Problem kluczyka (plip/cewka)- immobilizer fabryczny Renault
kris23 16 Sie 2005 16:36 75905 36
Najlepsze odpowiedzi
How can I fix a 1999 Renault Kangoo immobilizer problem when both keys still operate the central locking but the factory immobilizer does not disarm, and can I start it manually with the emergency code on the round key version?
The most practical fixes suggested are to check the antenna ring/coil at the ignition and its very thin wires for breaks, because on Renaults these connections often fail; if both keys fail, it is worth opening the steering-column cover and inspecting the coil and wiring first [#1767878] Another reply says that in this case the key fobs may be fine for central locking, but the transponders in the keys are likely damaged; a very delicate resoldering might be tried, but success is unlikely [#1761251] For a full bypass, one user says this Kangoo version needs an immobilizer emulator, with roughly 200 PLN for the emulator plus about 100 PLN labor, or reprogramming a 24C04 chip through an RTV/electronics service [#6689457] The same reply also states that the round-key 1999 Kangoo cannot be started manually with the emergency code and requires a computer/programmed solution instead [#6689457] A cheaper route mentioned is having a private specialist handle the key/immobilizer repair rather than the Renault dealer, which was said to quote excessive prices [#1740945][#1761054]
  • #1 1738831
    kris23
    Ocena: 8
    Witam. Mam Renault Kangoo 1.9 D 99' i zaciąłem się na samodzielne rozpracowanie mojego problemu bo myślę że 600 stów za plipy to rozbój... Autko nie zapala - nie rozbraja się immobilizer. Obydwa kluczyki otwierają centralny ( raczej sterowany radiem bo łapie nawet zza samochodu ) natomiast nie rozbrajają immobilizera fabrycznego. Baterie wymieniłem - choć stare też nie były złe... Jak kupowałem to w 1 kluczyku niby już nie działał immobilizer (używałem więc tylko tego drugiego). Jak się zaczęły problemy z tym ostatnim to przez moment działały nawet obydwa ( rozbrajały ) ale raz na kilka, kilkanascie razy i rzadziej ( po dłuższym przytrzymaniu przycisku otwierania zamka centralnego - taki jakby RESET ;) ). Wreszcie na 2 dzień po kilkunastominutowych zmaganiach odpaliłem ostatni raz i pojechałem do ASO ( podpięli auto do kompa ) -DIAGNOZA = do wymiany główki kluczyka ( plipy ) = koszt j.w. więc podziękowałem bo drogo i jaka pewność, że jak sprowadzą mi nowe kluczyki to nie okaże się że do wymiany jest także dekoder albo elektrozawór ? ASO skasowało mnie na 60zł i odpalilło autko z kompa i nawet łobuzy nie dali mi tego awaryjnego kodu i nie poinformowali że można odpalić ręcznie z pomocą tego kodu.
    Czytałem na forach, że cewki które są w główkach tych kluczyków padają
    jak muchy.... ale znalazłem opis jak naprawić taką cewkę ale niestety bez zdjęć... ( a elektronik ze mnie słaby - już lepszy archeolog :)
    Czy ktoś może podesłać dokładny opis problemu i opis jak naprawić cewkę ( najlepiej ze zdjęciami ) ? Oczywiście jako ostateczność biorę pod uwagę deaktywację immobilizera ... Czy da się i jak to zrobić samodzielnie w garażu ? Bedę wdzięczny za każdy dokładny opis-propozycję rozwiązania mego problemu lub ewent. gdzie mogę tanio dokonać powyższych operacji (okolice Katowic).
    Zależy mi na czasie więc piszcie też na priv: pompalini(_at_)tlen.pl
    mała uwaga:
    Chciałem chwilowo rozbroić immobilizer ręcznie ....z pomocą ( 4 cyfrowego) kodu awaryjnego odblokowywania blokady zapłnu ....
    ( za jego ściągnięcie ASO zaśpiewało 66zl) ale powiedzieli mi także że
    jak Kangur z 99 ma główkę kluczyka okragławą ( a mój ma ) to nie ręcznie nie da rady - tylko z komputerem podłączonym
    do auta i za pomocą programu.
    Czy to rzeczywiście prawda ?
  • #2 1739123
    lagis
    witam mam podobny problem z laguną , biorąc pod uwagę koszty w sewisie i awaryjność tego ustrojstwa postanowiłem wywalić immo z kompa (300pln ) i załozyć sterownik do centralnego , wydaje mi sie to najrozsadniejsze pozdrawiam i powodzenia!!!
  • #3 1739215
    kris23
    Ocena: 8
    lagis napisał:
    witam mam podobny problem z laguną , biorąc pod uwagę koszty w sewisie i awaryjność tego ustrojstwa postanowiłem wywalić immo z kompa (300pln ) i załozyć sterownik do centralnego , wydaje mi się to najrozsadniejsze pozdrawiam i powodzenia!!!
    Tak jak pisałem wywalenie fabrycznego immobilizera też biorę pod uwagę ale tutaj mam trochę obaw że jak się pogrzebie bez autoryzacji gdzieś w elektronice to mogą być potem jakieś problemy na drodze...... a w ASO immobilizera nie deaktywują - proponują wymianę plipów/kluczyków , dekodera etc. ... po odpowiedniej abstrakcyjnej cenie.
    I bądź tu mądry i pisz wiersze.... jak kasy nie masz w kieszeni :(
  • #4 1740945
    penio
    Ocena: 38
    kris23- bo o takich sprawach serwisy nie maja pojecia musisz szukac kogos prywatnie co sie tym zajmuje
  • #5 1742558
    bohun555
    Użytkownik obserwowany
    Ocena: 124
    Jeżeli twoje auto jest po gwarancji to ASO może ci skoczyć. Tam właśnie chodzi o to żeby postraszyć ludzi utratą gwarancji itp żeby naciągnąć ich na kasę (koszt 2-óch plipów i dekodera to ok 2 tys PLN). Sam pracuję w RENAULT i wiem co się psuje i ile się za to płaci dziwi mnie tylko głupota ludzi którzy zostawiają potworne pieniądze za naprawy bo "ktoś" ich postraszył utratą gwarancji. Wracając do tematu immo w twoim aucie to polecam swoje usługi po 17. Pozdrawiam.
  • #6 1743123
    kamyczek
    Ocena: 570
    A tak na marginesie wszystko co seryjnie montowane w autach nie jest żadnym zabezpieczeniem dla złodzieji samochodów . Prędzej złudną obietnica bezpieczeństwa dla właściciela i pretekstem do wyciągnięcia siana . A za 1000 zł można mieć bardzo dobry alarm z wodotryskami moim zdaniem owiele bardziej bezpieczny bo nie seryjny ...
  • #7 1744700
    bohun555
    Ocena: 124
    Tak na prawde to nie ma zabezpieczeia które chroni przed kradzieżą ale to temat na inny raz.......
  • #8 1760314
    vqsoft
    Ocena: 9
    nie wiem jakie masz piloty w tym kangoo, ostanio ojciec mail podobny problem w meganie 97. jednak tam uklad dziala na IR. serwis tez chcial bajonskie sumy. Jednak elektronik z czeladzi poradzil sobie wysmienicie i za 60 pln naprawil piloty.
    wiec moze to wyprobuj.
  • #9 1761054
    kris23
    Ocena: 8
    Moje piloty centralnego ( i immo ) mają sterowanie radiowe... choć nie wiem czy to ma znaczenie bo chodzi o ich fukcję immo ( po prostu nie rozbrajają immobilizera ).
    Jakbyś podrzucił mi namiar/telefon do tego mechanika to byłbym wdzięczny. Pisz na priv'a: pompalini(_at_)tlen.pl
    ASO powiedziało że to piloty są winne więc może by mi też pomógł za niewielkie pieniądze ?
    Pozdro
  • #10 1761251
    bohun555
    Ocena: 124
    Pozdro
    W twiom przypadku piloty są dobre. Auto nie odpala bo transpondery w kluczyku są uszkodzone. Można sprubować je delikatnie przelutować ale prawdopodobieństwo tego że to zadziała to tak jak szóstka w lotku. Pozdrawiam
  • #11 1767662
    mars212
    Ocena: 44
    Co wy piszecie????Przecież transpondera nie przelutujesz! To jest łączność bezprzewodowa z pętlą! Jeśli sie wywalił, to można jedynie go spróbować zaprogramować, e/w wymienić na nowy (mówie tu o transponderze)
  • #12 1767878
    amd
    Ocena: 8
    Nie wiem jak jest z tym w kangurze ale np w lagunie szybciej urywaja sie polaczenia cewki przy stacyjce. Jesli nie dzialaja oby dwa kluczyki to lepiej rozkrec oslone kolumny i przy stacyjce powinienes miec taki pierscien czyli cewke. Sprawdz czy przeodziki od niej lacza tam gdzie trzeba a sa bardzo cienkie wiec io usterke nie trudno.
  • #13 1768246
    bohun555
    Ocena: 124
    mars212 napisał:
    Co wy piszecie????Przecież transpondera nie przelutujesz! To jest łączność bezprzewodowa z pętlą! Jeśli się wywalił, to można jedynie go spróbować zaprogramować, e/w wymienić na nowy (mówie tu o transponderze)
    Renaulty mają specyficzne transpondery jak ktoś rozbierze taki kluczyk to bedzie wiedział o co mi chodzi.
  • #14 1768362
    mars212
    Ocena: 44
    ...chyba nie wszystkie kolego... ja mam akurat na stole immo od Renault i tu mam PCF 7931XP/SQ a to jest transponder bezstykowy.... :]
  • #15 1769129
    bohun555
    Ocena: 124
    Wszystko się zgadza ale w omawianym przypadku są lutowane do płytki plipa.
  • #17 3076960
    ksiks
    Ocena: 35
    Może ktoś wie jak wywalic fabryczne immo z renault clio 2000r.
  • #18 4402555
    nilif
    Mam wielki problem. Kupilem Clio II z 1998 1,4 benz. i na drugi dzien auto nie zapalilo. Zaczela mrygac taka pomaranczowa kontrolka od komputera. (w dniu zakupu auto podpiete pod kompa i wszystko ok) Mechanik, ktory mi wymienial pasek, oleje itd odpial pin od sterownika, popsikal czyms tam i odpalilo. Dzialalo bez klopotu. Pojechalem po kilku dniach w trase. Zrobilem kolo 1000 km i wszystko bzlo ok, az do momentu gdy wrocilem z marketu i to samo. Mrygajaca nie gasnaca lampka. Wezwalem pomoc, pana z kompem. Komputer wykazal za immo. Odpalilismy go ze dwa raze. Jesli nie wyjalem klucza ze stacyjki to ok, zapalal dalej. Jesli wyjalem - to juz nie. Nawet jesli auto zapalilo, to na wolnych obrotach mrygala ta kontrolka, gdy sie dodalo gazu to juz nie. Musze teraz auto sciagnac, bo jest 400 km od domu a ja wrocilem pociagiem. Auto Elektronik rozlozyl rece albo mu sie nie chcialo. Co to moze byc? POMOCY
  • #19 6564193
    elektryka2
    Ocena: 6
    Bez żadnych problemów wywalam immo i niema żadnych problemów pózniej.
  • #20 6685263
    audi_n
    witam,
    mam pytanie do elektryka2 albo bohun555- ile kosztuje wywalenie immobilaizera z kango i skad jestescie? moj email: rrss66(_at_)wp.pl pozdrawiam
  • #21 6688912
    Kusy
    Ocena: 30
    podłączę się do tematu. już kiedyś zadałem pytanie o immo ale nikt nie chce mi pomóc.
    chodzi dokładnie o clio sport z 2002. piloty mam 2 i działają i zamykają/otwierają i odpalają auto. ALE czasami się dzieje tak że jeżdżę tydzień 2 lub 3 (nigdy nie jest to ustalony czas), aż tu nagle wkładam kluczyk do stacyjki i przekręcam zapłon/start, a tu na desce mruga dioda od immo. miga szybciej niż zawsze. po kilku próbach (przekręceniach kluczyka) zaczyna się palić ciągle, i nie da się uruchomić silnika. kolega andrzej1982 sprawdzał mi kluczyki i mówił że są oki. kilka razy już miałem tak że musiałem dzwonić po kolegę i holować auto do domu. jednak nad tym wszystkim jakieś fatum wisi bo zazwyczaj jak holowany byłem kilkaset metrów i próbowałem odpalić to odpalał. dochodzę do wniosku że może jakieś złe styki w kostce.
    i teraz pytanie do kolegów elektryka2 i bohun555 czy jesteście w stanie pomóc na odległość czy jak zdradzicie skąd jesteście to podjęlibyście się "wywalenia" immo w moim aucie ??
    pzodr Kusy...
  • #22 6689457
    tocka
    Ocena: 199
    Zależy mi na czasie więc piszcie też na priv: pompalini(małpa)tlen.pl
    mała uwaga:
    Wiesz dlaczego ci tyle zawołali ?
    To ci wytłumaczę w twoim modelu trzeba zastosować emulator - koszt ok. 200 zł + robocizna. (100zł) + reszta za wygląd :D
    Wiem że moderator mnie pogoni ale "deaktywuje immobilaizery zapraszam na moje aukcje".
    Mogę ci pomóc na odległość ale musisz w okolicy mieć serwis RTV lub programator do 24C04 aby ci przeprogramował kość.
    Tylko na priv aby nie pomagać kolegom od przywłaszczania nie swoich samochodów.
  • #23 6689487
    Jacek79
    Poziom 37  
    Ocena: 1132
    tocka, jak ma clio na sagemie ( 3 wtyczki) to 2 stówy to mało.
  • #24 6689553
    tocka
    Ocena: 199
    clio tak ale w cangu ma ten sterownik bo dopiero po 2001roku były inne Problem kluczyka (plip/cewka)- immobilizer fabryczny Renault
  • #25 6689578
    Jacek79
    Poziom 37  
    Ocena: 1132
    myślałem że odnosisz się do postu "kusy".
  • #26 6689661
    tocka
    Ocena: 199
    jak ma syriusa takiego jak był w 2001 roku to bez emu się obejdzie :D
  • #27 6690187
    Jacek79
    Poziom 37  
    Ocena: 1132
    trzydziestki dwójki nie idą bez emu. Tzn są wsady czyściochy, ale jak go zapakujesz to silnik albo ma nierówne wolne obroty, albo nie ma mocy, albo nie włączy się sprężarka klimy.
  • #28 6690446
    tocka
    Ocena: 199
    wiem że 32 i 34 nie idzie bez emu i musi być np. taki PIC16F84A
    Ale np. 32N pójdzie bez .
  • #29 6690476
    Kusy
    Ocena: 30
    tak to ja już się nie znam...
    jeszcze przetrawię to wywalenie immo i tak jak pisałem na @, jak będę gdzieś w twojej okolicy dam znaka i pogadamy trochę
    pzodr Kusy
  • #30 6898872
    Paweł Melon
    Ocena: 4
    mam Reno kango i mam problem z blokada imobilajzer jest odciecie i nie moge odpalic. Jest jakies obejscie tego. prosze pomocy
✨ Problem dotyczy fabrycznego immobilizera w Renault Kangoo 1.9 D z 1999 roku, który nie rozbraja się pomimo działania centralnego zamka i wymiany baterii w kluczykach (plipach). Immobilizer uniemożliwia uruchomienie silnika, a autoryzowany serwis (ASO) proponuje kosztowną wymianę plipów i dekodera. W dyskusji pojawiają się sugestie dotyczące usunięcia immobilizera (tzw. "wywalenie immo") jako tańszej alternatywy, jednak z obawami o legalność i ewentualne problemy na drodze. Wskazuje się na możliwe uszkodzenia transponderów w kluczykach, które są bezstykowe i lutowane do płytki plipa, co utrudnia naprawę. Zalecane jest sprawdzenie cewki (pierścienia) przy stacyjce, gdyż przerwane przewody mogą powodować brak rozbrojenia immo. Wymiana lub programowanie transpondera jest możliwe, ale kosztowne. Pojawia się też informacja o emulatorach immobilizera (koszt około 200-300 zł plus robocizna), które pozwalają na ominięcie fabrycznego zabezpieczenia. Użytkownicy podkreślają, że seryjne immobilizery nie gwarantują pełnej ochrony przed kradzieżą i często są wykorzystywane przez serwisy do generowania wysokich kosztów napraw. Wskazane są również prywatne serwisy i elektronicy, którzy oferują tańsze rozwiązania. W dyskusji pojawiają się także inne modele Renault (Laguna, Megane, Clio) z podobnymi problemami immobilizera, a także uwagi o różnicach w systemach sterowania (radiowe vs. podczerwieni) i konieczności stosowania emulatorów w nowszych modelach.
