hej...
jestem ponownie ale niestety bez efektu. zapory żadnej nie mami porty też nie są zablokowane.
Mam pytanie czy można sobie wzajemnie użyczyć API KEy w celu przetestowania (oczywiście zdaję sobie sprawę że będzie inne miasto ale przynajmniej wiedział bym w czym jest problem
Po wpisaniu APi w podany przez "szydas" link pojawia się coś jak poniżej ?
{"cod":"200","message":0.003,"cnt":40,"list":[{"dt":1512950400,"main":{"temp":275.35,"temp_min":275.35,"temp_max":275.403,"pressure":998.71,"sea_level":1019.11,"grnd_level":998.71,"humidity":95,"temp_kf":-0.05},"weather":[{"id":500,"main":"Rain","description":"light rain","icon":"10n"}],"clouds":{"all":92},"wind":{"speed":5.56,"deg":149.501},"rain":{"3h":0.475},"snow":{},"sys":{"pod":"n"},"dt_txt":"2017-12-11 00:00:00"},{"dt":1512961200,"main":{"temp":275.22,"temp_min":275.22,"temp_max":275.257,"pressure":998.56,"sea_level":1019,"grnd_level":998.56,"humidity":96,"temp_kf":-0.03},"weather":[{"id":500,"main":"Rain","description":"light rain","icon":"10n"}],"clouds":{"all":92},"wind":{"speed":5.66,"deg":151.002},"rain":{"3h":0.585},"snow":{},"sys":{"pod":"n"},"dt_txt":"2017-12-11 03:00:00"},{"dt":1512972000,"main":{"temp":274.86,"temp_min":274.86,"temp_max":274.873,"pressure":999,"sea_level":1019.5,"grnd_level":999,"humidity":97,"temp_kf":-0.02},"weather":[{"id":500,"main":"Rain","description":"light rain","icon":"10d"}],"clouds":{"all":92},"wind":{"speed":5.77,"deg":155.5},"rain":{"3h":0.645},"snow":{},"sys":{"pod":"d"},"dt_txt":"2017-12-11 06:00:00"},{"dt":1512982800,"main":{"temp":274.839,"temp_min":274.839,"temp_max":274.839,"pressure":999.8,"sea_level":1020.28,"grnd_level":999.8,"humidity":97,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"light rain","icon":"10d"}],"clouds":{"all":92},"wind":{"speed":5.21,"deg":163.001},"rain":{"3h":0.485},"snow":{"3h":0.0235},"sys":{"pod":"d"},"dt_txt":"2017-12-11 09:00:00"},{"dt":1512993600,"main":{"temp":275.107,"temp_min":275.107,"temp_max":275.107,"pressure":1000.71,"sea_level":1021.27,"grnd_level":1000.71,"humidity":95,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"light rain","icon":"10d"}],"clouds":{"all":92},"wind":{"speed":4.11,"deg":194.503},"rain":{"3h":0.56},"snow":{"3h":0.015},"sys":{"pod":"d"},"dt_txt":"2017-12-11 12:00:00"},{"dt":1513004400,"main":{"temp":272.88,"temp_min":272.88,"temp_max":272.88,"pressure":1004.05,"sea_level":1024.69,"grnd_level":1004.05,"humidity":99,"temp_kf":0},"weather":[{"id":500,"main":"Rain","description":"light rain","icon":"10n"}],"clouds":{"all":24},"wind":{"speed":3.41,"deg":251.001},"rain":{"3h":0.13},"snow":{"3h":0.08},"sys":{"pod":"n"},"dt_txt":"2017-12-11 15:00:00"},{"dt":1513015200,"main":{"temp":268.448,"temp_min":268.448,"temp_max":268.448,"pressure":1006.57,"sea_level":1027.23,"grnd_level":1006.57,"humidity":93,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":0},"wind":{"speed":3.86,"deg":227.503},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2017-12-11 18:00:00"},{"dt":1513026000,"main":{"temp":267.456,"temp_min":267.456,"temp_max":267.456,"pressure":1007.78,"sea_level":1028.48,"grnd_level":1007.78,"humidity":89,"temp_kf":0},"weather":[{"id":801,"main":"Clouds","description":"few clouds","icon":"02n"}],"clouds":{"all":24},"wind":{"speed":3.31,"deg":208.002},"rain":{},"snow":{},"sys":{"pod":"n"},"dt_txt":"2017-12-11 21:00:00"},{"dt":1513036800,"main":{"temp":268.21,"temp_min":268.21,"temp_max":268.21,"pressure":1008.53,"sea_level":1029.36,"grnd_level":1008.53,"humidity":88,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":24},"wind":{"speed":3.36,"deg":188.001},"rain":{},"snow":{"3h":0.0075000000000001},"sys":{"pod":"n"},"dt_txt":"2017-12-12 00:00:00"},{"dt":1513047600,"main":{"temp":268.485,"temp_min":268.485,"temp_max":268.485,"pressure":1009.04,"sea_level":1029.77,"grnd_level":1009.04,"humidity":90,"temp_kf":0},"weather":[{"id":800,"main":"Clear","description":"clear sky","icon":"01n"}],"clouds":{"all":64},"wind":{"speed":3.36,"deg":175.503},"rain":{},"snow":{"3h":0.02},"sys":{"pod":"n"},"dt_txt":"2017-12-12 03:00:00"},{"dt":1513058400,"main":
