Skoda Superb 3v - DLA błędy modułów w lampach nieprawidłowe kodowanie
JACKTHESOUL 17 Cze 2022 19:15 1863 0
  • #1 20065034
    JACKTHESOUL
    Ocena: 54
    Cześć! kupiłem sobie skodę superb 2019
    wyciąg z vcds
    Spoiler:
    Wednesday,01,June,2022,20:45:00:60643
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4615.4
    Data version: 20210903 DS330.0
    www.Ross-Tech.com
    License Plate:
    Mileage: 129154km-80252mi Repair Order:
    Chassis Type: NP-SK48 (3Q0)
    Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44
    47 4B 52 5F 6C 6D 75 A5 BB BC
    Mileage: 129154km-80252miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Malfunction 0010
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    22-AWD -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4B-Multifunc. Module -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    75-Telematics -- Status: OK 0000
    A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
    BB-Door Rear Drv -- Status: OK 0000
    BC-Door Rear Pass -- Status: OK 0000
    Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
    Part No SW: 04L 906 026 KA HW: 04L 907 309 P
    Component: R4 2.0l TDI H26 6014
    Revision: B4H26--- CVN: 42C09F31B866C2ADB866C2AD
    Coding: 01250412036605083000
    Shop #: WSC 33361 790 00172
    ASAM Dataset: EV_ECM20TDI01104L906026KA 005004
    ROD: EV_ECM20TDI01104L906026KA_005.rod
    VCID: 73B3D6B14B3BE6A3AA3-8026
    VINID: 91D49C6877A025B1C01C42021C25F60CF6
    1 Fault Found:
    4709 - No Communications with Cruise Control (Front) Distance Sensor
    U0235 00 [039] - -
    [Lost Communication WithCruise Control Front Distance Range Sensor]
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:42
    Engine RPM: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 16 °C
    Intake air temperature: 17 °C
    Ambient air pressure: 1000 mbar
    Voltage terminal 30: 11.640 V
    Unlearning counter according OBD: 40
    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
    Drivetrain coordinator: brake fault status-Bits 0-7: 0
    Drivetrain coordinator: brake function status-Bits 0-7: 0
    Acceleration: 0.000 m/s˛
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
    Part No SW: 0GC 300 013 K HW: 0GC 927 711 H
    Component: GSG DQ381 H06 2403
    Revision: 00H06V08 CVN: D788ABA1
    Coding: 0014
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_TCMDQ381061 001
    ROD: EV_TCMDQ381061.rod
    VCID: 2C010DCDD685F95B2B9-8078
    No subsystems:
    No fault code found.
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 614 517 DH HW: 5Q0 614 517 AH
    Component: ESC H62 0754
    Revision: 00000000 Serial number: 61199000000824
    Coding: 1E076A9C34270B70477F070260CA4978562CD0E2E0069275386150F8C2A9420B00000012121212B835351919323200
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
    ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
    VCID: 7AADFB956C5197EBE95-802E
    2 Faults Found:
    8192 - Databus
    U1121 00 [009] - Missing Message
    [FCAN: ACC_07 message is not received]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:42
    8196 - Databus
    [FCAN : ACC_10 message is not received]
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:42
    Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
    Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
    Component: VWKESSYMQB 037 1204
    Revision: 00037000 Serial number: 0514789616
    Coding: 032C0C0723
    ASAM Dataset: EV_KessyHellaMQBAB 004046
    ROD: EV_KessyHellaMQBAB_004_SK25.rod
    VCID: 43D346715B1B1623FA3-8016
    Address 06: Seat Mem. Pass (J521) Labels:* None
    Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
    Component: Sitzmemory H09 0024
    Serial number: Y0006SCT10464
    Coding: 0010000000000500018280808080000000008181000000D400
    ASAM Dataset: EV_SeatMemorPasseSide 002022
    ROD: EV_SeatMemorPasseSide.rod
    VCID: 3D2730893DFF60D38C7-8068
    Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
    Part No SW: 3V0 907 044 CP HW: 3V0 907 044 CP
    Component: AC Automat H34 4402
    Revision: 20K10000 Serial number: 00000B01343284
    Coding: 12010104002410011005100D0010112A
    ASAM Dataset: EV_ACClimaPrehVW37X 002025
    ROD: EV_ACClimaPrehVW37X_002_VW37.rod
    VCID: 0451856D1E95D11B839-8050
    Humidity sensor: exterior:
    Rear A/C control head:
    Subsystem 2 - Part No SW: 3V0 907 049 E HW: 3V0 907 049 E
    Component: E265KlimaHeck H02 0101
    Serial number: 06051501850797
    Coding: 000000
    Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
    Part No SW: 5Q0 937 084 DD HW: 5Q0 937 084 CG
    Component: BCM MQBAB H H38 0273
    Serial number: 01001912600394
    Coding: 000000000000000000000000000000000000000000000000000000000000
    ASAM Dataset: EV_BCMMQB 019001
    ROD: EV_BCMBOSCH_019.rod
    VCID: 7DA7F0897D7FA0D3CC7-8028
    Wiper motor control module:
    Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
    Component: 48x LL 190410 032 0121
    Serial number: 00000001904040302923
    Coding: 164DDD
    Rain/Light Recognition Sensor:
    Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
    Component: RLHS 052 0107
    Serial number: S5Y19M05D13H12M40S40
    Coding: 0088DF
    Anti-theft alarm system sensor:
    Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0316
    Serial number: 000000000ZY1906425AG
    Alarm horn:
    Subsystem 4 - Part No SW: 5QD 951 605 HW: 5QD 951 605
    Component: Sirene, DWA 005 0314
    Serial number: 00002856223982601161
    Blower 1 for left front backrest:
    Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
    Component: SysNameFanLin 014 0101
    Serial number: ESE0519871
    Blower 1 for left front seat cushion:
    Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
    Serial number: ESE0519966
    Blower 1 for right front backrest:
    Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
    Serial number: ESE0519079
    Blower 1 for right front seat cushion:
    Subsystem 8 - Part No SW: 3G0 963 345 HW: 3G0 963 345
    Serial number: ESE0519974
    2 Faults Found:
    9994 - Bulb for Right Parking Lamp
    B12E9 15 [009] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:16:03
    541204 - Databus
    U1123 00 [009] - Received Error Message
    [LWR_AFS_01 / 05 Datenbus empfangener Fehlerwert]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 4
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:16:08
    Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
    Part No SW: 5QA 919 294 C HW: 5QA 919 294
    Component: PDC 8 KanalH07 0050
    Serial number: 000308418019113
    Coding: 0471155851
    ASAM Dataset: EV_EPHVA18AU3700000 009039
    ROD: EV_EPHVA18AU3700000.rod
    VCID: 4CC16D4D7645D95B0B9-8018
    1 Fault Found:
    12727553 - Databus
    [Steuergerät für Abstandsregelung - Gateway_79.ACC_02_alt - kein Signal/keine Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 6
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:43
    Address 13: Auto Dist. Reg
    Cannot be reached
    Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
    Component: DAEMPFUNGS-SG H17 0121
    Serial number: 22041941351284
    ASAM Dataset: EV_DRCONTITEMIC 001019
    ROD: EV_DRCONTITEMIC_VW37.rod
    VCID: 3829219D12DD45FB5F1-806C
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 BS HW: 5Q0 959 655 BS
    Component: AirbagVW21 007 0403
    Serial number: 003FMR58L5N0
    Coding: 98CCC0C0000000005C5400CF004800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
    ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    VCID: 127DB33554E14FAB015-8046
    Crash sensor for side airbag: driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 000 905 19
    Component: SideSensor_Df 001 0887
    Serial number: 35700000000FF7242C3W
    Coding: 2D2D2D
    Front Passenger's Side Airbag Crash Sensor:
    Subsystem 2 - Part No SW: ----------- HW: 480 000 905 19
    Component: SideSensor_Pf 001 0887
    Serial number: 35800000000FF8242C3Y
    Coding: 2D2D2D
    Rear Side Airbag Crash Sensor (on driver's side):
    Subsystem 3 - Part No SW: ----------- HW: 480 400 605 19
    Component: SideSensor_Dr 005 6149
    Serial number: 3510001C6F00135651CX
    Coding: 2D2D2D
    Passenger side rear thorax airbag crash sensor:
    Subsystem 4 - Part No SW: ----------- HW: 480 400 605 19
    Component: SideSensor_Pr 005 6149
    Serial number: 3520001C6F001357325R
    Coding: 2D2D2D
    Crash sensor for front airbag: driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 401 005 18
    Component: FrontSensor_D 000 6149
    Serial number: 3550001B72948593B5FH
    Coding: 2D2D2D
    Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
    Part No SW: 5Q0 953 521 LR HW: 5Q0 953 569 B
    Component: Lenks.Modul 100 0245
    Revision: FF036036 Serial number: 20190504500129
    Coding: 6414
    ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
    ROD: EV_SMLSVALEOMQBLRH.rod
    VCID: 0D47A0494DDF9053DC7-8058
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
    Part No SW: 3V0 920 711 C HW: 3V0 920 711 C
    Component: KOMBI 312 2700
    Coding: 07A5081AFF840008018B6B0B5001000880000000
    Shop #: WSC 73430 031 00172
    ASAM Dataset: EV_DashBoardVDDMQBAB 009068
    ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
    VCID: 303919BDFAAD9DBB171-8064
    3 Faults Found:
    16777028 - Function Restricted due to Interrupted Communications
    U1110 00 [009] - -
    [BAP_AWV_0x1B keine Kommunikation]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:43
    16776960 - Databus
    [ACC_02 keine Kommunikation]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:40
    16776961 - Databus
    [ACC_04 keine Kommunikation]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:40
    Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
    Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
    Component: GW MQB High 521 5366
    Serial number: 06051911601447
    Coding: 0B0100045F087300EB0002DA9C0F00010001070000000000000000000000
    GVL: 01D63C000800060040FC80008002CC0000000000000200000000000000000000
    ASAM Dataset: EV_GatewNF 013025
    ROD: EV_GatewNF_VW37.rod
    VCID: 6E85C7C52019CB4B45D-803A
    Generator:
    Component: 0-01-09-01-04
    Multifunction steering wheel control module:
    Subsystem 2 - Part No SW: 3V0 919 719 G HW: 3V0 919 719 G
    Component: E221__MFL-PR6 H03 0170
    Serial number: 000000000B0344250419
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
    Component: J367-BDMHella H10 9070
    Serial number: 9082031305
    Inverter for electrical outlet:
    Subsystem 4 - Part No SW: 5Q0 907 155 B HW: 5Q0 907 155 B
    Component: U13DCAC H27 0810
    Serial number: 2109857
    2 Faults Found:
    131671 - No Communications with Cruise Control (Front) Distance Sensor
    U0235 00 [009] - -
    [Timeout Knoten 0x57 / 13 - Abstandsdistanzregelung]
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:41
    Terminal 30 power supply: 11.5 V
    Terminal 15: On
    8526361 - LV Energy Management
    B1802 F1 [008] - Warning Triggered
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 170
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:38:32
    Terminal 30 power supply: 10.9 V
    Terminal 15: On
    Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
    Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
    Component: Haldex4Motion H55 7084
    Serial number: HA1-00004.04.19
    Coding: 0301
    ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
    ROD: EV_AllWheelContrHA1VW37X_004.rod
    Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
    Part No SW: 3Q0 905 861 B HW: 3Q0 905 861 B
    Component: ELV-MQBB H05 0020
    Serial number: 19000118136014
    Coding: 0800000000000000
    ASAM Dataset: EV_ELVMarqMQBA0 002002
    ROD: EV_ELVMarqMQBA0_VW37.rod
    VCID: 333316B10BBBA6A36A3-8066
    Address 36: Seat Mem. Drvr (J810) Labels:* None
    Part No SW: 3Q0 959 760 D HW: 3Q0 959 760 D
    Component: Sitzmemory H06 0024
    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙
    Coding: 0010000000000500818280808080000000008181000000D400
    ASAM Dataset: EV_SeatMemorDriveSide 002022
    ROD: EV_SeatMemorDriveSide.rod
    VCID: 3C213D8D26E569DBBB9-8068
    Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
    Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
    Component: HRE_Master H12 0081
    Serial number: 0515148654
    Coding: 02011103
    ASAM Dataset: EV_HREntryHella 001028
    ROD: EV_HREntryHella_VW37.rod
    Lane change assistance control module 2:
    Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
    Component: HRE_Slave H12 0081
    Serial number: 0514918363
    Coding: 020111
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
    Component: TSG FS 006 0246
    Serial number: 0000375002838
    Coding: 001D8820DE00020000001100
    ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
    ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
    VCID: 48C9515D623D357B2F1-801C
    1 Fault Found:
    196660 - Motor for Window Regulator
    B1487 54 [009] - Missing Calibration / Basic Setting
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:45
    Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
    Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
    Component: MQB_VWBS_GEN2 212 2211
    Serial number: 910049 00
    Coding: 0100001100400110
    ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
    ROD: EV_SteerAssisVWBSMQBGen2.rod
    VCID: 2B030ED1D38BFE63223-807E
    Address 47: Sound System (J525) Labels:| 81A-035-466.clb
    Part No SW: 81A 035 223 HW: 81A 035 223
    Component: MIB2_amp_P_SK H10 0410
    Revision: 00000001 Serial number: SKZ8Z1KJE07GH6B
    Coding: 0384020000AA002FAA0000000000
    ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
    ROD: EV_AMPMst16C5Gen2ALPI.rod
    VCID: 59EF8419C997BCF380F-800C
    1 Fault Found:
    0600 - Loudspeaker 1 in Double-Subwoofer
    B130C 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:18:41
    Voltage terminal 30: 11.4 V
    Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
    Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
    Component: FCM MQB Low 002 0345
    Serial number: 07051910521260
    Coding: 00000002090006F206007F01000000000000000000000000000000000000
    ASAM Dataset: EV_MultiModulContiVW48X 002006
    ROD: EV_MultiModulContiVW48X_002_VW41.rod
    VCID: 353728A905CFB893447-8060
    Left Headlamp Power Output Stage:
    Subsystem 1 - Part No SW: 4H0 941 329 HW: 4H0 941 329
    Component: Leimo links H02 0013
    Coding: 000000
    Right Headlamp Power Output Stage:
    Subsystem 2 - Part No SW: 4H0 941 329 HW: 4H0 941 329
    Component: Leimo rechts H02 0008
    Coding: 000000
    2 Faults Found:
    5276401 - Power Output Module for Right Headlamp
    C1082 F1 [137] - Incorrectly Coded
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:26:26
    5281557 - Adjusting Motor for Variable Lighting Right
    C1097 15 [137] - Open or Short to Plus
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:26:27
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
    Component: TSG BFS 006 0246
    Serial number: 0000374740338
    Coding: 001D8020DE00020000001100
    ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
    ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
    VCID: 47CB52616F233A0326B-8012
    Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-HGH2.clb
    Part No SW: 565 035 021 D HW: 565 035 021
    Component: MU-H-LND-EU H55 1382
    Serial number: A853E0KB129000
    Coding: 03840201000000004111120200880A332F0103E4012085009E
    ASAM Dataset: EV_MUHig4CGen2HBAS 001001
    ROD: EV_MUHig4CGen2HBAS_AU37.rod
    VCID: 0F7BBA4147D3A2432EB-805A
    Display and control head 1 for information electronics:
    Subsystem 1 - Part No SW: 3V0 919 606 D HW: 3V0 919 606 D
    Component: ABT_High-2 H52 9130
    Serial number: SKZ6ZHW1322695
    Data carrier:
    Subsystem 2 - Part No SW: V03 959 801 JR HW: -----------
    Component: ECE 2019 --- 0175
    Serial number: --------------------
    Compact disc data bank:
    Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2 --- 1017
    2 Faults Found:
    7173 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:40:09
    Voltage terminal 30: 12.1 V
    BAP-BAP_Function_ID: 02
    7195 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:40:09
    Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
    Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
    Component: RVC Compact H18 0231
    Coding: 04840201A2002017000040
    ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
    ROD: EV_CamSysRVRVCPANAMQBAB.rod
    VCID: 392F249929D75CF3A0F-806C
    Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
    Part No SW: 5Q0 959 107 S HW: 5Q0 959 107 J
    Component: HDSG-Modul H13 0271
    Revision: -------- Serial number: A2-C737-6291-8
    Coding: 0D08
    ASAM Dataset: EV_DeckLidCONTIAU736 001017
    ROD: EV_DeckLidCONTIAU736_VW37.rod
    Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
    Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
    Component: OCULowMQBLGE H19 0825
    Revision: --------
    Coding: 03840201EA421A0D3F1C9E020045400382E608
    ASAM Dataset: EV_OCULowMQBLGE 004049
    ROD: EV_OCULowMQBLGE_004_VW25.rod
    1 Fault Found:
    9455892 - Mute switch radio
    B1049 14 [008] - Open or Short to Ground
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 18:39:49
    Voltage terminal 30: 11.9 V
    Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
    Part No SW: 3QD 980 654 A HW: 3Q0 980 654 A
    Component: MQB_B_MFK H10 1611
    Serial number: 02041941P23813
    Coding: 0204080200000401002623548150A90098000E10004000
    ASAM Dataset: EV_MFKBoschMQBB 002041
    ROD: EV_MFKBoschMQBB_002.rod
    VCID: 49CF54597937CC7330F-801C
    2 Faults Found:
    1122561 - Databus
    [TIMEOUT_ACC_10]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:13:54
    Control Module temperature: 42 °C
    Outside temperature: 17.5 °C
    Vehicle speed: 0.00 km/h
    System run time: 1493.0 s
    Voltage terminal 15: 11.8 V
    mid: 01 A3
    Status of camera: operational
    Engine_Running_Info: 0
    Software_Info_4: 1
    Software_Info_3: 1
    Software_Info_2: 6
    Software_Info_1: 1
    1122597 - Local Data Bus
    U1169 00 [009] - Missing Message
    [Timeout_RDR1_Header]
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 130
    Mileage: 129154 km
    Date: 2022.06.01
    Time: 20:13:54
    mid: 01 43
    Software_Info_4: 1
    Software_Info_3: 1
    Software_Info_2: 6
    Software_Info_1: 1
    Address BB: Door Rear Drv (J388) Labels:* None
    Part No SW: 5Q4 959 595 F HW: 8W0 959 595 F
    Component: TSG HFS 005 0246
    Serial number: 0000375331570
    Coding: 001C80208000020000001100
    ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
    ROD: EV_DCU2RearDriveMAXHCONT_SK37.rod
    VCID: 4ACD6B557C31C76B395-801E
    Address BC: Door Rear Pass (J389) Labels:* None
    Component: TSG HBFS 005 0246
    Serial number: 0000375559323
    ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
    ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
    End----(Elapsed Time: 02:11, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
    jak widać w module 4B mam 2 błędy, jeden już wiem co muszę zrobić czekam na części drugi to "C1082 F1 [137]" i tu jak podejrzewam jest kwestia parametryzacji. Jako, że nigdy tego nie robiłem muszę poprosić o radę, znalazłem odpowiednie auto w VCP ściągnąłem kontener zdc i mam do wyboru takie 4 elementy:
    co wybrać? Wymieniany był moduł 4H0941329 w lampie.
