Laptop Dell Inspiron 1564 - podczas uruchamiania czarny ekran, wentylator chodzi, odezwie się napęd optyczny i dalej nic... Przy kombinacji fn-power to samo, jednak po około 1 min. laptop "chce mi coś powiedzieć" tzn. słychać dźwięk biosu 3-2-1 ( w załączniku) niestety nie potrafię rozkodować co to oznacza. Jeśli ktoś jest w stanie mi pomóc to z góry dziękuję. Dodam, że wcześniej próbowałem coś wyszukać w internecie, niestety akurat kombinacji 3-2-1 nie znalazłem :
Beeps Error Message Description
1-1-2 CPU test failure- The CPU is faulty. Replace the CPU
Low 1-1-2 System board select failure- The motherboard is having an undetermined fault. Replace the motherboard
1-1-3 CMOS read/write error- The real time clock/CMOS is faulty. Replace the CMOS if possible
Low 1-1-3 Extended CMOS RAM failure- The extended portion of the CMOS RAM has failed. Replace the CMOS if possible
1-1-4 BIOS ROM checksum error- The BIOS ROM has failed. Replace the BIOS or upgrade if possible
1-2-1 PIT failure- The programmable interrupt timer has failed. Replace if possible
1-2-2 DMA failure- The DMA controller has failed. Replace the IC if possible
1-2-3 DMA read/write failure- The DMA controller has failed. Replace the IC if possible
1-3-1 RAM refresh failure- The RAM refresh controller has failed
1-3-2 64KB RAM failure- The test of the first 64KB RAM has failed to start
1-3-3 First 64KB RAM failure- The first RAM IC has failed. Replace the IC if possible
1-3-4 First 64KB logic failure- The first RAM control logic has failed
1-4-1 Address line failure- The address line to the first 64KB RAM has failed
1-4-2 Parity RAM failure- The first RAM IC has failed. Replace if possible
1-4-3 EISA fail-safe timer test- Replace the motherboard
1-4-4 EISA NMI port 462 test- Replace the motherboard
2-1-1 64KB RAM failure
Bit 0; This data bit on the first RAM IC has failed. Replace the IC if possible
2-1-2 64KB RAM failure
Bit 1; This data bit on the first RAM IC has failed. Replace the IC if possible
2-1-3 64KB RAM failure
Bit 2; This data bit on the first RAM IC has failed. Replace the IC if possible
2-1-4 64KB RAM failure
Bit 3; This data bit on the first RAM IC has failed. Replace the IC if possible
2-2-1 64KB RAM failure
Bit 4; This data bit on the first RAM IC has failed. Replace the IC if possible
2-2-2 64KB RAM failure
Bit 5; This data bit on the first RAM IC has failed. Replace the IC if possible
2-2-364KB RAM failure
Bit 6; This data bit on the first RAM IC has failed. Replace the IC if possible
2-2-4 64KB RAM failure
Bit 7; This data bit on the first RAM IC has failed. Replace the IC if possible
2-3-1 64KB RAM failure
Bit 8; This data bit on the first RAM IC has failed. Replace the IC if possible
2-3-2 64KB RAM failure
Bit 9; This data bit on the first RAM IC has failed. Replace the IC if possible
2-3-3 64KB RAM failure
Bit 10; This data bit on the first RAM IC has failed. Replace the IC if possible
2-3-4 64KB RAM failure
Bit 11; This data bit on the first RAM IC has failed. Replace the IC if possible
2-4-1 64KB RAM failure
Bit 12; This data bit on the first RAM IC has failed. Replace the IC if possible
2-4-2 64KB RAM failure
Bit 13; This data bit on the first RAM IC has failed. Replace the IC if possible
2-4-3 64KB RAM failure
Bit 14; This data bit on the first RAM IC has failed. Replace the IC if possible
2-4-4 64KB RAM failure
Bit 15; This data bit on the first RAM IC has failed. Replace the IC if possible
3-1-1 Slave DMA register failure
The DMA controller has failed. Replace the controller if possible
3-1-2 Master DMA register failure
The DMA controller had failed. Replace the controller if possible
3-1-3 Master interrupt mask register failure- The interrupt controller IC has failed
3-1-4 Slave interrupt mask register failure- The interrupt controller IC has failed
3-2-2Interrupt vector error- The BIOS was unable to load the interrupt vectors into memory. Replace the motherboard
3-2-3 Reserved
3-2-4Keyboard controller failure- The keyboard controller has failed. Replace the IC if possible
3-3-1 CMOS RAM power bad- Replace the CMOS battery or CMOS RAM if possible
3-3-2 CMOS configuration error- The CMOS configuration has failed. Restore the configuration or replace the battery if possible
3-3-3Reserved
3-3-4 Video memory failure- There is a problem with the video memory. Replace the video adapter if possible
3-4-1 Video initialization failure- There is a problem with the video adapter. Reseat the adapter or replace the adapter if possible
4-2-1 Timer failure- The system's timer IC has failed. Replace the IC if possible
4-2-2 Shutdown failure- The CMOS has failed. Replace the CMOS IC if possible
4-2-3 Gate A20 failure- The keyboard controller has failed. Replace the IC if possible
4-2-4 Unexpected interrupt in protected mode- This is a CPU problem. Replace the CPU and retest
4-3-1 RAM test failure- System RAM addressing circuitry is faulty. Replace the motherboard
4-3-3 Interval timer channel 2 failure- The system timer IC has failed. Replace the IC if possible
4-3-4Time of day clock failure- The real time clock/CMOS has failed. Replace the CMOS if possible
4-4-1 Serial port failure- A error has occurred in the serial port circuitry
4-4-2 Parallel port failure- A error has occurred in the parallel port circuitry
4-4-3 Math coprocessor failure- The math coprocessor has failed. If possible, replace the MPU
3-2-3 Reserved
3-3-3Reserved
