Sony KDL-37V5810 - Wsad na memory stick dla EX2L-Coriander-SAT
kobobolek 16 Paź 2017 09:40 1827 3
  • #1 16760089
    kobobolek
    Ocena: 21
    Szukam wsadu na Memory Stick aby ożywić płytę główną 1-878-942-41, A-1710-876-A
    Telewizor SONY KDL-37V5810, chassis EX2L_CORIANDER_SAT
    Ustaliłem na podstawie podobnej dokumentacji, że wersja płyty jest z głowicą SILICON
    Mam wsady do innych modeli EX2L, ale nie ma tam wyliczonego KDL-37V5810.
    Czy można na próbę włożyć wsad z pliku: MSImage_EX2L_DVBC_PKG1750EA.zip ??
    Czy jest tu inne dedykowane oprogramowanie?
  • #2 16769256
    almou
    Ocena: 55
    Please could somebody send me the guide to launch the upgrade
  • #3 16776059
    kobobolek
    Ocena: 21
    Przykładowy opis do SONY KDL40W5500:
    Memory Stick Preparation
    * Remove unnecessary files from the MS before copying data.
    * Use a Memory Stick formatter (Windows formatters are not supported). Sony format programs can be obtained
    from support.sony-europe.com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM#disc.
    * Choose “Full” format (not “Quick” format).
    * The flash size should be 32MB or higher.
    * Preferably use a Sony device. A steady performance of products of other brands is not guaranteed.
    * The file written to the MS is a ‘Memstick.ind’ file.
    2. MS DL EMMA NVM Update [Skip this step in case of a regular update]
    2-1. Check whether the BA Main Board has a standard or silicon tuner mounted (TB 09TV090).
    2-2. In case of a 40/46/52Z* panel, additionally check for the panel type (TB 09TV121).
    2-3. Extract the appropriate “Basil/Coriander/Eco_Basil/Ginger/Paprika_*.zip” file attached to TB 09TV040.
    2-4. Copy the entire “bin”, “eep” and “eg2l_dvt” folder together with the “autoexec.bat” file into the root of the MS.
    2-5. Unplug the power cord. Do not use the [Power] key or [Standby] key on the remote commander.
    2-6. Insert the Memory Stick.
    2-7. Plug the power cord.
    2-8. The Emma NVM data will be updated. No indications are shown during the upgrade. Only the green LED is on,
    without picture.
    2-9. Wait for 30 seconds.
    2-10. Unplug the power cord, and take out the Memory Stick.
    Nadal poszukują softy do KDL-37V5810 ...
  • #4 16806374
    almou
    Ocena: 55
    Merci Kobobolek. J'ai suivi la procédure mais la n'a pas démaré. Comment est-ce que je peux me procurer le fichier "autoexec.bat" ? Je crois que mon problème est là-bas
