Zwezony raster, brak menu(kolorowe linie)
Potrzebny schemat. Janusz
Czy wolisz polską wersję strony elektroda?
Nie, dziękuję Przekieruj mnie tam!!!MONKEY!!! napisał:hi
i also have one of these i found on the road last night
symptons
no raster no LT from lopt no drive
so
method is so far this i will use now
drop out the chassis to work on it and lay the tube on a towel
solder all {i had lots of dry joints and brockens in the big can mounted on the back of the chassis
with a meter - to chassis set to 200v dc range power up with main isolator and test for a pulse on each diode coming from the chopper
if no pulse check for low readings
the chopper chip has auto protection on any LT / HT rail coming from the chopper
and i also notice an isolator package
{also worth checking with a meter on diode range}
so if there is a pulse on all rails fine
next check all the diodes on the lopt to gnd for shorts and also check all the current limiters before the diodes
i will work on and post conclusion to repair of this
ill do it now
quite looking foward to adding three inch all round to my main area
for cad
let me know if you still have your hansol
maybe if i find the problem in the course i can help you to fix the one you have
hope to talk again
