ATI Radeon HD 4670 - Windows 8.1 sterownik działa tylko (microsoft corporation)
badboy23 21 Sie 2014 16:50 1497 0
  • #1 13896134
    badboy23
    Ocena: 49
    Witam, posiadam w Kartę grafiki ATI Radeon HD 4670 i mam problem zainstalowaniem sterowników pod Windows 8.1 innych niż (microsoft corporation - wddm v1.1). potrzebuję sterownik z działającym OpenGL.
    Instalowałem te: 13.1 jak i najnowsze ale nie pomaga wyskakuje mi taki komunikat w ninecraft.
    Spoiler:
    Bad video card drivers!
    Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
    This can usually be fixed by updating the video card drivers.
    --- BEGIN ERROR REPORT 7fe0271 --------
    Generated 21.08.14 16:01
    -- System Details --
    Details:
    Minecraft Version: 1.5.2
    Operating System: Windows 8.1 (x86) version 6.3
    Java Version: 1.7.0_67, Oracle Corporation
    Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
    Memory: 431377056 bytes (411 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
    JVM Flags: 2 total; -Xms512m -Xmx1024m
    AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
    Suspicious classes: No suspicious classes found.
    IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
    LWJGL: 2.4.2
    OpenGL: ~~ERROR~~ NullPointerException: null
    Is Modded: Probably not. Jar signature remains and client brand is untouched.
    Type: Client (map_client.txt)
    Texture Pack: Default
    Profiler Position: N/A (disabled)
    Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
    org.lwjgl.LWJGLException: Pixel format not accelerated
    at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
    at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
    at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
    at org.lwjgl.opengl.Display.createWindow(Display.java:311)
    at org.lwjgl.opengl.Display.create(Display.java:856)
    at org.lwjgl.opengl.Display.create(Display.java:784)
    at org.lwjgl.opengl.Display.create(Display.java:765)
    at net.minecraft.client.Minecraft.a(SourceFile:235)
    at avv.a(SourceFile:56)
    at net.minecraft.client.Minecraft.run(SourceFile:507)
    at java.lang.Thread.run(Unknown Source)
    --- END ERROR REPORT 1385c6d1 ----------
