WD3200LPVT - Nieudane zgranie danych z dysku przez USB, różne partycje
Darektbg 04 Mar 2013 18:13 1245 0
  • #1 12019827
    Darektbg
    Ocena: 21
    Dysk był używany w starym laptopie, w którym padła płyta główna. Zakup nowego laptopa i próba zgrania danych ze starego dysku przez USB kończy się fiaskiem. Na dysku było kilka partycji(NTFS, FAT32, ext4).
    [  760.715384] usb 1-1.2: new high-speed USB device number 25 using ehci_hcd
    [  760.801617] usb 1-1.2: New USB device found, idVendor=152d, idProduct=2338
    [  760.801623] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
    [  760.801626] usb 1-1.2: Product: USB to ATA/ATAPI bridge
    [  760.801629] usb 1-1.2: Manufacturer: JMicron
    [  760.801632] usb 1-1.2: SerialNumber: 000001D91871
    [  760.803517] scsi20 : usb-storage 1-1.2:1.0
    [  761.803567] scsi 20:0:0:0: Direct-Access     WDC WD32 00LPVT-00G33T0        PQ: 0 ANSI: 2 CCS
    [  761.805478] sd 20:0:0:0: Attached scsi generic sg2 type 0
    [  761.805840] sd 20:0:0:0: [sdb] 78142806 4096-byte logical blocks: (320 GB/298 GiB)
    [  761.806585] sd 20:0:0:0: [sdb] Write Protect is off
    [  761.806594] sd 20:0:0:0: [sdb] Mode Sense: 28 00 00 00
    [  761.807333] sd 20:0:0:0: [sdb] No Caching mode page present
    [  761.807341] sd 20:0:0:0: [sdb] Assuming drive cache: write through
    [  761.808208] sd 20:0:0:0: [sdb] 78142806 4096-byte logical blocks: (320 GB/298 GiB)
    [  761.809707] sd 20:0:0:0: [sdb] No Caching mode page present
    [  761.809713] sd 20:0:0:0: [sdb] Assuming drive cache: write through
    [  763.486674]  sdb: sdb1 sdb2 < >
    [  763.486679] sdb: partition table partially beyond EOD, enabling native capacity
    [  763.487529] sd 20:0:0:0: [sdb] 78142806 4096-byte logical blocks: (320 GB/298 GiB)
    [  763.489110] sd 20:0:0:0: [sdb] No Caching mode page present
    [  763.489118] sd 20:0:0:0: [sdb] Assuming drive cache: write through
    [  763.489694]  sdb: sdb1 sdb2 < >
    [  763.489699] sdb: partition table partially beyond EOD, truncated
    [  763.489707] sdb: p1 size 1638402696 extends beyond EOD, truncated
    [  763.489971] sdb: p2 start 1638403688 is beyond EOD, truncated
    [  763.491333] sd 20:0:0:0: [sdb] 78142806 4096-byte logical blocks: (320 GB/298 GiB)
    [  763.492822] sd 20:0:0:0: [sdb] No Caching mode page present
    [  763.492827] sd 20:0:0:0: [sdb] Assuming drive cache: write through
    [  763.492831] sd 20:0:0:0: [sdb] Attached SCSI disk
    [root@localhost liveuser]# lsusb
    Bus 001 Device 025: ID 152d:2338 JMicron Technology Corp. / JMicron USA Technology Corp. JM20337 Hi-Speed USB to SATA & PATA Combo Bridge
    [root@localhost liveuser]# fdisk -l /dev/sdb
    fdisk: unable to seek on /dev/sdb: Invalid argument
    [root@localhost liveuser]# mount /dev/sdb1 ~/1
    mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
           missing codepage or helper program, or other error
           In some cases useful info is found in syslog - try
           dmesg | tail or so
    Dodam, że przy pomocy tej samej przejściówki zgrałem dane z innego dysku 2,5" SATA HITACHI 80GB
