[Rozwiązano] XD32H2VSAT - Ciemny ekran po awarii prądu, potencjalne uszkodzenie firmware'u w 17MB140
Elettrone 29 Paź 2021 09:31 2574 4
  • #1 19679830
    Elettrone
    Poziom 6  
    Ocena: 9
    Mark: XD
    Model: XD32H2VSAT
    Chassis (main board, components): Vestel 17MB140
    LCD Screen/Panel: VES315WNDS-2D-N22
    This TV after a power failure has turned on again with a dark screen, the backlight no longer works, instead the screen image with external lighting and the audio are ok. I checked the led bars but they are fine, then I think of a firmware problem. Does anyone have the update file to upload to a USB stick or the dump for the spi? Thanks!
  • #2 19679857
    yokoono51
    Poziom 29  
    Ocena: 323
    You need to make sure it's not a backlight problem. Recovery firmware:
    • 17Mb140 kurtarma non vestel.rar (12.23 MB) Musisz być zalogowany, aby pobrać ten załącznik.
  • #3 19680209
    Elettrone
    Poziom 6  
    Ocena: 9
    Excuse me the extracted file mb140.bin do I have to insert it into the spi via programmer or copy it to the usb stick?
  • #4 19680327
    yokoono51
    Poziom 29  
    Ocena: 323
    It's for the stick. It is installed with the OK key.
  • #5 19686640
    Elettrone
    Poziom 6  
    Ocena: 9
    The problem was not what I thought: even if while I was testing the led bars seemed fine, one led had a false contact and was faulty. Thanks for the firmware anyway!
