Ufsxcom – jak odblokować ufsxcom do pracy z uniwersalnymi kablami i softem?
chillouty 11 Paź 2005 12:53 1371 1
  • #1 1889746
    chillouty
    Ocena: 10
    How to crack ufsxcom to use all ufsx cables with any universal soft like usr ot other we dont need to use unibox ! only ur ufs
    Download file from
    http://www.i-mobile.info
    1. Run ufsxcom, then click on registration (dont enter anything)
    2. Run winhex and open the 2nd ufsxcom.exe process, load its primary memory
    3. Search for the ascii 06FBFF66.TMP, then above that you will see some clsid, take note of that clsid. example: {84097FE5-DDFA-F2C1-2750-
    Now press the key page down twice and you will see something like knZzzCy take note of whatever is below it, for example : kPtXEQBNYV
    4. Remember to take note of the two values above, Close ufsxcom.exe by clicking cancel, then ignore the error by clicking ok
    5. Now create a file using notepad and paste the following BUT replace YOURCLSID and YOURVALUE with those that you have noted above for example {84097FE5-DDFA-F2C1-2750-A54110277569} and kPtXEQBNYV:
    Quote:
    @Echo. off
    echo Reset UFSxCOM trial ver 0.01b
    echo.
    rem remove all tmp files in temp directory
    del %temp%\*.tmp
    rem remove trial
    reg delete HKCR\CLSID\YOURCLSID /v YOURVALUE /f
    reg delete HKLM\SOFTWARE\Licenses /v {025A1A4AC9FC0BBFA} /f
    reg delete HKLM\SOFTWARE\Licenses /v {I25A1A4AC9FC0BBFA} /f
    reg delete HKLM\SOFTWARE\Licenses /v {07D6033B0D5A924FC} /f
    reg delete HKLM\SOFTWARE\Licenses /v {I7D6033B0D5A924FC} /f
    pause
    will be
    Quote:
    @Echo. off
    echo.
    del %temp%\*.tmp
    rem remove trial
    reg delete HKCR\CLSID\{84097FE5-DDFA-F2C1-2750-A54110277569} /v kPtXEQBNYV /f
    pause
    then save the file to reset.bat
    run the file everytime you run out of trial days.
    enjoy
    Całość sciągnieta z innego forum, nie podawałem linka, bo byscie musieli sie logowac/rejestrowac.
    Panowie nie wiem czemu ale mi to nie działa, na forum userzy zas pisza ze działa, wiec nie wiem.
    TESTUJCIE.
    • Ufsxcom – jak odblokować ufsxcom do pracy z uniwersalnymi kablami i softem? ufsxcom.gif (26.87 KB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #2 1890977
    Multi_COM
    Spec od GSM
    Ocena: 59
    bo to nie dziala ;)) bylo juz pisane o tym na Elce wiec tylko wystarczy poszukac... nie ma i nie bedzie tego softu za free - trzeba z tym zyc i tyle !
    P.S
    To co dales to tylko przedzluzenie okresu Triala a pelan funkcjonalnosc jest dopiero po uzciu pliku licencyjnego gennerowanego na podstawie REQ - ta wersja wiec nie umoliwia korzystanie z pelnych predkosci, nie umozliwai wybranai trybow pracy Box a tylko zobaczenie sobie interfejsu ;)
