Wybór karty graficznej low profile do HP Pavilion p6610pl z Intel G41 Express
begded 30 Wrz 2013 23:28 2013 5
  • #1 12795912
    begded
    Witam. Posiadam tego oto "demona predkosci" Hp Pavilion p6610pl.
    Motherboard
    H-I41-uATX (Eton/EtonL)
    Manufacturer: Foxconn
    Form factor: microATX - 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
    Chipset: Intel G41 Express
    Memory sockets: 2 x DDR3
    Front side bus speeds: 1333/1066/800 MHz
    Processor socket: 775
    Expansion Slots:
    1 PCI Express x16 slot for graphics card
    2 PCI Express x1 slots
    1 PCI slot
    1 PCI Express x1 minicard slot
    Processor
    Intel Core 2 Duo E7500
    Figure 2: Intel Core 2 Duo logo
    Image of Intel logo
    Operating speed: Up to 2.93 GHz
    Number of cores: 2
    Socket: 775
    Processor upgrade information
    TDP: Varies by processor
    Motherboard supports the following processor upgrades:
    Core 2 Quad Q8xx0/Q9xx0 (Yorkfield core) (95W)
    Core 2 Duo E8xx0 (Wolfdale core) (65W)
    Core 2 Duo E7xx0 (Wolfdale core) (65W)
    Pentium Dual Core E5xx0 (Wolfdale core) (65W)
    Celeron Dual Core E1xx0 (Conroe core) (65W)
    Celeron 4xx series (Conroe core) (35W)
    Memory
    3 GB
    Amount: 3 GB
    Speed: PC3-10600 MB/sec (messages as PC3-6400)
    Type: DDR3-1333
    Memory upgrade information
    Supports DDR3 DIMMs only
    Dual channel memory architecture
    Two DDR3 DIMM (240-pin) sockets
    DIMM types:
    PC3-10600 (DDR3-1333)
    PC3-8500 (DDR3-1066)
    PC3-6400 (DDR3-800)
    Non-ECC memory only, unbuffered
    Supports 2 GB DDR3 DIMMs
    Supports up to 4 GB on 64-bit PCs
    Maximum memory only if using 2GB DDR3 DIMM modules
    NOTE: 32-bit PCs cannot address a full 4.0 GB of memory
    Video graphics
    NVIDIA GeForce G210
    Figure 3: Video card
    Image of video card
    Figure 4: Ports
    1 - VGA
    2 - HDMI
    3 - DVI-I (single-link or dual-link)
    Image of video card bracket showing ports
    * VGA using included DVI-to-VGA adapter
    Interface: PCI Express x16
    Maximum resolution:
    HDMI TV resolution: up to 1080p*
    HDMI PC resolution: 2048x1536 at 75 Hz
    DVI TV resolution: up to 1080p*
    DVI PC resolution (dual-link): 2048x1536 at 75 Hz
    DVI PC resolution (single-link): 1920x1200 at 60 Hz
    VGA resolution: 2048x1536 at 75 Hz
    * Use NVIDIA software to optimize display
    512 MB onboard memory
    Supports two displays at the same time*
    Two of the three ports are usable at any one time
    Supports HDCP
    Hard drive
    500 GB
    Interface: SATA
    Rotational Speed: 7200 RPM
    Chcialbym prosic o doradzenie i wyjasnienie:
    1. w zakupie karty graficznej low profile (czy dostane cos lepszego od tego co mam?)
    2. dobrego zasilacza min 400w
    3.. Czy bedzie zauwazalna roznica jezelie wymienie jedna 1gb kosc ram na 2gb
    4. Jak podkreci system w tym biosie Wybór karty graficznej low profile do HP Pavilion p6610pl z Intel G41 Express Jesli sie nie da to czy moge go jakos usunac i wgrac inny jezeli tak to prosilbym o wytlumaczenie.
  • #2 12796235
    kozak69
    Ocena: 76
    w HPekach nie ma możliwosći podkręcania sprzętu z tego co wiem,jedynie programami można
  • #3 12796425
    andrzej55
    Poziom 37  
    Ocena: 375
    Z nowych low profile można kupić HD6570 1GB DDR3 za ok.200zł, HD6670 GDDR5 -300zł, i HD7750 za 370zł. Wszystkie dużo mocniejsze od twojej.
  • #4 12798772
    begded
    Dziekuje za doradzenie w sprawie kart graficznych. Sprawe ramu oraz zasilacza zalatwilem.
    Zostaje pytanie co z tym biosem bo zalezy mi na tym pod kreceniu ?! Czy probowac zainstalowac nowy bios czy bawic sie tymi programami, jezeli zostalbym przy pod kreceniu przez program to czy znacznie jest ono gorsze niz przez biosa i na czym polega roznica.
  • #5 12800251
    wariato
    Ocena: 840
    A skąd weźmiesz nowy Bios ? Musiałbyś szukać jakichś przerabianych z możliwością ruszenia FSB. Na tym nie da sie podkręcać bo to płyty OEM dla HP.
  • #6 12802666
    begded
    Sadzilem ze mozna po prostu w grac swojego biosa w plyte glowna. W takim razie dziekuje za pomoc i prosze o zamkniecie tematu.
