schemat - Unitra Fonica Gramofon Mister hit Typ WG-400
mimiluna 23 Sty 2013 12:22 10047 10
  • #1 11829020
    mimiluna
    Hi, I hope I am not mistaken the place of issue, but if so, please excuse me .. I UNITRA FONICA Mr Hit GRAMOFON ZE WZMACNIACZEM TYP WG -400. Very little is heard, barely audible. Want to fix it and that I need the scheme. Please if someone can help me.
    Thank you
  • #3 11829150
    dood
    Ocena: 6
    Mimiluna, have you checked the cartridge? It's crystal type and they loose their properties when they get older.
  • #4 11829179
    mimiluna
    Thanks for the info, but my turntable is not so! Did not hit 71, but Mr. Hit
    I will write all data: UNITRA FONICA Mister Hit GRAMOFON ZE WZMACNIACZEM TYP WG-400
    WT-71/T4-264-063
    ZASILANIE 220V~50Hz
    It is different from what you sent me
  • #5 11829236
    thereminator
    Warunkowo odblokowany
    Ocena: 655
    There was no other WG-400 Mister Hit but this one.
  • #6 11829285
    mimiluna
    I will try later to put a picture
    Hello again from the sample which did establish that - transformer works well motora.No heard from the speaker hum (50 Hz)! And when you touch the needle - do not hear anything. Does anyone know what could be the problem?
  • #7 11832506
    Futrzaczek
    Ocena: 522
    Check cables between the needle and amplifier. Maybe the amplifier is broken down?
    Here is the schematic: http://www.oldradio.pl/foto_schematy/sch00268.jpg
    Make sure that voltages and currents are similar with ones shown in the schematic. Try to touch the base of T101 with your finger - a loud noise should be audible.
    PS. Is your loudspeaker fully functional? Is it connected to the amplifier correctly?
    Konto firmowe:
    F-TECH Michał Kurzela
    Zacisze 20B, Serock, 05-140 | Strona WWW: https://elektronika.top/
  • #8 11832776
    thereminator
    Ocena: 655
    UF50 is a stereo catridge. You can connect it from DIN output into stereo amplifier.
    Pin 3 = channel L , pin 5 = channel R, pin 2 = GND.
  • #9 11834582
    mimiluna
    Hello! Thanks for all the advice. Discovered the problem - the cartridge not work and should therefore be replaced. On the one hand it is good that we found the problem, but on the other - now we can not find a new one. Does anyone know where I can find, order and buy?
    the cartridge unitra UF50
  • #10 11834810
    dood
    Ocena: 6
    They are almost in continuous sale on allegro.pl (polish online auction site). You just have to find the seller who will agree send it abroad.
  • #11 11834985
    mimiluna
    OK,thank you :)
✨ Użytkownik zgłosił problem z gramofonem UNITRA FONICA Mister Hit Typ WG-400, który wydaje bardzo cichy dźwięk. Po kilku odpowiedziach, zidentyfikowano, że problem może leżeć w wkładce, która jest typu UF50 i może wymagać wymiany. Użytkownik otrzymał schemat urządzenia oraz porady dotyczące sprawdzenia połączeń kablowych i działania wzmacniacza. W końcu potwierdzono, że wkładka nie działa i użytkownik poszukuje miejsca zakupu nowej wkładki UF50, która jest dostępna na polskim portalu aukcyjnym allegro.pl.
