Czy dysk Toshiba MK5075GSX jest jeszcze sprawny według raportu S.M.A.R.T?
Qabx 22 Sie 2014 13:14 1359 3
  • #1 13898216
    Qabx
    Powiedzcie mi proszę, czy ten dysk nadaje się jeszcze do użytku.
    Raport tekstowy:
    Spoiler:
    smartctl 6.1 2013-03-16 r3800 [i686-linux-3.8.10-pmagic] (local build)
    Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
    === START OF INFORMATION SECTION ===
    Device Model: TOSHIBA MK5075GSX
    Serial Number: X1PQC8UVT
    LU WWN Device Id: 5 000039 393f83ae8
    Firmware Version: GT001M
    User Capacity: 500,107,862,016 bytes [500 GB]
    Sector Size: 512 bytes logical/physical
    Rotation Rate: 5400 rpm
    Device is: Not in smartctl database [for details use: -P showall]
    ATA Version is: ATA8-ACS (minor revision not indicated)
    SATA Version is: SATA 2.6, 3.0 Gb/s (current: 3.0 Gb/s)
    Local Time is: Fri Aug 22 13:11:43 2014 UTC
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status: (0x00) Offline data collection activity
    was never started.
    Auto Offline Data Collection: Disabled.
    Self-test execution status: ( 25) The self-test routine was aborted by
    the host.
    Total time to complete Offline
    data collection: ( 120) seconds.
    capabilities: (0x5b) SMART execute Offline immediate.
    Auto Offline data collection on/off support.
    Suspend Offline collection upon new
    command.
    Offline surface scan supported.
    Self-test supported.
    No Conveyance Self-test supported.
    Selective Self-test supported.
    SMART capabilities: (0x0003) Saves SMART data before entering
    power-saving mode.
    Supports SMART auto save timer.
    Error logging capability: (0x01) Error logging supported.
    General Purpose Logging supported.
    Short self-test routine
    recommended polling time: ( 2) minutes.
    Extended self-test routine
    recommended polling time: ( 143) minutes.
    SCT capabilities: (0x003d) SCT Status supported.
    SCT Error Recovery Control supported.
    SCT Feature Control supported.
    SCT Data Table supported.
    SMART Attributes Data Structure revision number: 16
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
    1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
    2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
    3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 1643
    4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 2971
    5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 144
    7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
    8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
    9 Power_On_Hours 0x0032 075 075 000 Old_age Always - 10376
    10 Spin_Retry_Count 0x0033 159 100 030 Pre-fail Always - 0
    12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2702
    191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 2901
    192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 81
    193 Load_Cycle_Count 0x0032 085 085 000 Old_age Always - 153077
    194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 32 (Min/Max 9/50)
    196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 17
    197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 264
    198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
    199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
    220 Disk_Shift 0x0002 100 100 000 Old_age Always - 8283
    222 Loaded_Hours 0x0032 085 085 000 Old_age Always - 6117
    223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
    224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
    226 Load-in_Time 0x0026 100 100 000 Old_age Always - 294
    240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
    SMART Error Log Version: 1
    ATA Error Count: 1089 (device log contains only the most recent five errors)
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    SC = Sector Count Register [HEX]
    SN = Sector Number Register [HEX]
    CL = Cylinder Low Register [HEX]
    CH = Cylinder High Register [HEX]
    DH = Device/Head Register [HEX]
    DC = Device Command Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
    Powered_Up_Time is measured from power on, and printed as
    DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
    SS=sec, and sss=millisec. It "wraps" after 49.710 days.
    Error 1089 occurred at disk power-on lifetime: 10376 hours (432 days + 8 hours)
    When the command that caused the error occurred, the device was active or idle.
    After command completion occurred, registers were:
    ER ST SC SN CL CH DH
    40 41 22 d0 0a 0b 60 Error: UNC at LBA = 0x000b0ad0 = 723664
    Commands leading to the command that caused the error were:
    CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
    60 28 20 b0 0a 0b 40 00 00:28:51.284 READ FPDMA QUEUED
    ef 02 00 00 00 00 00 00 00:28:51.283 SET FEATURES [Enable write cache]
    aa aa aa aa aa aa aa ff 00:28:51.251 [RESERVED]
    60 28 18 b0 0a 0b 40 00 00:28:47.228 READ FPDMA QUEUED
    60 40 10 70 0a 0b 40 00 00:28:47.227 READ FPDMA QUEUED
    Error 1088 occurred at disk power-on lifetime: 10376 hours (432 days + 8 hours)
    40 41 1a d0 0a 0b 60 Error: UNC at LBA = 0x000b0ad0 = 723664
    60 40 08 58 0b 0b 40 00 00:28:47.227 READ FPDMA QUEUED
    60 80 08 d8 0a 0b 40 00 00:28:43.359 READ FPDMA QUEUED
    ef 02 00 00 00 00 00 00 00:28:43.359 SET FEATURES [Enable write cache]
    Error 1087 occurred at disk power-on lifetime: 10376 hours (432 days + 8 hours)
    40 41 0a d0 0a 0b 60 Error: UNC at LBA = 0x000b0ad0 = 723664
    60 80 08 d0 0a 0b 40 00 00:28:39.257 READ FPDMA QUEUED
    ef 02 00 00 00 00 00 00 00:28:39.257 SET FEATURES [Enable write cache]
    aa aa aa aa aa aa aa ff 00:28:39.240 [RESERVED]
    60 80 08 d0 0a 0b 40 00 00:28:35.170 READ FPDMA QUEUED
    ef 02 00 00 00 00 00 00 00:28:35.170 SET FEATURES [Enable write cache]
    Error 1086 occurred at disk power-on lifetime: 10376 hours (432 days + 8 hours)
    aa aa aa aa aa aa aa ff 00:28:35.140 [RESERVED]
    60 80 08 d0 0a 0b 40 00 00:28:31.068 READ FPDMA QUEUED
    ef 02 00 00 00 00 00 00 00:28:31.068 SET FEATURES [Enable write cache]
    Error 1085 occurred at disk power-on lifetime: 10376 hours (432 days + 8 hours)
    aa aa aa aa aa aa aa ff 00:28:31.051 [RESERVED]
    60 80 08 d0 0a 0b 40 00 00:28:26.981 READ FPDMA QUEUED
    ef 02 00 00 00 00 00 00 00:28:26.981 SET FEATURES [Enable write cache]
    SMART Self-test log structure revision number 1
    Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
    # 1 Extended offline Aborted by host 90% 10376 -
    # 2 Short offline Completed: read failure 00% 10376 265768
    SMART Selective self-test log data structure revision number 1
    SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    Selective self-test flags (0x0):
    After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
    Dra98
    Moderator - Komputery Serwis
    Ocena: 1068
    Jeśli są na nim ważne dane należy jak najszybciej je skopiować a dysk wymienić temu nic nie pomoże.
    Atrybut 191 prawie 3k wstrząsów, oraz ważniejsze 05 - 144, oraz 197 - kolejne sektory niestabilne pokazują, że dysk nadaje się do utylizacji\wymiany.
  • #3 13898568
    Qabx
    Windows wymiękł ale Ubuntu trzyma się dzielnie :P
    Windowsa nie można było ani uruchomić, ani zainstalować, a Ubuntu chodzi po formacie nawet.
    mbo
    Ocena: 845
    Czyżbyś zamierzał używać ten dysk ?
    Jeśli tak to grasz w loterię kiedy padnie i stracisz dane ...
