: 00000B22
    CMT_PUBLIC_ID: 2A8001015C047E56AEFDF229D987A2A30CC7BD90
    CMT_ASIC_MODE_ID: 00
    CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT_BOOT_ROM_CRC: 273F6D55
    CMT_SECURE_ROM_CRC: DFAAF68F
    CMT Ready!
    Searching for BootCode: DualLine 32Bit
    RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
    Flashbus Write baud set to 1.0Mbits
    Flashbus Read baud set to 98Kbits
    Using OLD BB5 FLASHING PROTOCOL
    If software STUCK HERE with box TX LED lit, that means:
    1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
    2. Your cable is not TX2 Enabled!
    3. Transmission error occured, try again
    In either cases, you need to reconnect your box from USB.
    FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
    FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
    FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
    Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
    FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
    RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
    Flashbus Write baud set to 2.0Mbits
    Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
    Box TX2 Data Pin set to: Service Pin 3
    Box VPP disabled
    Internal CMT Phone VPP Enabled
    PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2
    APE Subsystem Not Found
    Flashbus Write baud set to 5.0Mbits
    HWC Looks OK!
    CCC Looks OK!
    Restarting MCU...
    Step 3 : Analyzing Security Block
    "2A8001015C047E56AEFDF229D987A2A30CC7BD90.C0006FBC" Exists, That is good...
    Checking SUPERDONGLE...
    SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
    Checking SIMLOCK...
    Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
    Checking MCU&DSP TIMESTAMPS...
    MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
    Checking CMLA KEYS...
    CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
    Checking ECC KEYS...
    ECC KEYS FOUND AND CHECKSUM OK! PASSED!
    Checking DIV KEYS...
    DIV KEYS FOUND AND CHECKSUM OK! PASSED!
    Analyze finished!
    selftest
    Selftests to proceed: 30
    Passed ST_EAR_DATA_LOOP_TEST
    Passed ST_SIM_CLK_LOOP_TEST
    Passed ST_SIM_IO_CTRL_LOOP_TEST
    Passed ST_SLEEP_X_LOOP_TEST
    Passed ST_UEM_CBUS_IF_TEST
    Failed ST_KEYBOARD_STUCK_TEST
    Passed ST_CAMERA_IF_TEST
    Passed ST_LCD_TEST
    Passed ST_LPRF_IF_TEST
    Passed ST_LPRF_AUDIO_LINES_TEST
    Passed ST_CURRENT_CONS_TEST
    Passed ST_RADIO_TEST
    Passed ST_BACKLIGHT_TEST
    Passed ST_SIM_LOCK_TEST
    Failed ST_SECURITY_TEST
    Passed ST_BT_WAKEUP_TEST
    Passed ST_HOOKINT_TEST
    Passed ST_TAHVOINT_TEST
    Passed ST_BTEMP_TEST
    Passed ST_AMB_LIGHT_SENSOR_TEST
    Passed ST_IIC_TEST
    Passed ST_LED_CONTROLLER_TEST
    Passed ST_CDSP_SLEEPCLK_FREQ_TEST
    Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST
    Passed ST_CDSP_RF_BB_IF_TEST
    Passed ST_CDSP_GSM_TX_POWER_TEST
    Failed ST_CDSP_RF_SUPPLY_TEST
    Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
    Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST
    Passed ST_CDSP_RX_IQ_TEST
    Selftests done, Tests total: 30, Tests passed: 27, Tests not passed: 3
  • #5 11101053
    FIsiu_
    Ocena: 295
    Jak widac z loga do naprawy SECURITY :D
  • #6 11101061
    jayu0
    Poziom 37  
    Ocena: 141
    Tu masz problem.
  • #7 11101106
    sewer29
    Ocena: 40
    Jak mogło dojsc do uszkodzenia,tel.nie posiadał locka.
  • #8 11101133
    FIsiu_
    Ocena: 295
    Czasami pada sam z siebie, tutaj powinno pomóc naprawa superdongle, sx4 i PM :D
  • #9 11101140
    jayu0
    Poziom 37  
    Ocena: 141
    Mozna dodac ze obszar security jest do raprawy w kazdej nokii na kazdym sl. Gorzej z simlock failed.
  • #10 11101226
    sewer29
    Ocena: 40
    Cyclon postawił dzięki Panowie.
Nokia 6303 RM-443 wyświetla czerwony napis "CONTACT SERVICE" po włączeniu, co wskazuje na problem z bezpieczeństwem. Użytkownik odzyskał kontakty i zaktualizował oprogramowanie za pomocą Phoenix, jednak telefon nadal nie działa prawidłowo. W odpowiedziach zasugerowano, że problem może wynikać z uszkodzenia obszaru Superdongle lub błędu w testach bezpieczeństwa. Zalecane rozwiązania obejmują naprawę Superdongle oraz użycie SX4 Authorization/SD Repair, a także zapisanie pliku PM z odpowiednimi polami. Użytkownik potwierdził, że Cyclon pomógł w naprawie.
