Lenovo G500 - wymiana cpu na najmocniejszy dostepny
midass 27 Mar 2019 11:18 7245 16
  • #1 17869217
    midass
    jak w temacie
    mam celerona 1900MHz
    chce wrzucic cos najmocniejszego co sie da
    co mozna aby pasowało? moze jakies i5 bo chyba i7 nie da rady
    model:
    lenovo g500
    s/n cb29722961
  • #3 17869285
    midass
    znalazlem wszystkie cpu pasujace , bios jak poprzednik napisal UPGRADE:
    Model Box part numbers Technology
    (micron) Cores Threads Frequency
    (MHz) Turbo
    freq.
    (MHz) L2 cache
    (KB) L3 cache
    (KB) TDP
    (Watt)
    Core i3-2312M 0.032 2 4 2100 512 3072 35
    Core i3-2308M 0.032 2 4 2100 512 3072 35
    Core i3-2310M 0.032 2 4 2100 512 3072 35
    Core i3-2332M 0.032 2 4 2200 512 3072 35
    Core i3-2330E 0.032 2 4 2200 512 3072 35
    Core i3-2328M 0.032 2 4 2200 512 3072 35
    Core i3-2330M 0.032 2 4 2200 512 3072 35
    Core i3-2350M 0.032 2 4 2300 512 3072 35
    Core i3-2348M 0.032 2 4 2300 512 3072 35
    Core i3-3110M 0.022 2 4 2400 512 3072 35
    Core i3-3120ME 0.022 2 4 2400 512 3072 35
    Core i3-2370M 0.032 2 4 2400 512 3072 35
    Core i3-3120M 0.022 2 4 2500 512 3072 35
    Core i3-3130M 0.022 2 4 2600 512 3072 35
    Core i5-2410M 0.032 2 4 2300 2900 512 3072 35
    Core i5-2430M 0.032 2 4 2400 3000 512 3072 35
    Core i5-2450M 0.032 2 4 2500 3100 512 3072 35
    Core i5-3210M 0.022 2 4 2500 3100 512 3072 35
    Core i5-2520M BX80627I52520M 0.032 2 4 2500 3200 512 3072 35
    Core i5-2510E 0.032 2 4 2500 3100 512 3072 35
    Core i5-3320M BX80638I53320M 0.022 2 4 2600 3300 512 3072 35
    Core i5-3230M 0.022 2 4 2600 3200 512 3072 35
    Core i5-2540M BX80627I52540M 0.032 2 4 2600 3300 512 3072 35
    Core i5-3610ME 0.022 2 4 2700 3300 512 3072 35
    Core i5-3340M BX80638I53340M 0.022 2 4 2700 3400 512 3072 35
    Core i5-3360M BX80638I53360M 0.022 2 4 2800 3500 512 3072 35
    Core i5-3380M BX80638I53380M 0.022 2 4 2900 3600 512 3072 35
    Core i7-2630QM 0.032 4 8 2000 2900 1024 6144 45
    Core i7-3612QM 0.022 4 8 2100 3100 1024 6144 35
    Core i7-2710QE 0.032 4 8 2100 3000 1024 6144 45
    Core i7-3632QM 0.022 4 8 2200 3200 1024 6144 35
    Core i7-2720QM BX80627I72720QM 0.032 4 8 2200 3300 1024 6144 45
    Core i7-2670QM 0.032 4 8 2200 3100 1024 6144 45
    Core i7-2820QM BX80627I72820QM 0.032 4 8 2300 3400 1024 8192 45
    Core i7-3610QE 0.022 4 8 2300 3300 1024 6144 45
    Core i7-3610QM 0.022 4 8 2300 3300 1024 6144 45
    Core i7-2760QM BX80627I72760QM 0.032 4 8 2400 3500 1024 6144 45
    Core i7-3630QM 0.022 4 8 2400 3400 1024 6144 45
    Core i7-2860QM BX80627I72860QM 0.032 4 8 2500 3600 1024 8192 45
    Core i7-3720QM BX80638I73720QM 0.022 4 8 2600 3600 1024 6144 45
    Core i7-3820QM BX80638I73820QM 0.022 4 8 2700 3700 1024 8192 45
    Core i7-3740QM BX80638I73740QM 0.022 4 8 2700 3700 1024 6144 45
    Core i7-2620M 0.032 2 4 2700 3400 512 4096 35
    Core i7-2640M 0.032 2 4 2800 3500 512 4096 35
    Core i7-3840QM BX80638I73840QM 0.022 4 8 2800 3800 1024 8192 45
    Core i7-3520M 0.022 2 4 2900 3600 512 4096 35
    Core i7-3540M 0.022 2 4 3000 3700 512 4096 35
    Core i7-2920XM 0.032 4 8 2500 3500 1024 8192 55
    Core i7-2960XM 0.032 4 8 2700 3700 1024 8192 55
    Core i7-3920XM 0.022 4 8 2900 3800 1024 8192 55
    Core i7-3940XM 0.022 4 8 3000 3900 1024 8192 55
    Celeron B800 0.032 2 2 1500 512 2048 35
    Celeron B815 0.032 2 2 1600 512 2048 35
    Celeron B810 0.032 2 2 1600 512 2048 35
    Celeron B710 0.032 1 1 1600 256 1536 35
    Celeron B720 0.032 1 1 1700 256 1536 35
    Celeron B820 0.032 2 2 1700 512 2048 35
    Celeron B830 0.032 2 2 1800 512 2048 35
    Celeron B730 0.032 1 2 1800 256 1536 35
    Celeron 1000M 0.022 2 2 1800 512 2048 35
    Celeron B840 0.032 2 2 1900 512 2048 35
    Celeron 1005M 0.022 2 2 1900 512 2048 35
    Celeron 1020M 0.022 2 2 2100 512 2048 35
    Celeron 1020E 0.022 2 2 2200 512 2048 35
    Mobile Pentium A1018 0.022 2 2 2100 512 1024 35
    Pentium B940 0.032 2 2 2000 512 2048 35
    Pentium B950 0.032 2 2 2100 512 2048 35
    Pentium B960 0.032 2 2 2200 512 2048 35
    Pentium B970 0.032 2 2 2300 512 2048 35
    Pentium B980 0.032 2 2 2400 512 2048 35
    Pentium 2020M 0.022 2 2 2400 512 2048 35
    Pentium 2030M 0.022 2 2 2500 512 2048 35
    dziękuje za pomoc
  • #4 17883185
    midass
    po wymianie cpu na Intel Core i5-2430M SR04W
    wyskakuje ze zły procek, proszę wymienić
    wymiana biosa lub aktualizacja pomoże?
    nie robiłem nigdy z biosem update, na starym procku działa ok
  • #5 17883202
    jurkuc
    Ocena: 314
    Tak jak pisałem w swoim poście aktualizacja bios-u jest konieczna ponieważ przy aktualizacji uaktualniana jest również lista mikrokodów dla nowszych procesorów.
  • #6 17883235
    ak6
    Ocena: 139
    Dodam tylko, że aktualizację musisz zrobić na starym procesorze.
    Aktualizacja Bios jest konieczna.
  • #7 17883267
    midass
    szukałem i znalazlem ze jest jakaś opcja "via air" ale chyba tylko do nowszych modeli
    jak w tym Lenovo to zrobić żeby nie wlutowywać układu?
  • #9 17883401
    midass
    a co w przypadku komunikatu ze ROM biosu jest taki sam jak w BIOSie?
    czyli mam najnowszy pewnie....
    ten co podałeś :)
  • #10 17883413
    jurkuc
    Ocena: 314
    Jeżeli jest taki komunikat to rzeczywiście masz bios najnowszy i nie dokona się aktualizacja :)
  • #11 17883436
    midass
    to już wiemy :)
    pytanie jak to dalej ogarnąć bo płyta w rozpisce obsługuje ten cpu
  • #12 17883452
    jurkuc
    Ocena: 314
    Instrukcja serwisowa do tego sprzętu podaje kompatybilne procesory do niego. Proszę sprawdzić czy znajduje się on na liście. Ja niestety go nie widzę.
    • CPU for Lenovo G500.pdf (342.3 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #13 17883457
    midass
    moge prosic o pelen pdf?
    i7 przy drogie szukam bardziej i5
  • #14 17883459
    jurkuc
    Ocena: 314
    Proszę bardzo ( strony 82 do 83 )
    • lenovo_g400g500g405g505g410g510_hmm.pdf (8.82 MB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #16 17887391
    midass
    CORE i5-3230M 2.60GHz SR0WY
    i
    na obydwu
    Unsupport CPU for PCH, Power off and change it
    czyli juz nie mam pomyslu na ta plyte
    wejscie do biosa bez problemu ale przy starcie niestety ten komunikat
    może ktoś ma jakiś pomysł?
  • #17 20425806
    Jimbeam01
    Ocena: 7
    Mostek puści Ci najwyżej Pentiuma. Żadne i3/i5/i7 nie będzie działało.
✨ Użytkownik poszukuje informacji na temat wymiany procesora w laptopie Lenovo G500, który obecnie ma zainstalowany procesor Celeron 1900MHz. W odpowiedziach zasugerowano, że możliwe jest zainstalowanie procesora Intel Core i7-3520M, jednak przed wymianą konieczna jest aktualizacja BIOS-u do najnowszej wersji. Użytkownicy podali również listę kompatybilnych procesorów, w tym różne modele i3 oraz i5, takie jak i5-2430M i i5-3230M. Po wymianie na i5-2430M użytkownik napotkał komunikat o błędzie, co sugeruje, że BIOS może nie obsługiwać nowego procesora. Wskazano, że aktualizacja BIOS-u powinna być przeprowadzona na starym procesorze, a także że nie ma potrzeby wylutowywania układów. W przypadku problemów z komunikatem o nieobsługiwanym procesorze, użytkownicy sugerowali sprawdzenie listy kompatybilnych procesorów w dokumentacji serwisowej.
