Witam!
Mam SE t230 ktorego niedalo sie wlaczyc - pojawiala sie tylko ikona bateri. Pod ladowarka normalnie ladowal i wyswietlal napis "tylko ladowanie"
Wgralem mu przez tornado MCU i GDFS jednak po tej operacji calkowicie zamarl.
Niewiem co mam juz robic, moze flashowanie z zaznaczona jakas opcja? A moze to uszkodzenie hardware?
Ponizej kod z Toggle OS trace monitor:
WD SW Watchdog Initialized, sigId=0xc1c
WD SW Watchdog MMI Failure Delay = 0x3
RLink running in TAE
MPH NullState
RR: PID 43
RR: TIMER_PRIM 6298
RR: MPH_RR_PRIM 13760
RR: RR_MPH_PRIM 13810
RR: RR_RLC_PRIM 13940
RR: RLC_RR_PRIM 13950
RR: PH_MPH_PRIM 14040
RR: MPH_PH_PRIM 14110
RR: PH_RLC_PRIM 14260
RR: RLC_PH_PRIM 14280
RLC: RLC_LLC
RLC: RLC_IDLE_REQ = 14350
RLC: RLC_GMM_DATA_REQ = 14351
RLC: RLC_DATA_REQ = 14352
RLC: RLC_UNITDATA_REQ = 14353
RLC: RLC_RLC_DATA_REQ = 14354
RLC: RLC_RLC_UNITDATA_REQ = 14355
RLC: RLC_DATA_RSP = 14356
RLC: LLC_RLC
RLC: RLC_DATA_CNF = 14360
RLC: RLC_DATA_IND = 14361
RLC: RLC_STATUS_IND = 14362
RLC: RR_RLC
RLC: RR_TBF_ESTABLISH_REQ = 13940
RLC: RR_UPLINK_TBF_RELEASE_REQ = 13942
RLC: RR_DOWNLINK_TBF_RELEASE_REQ = 13943
RLC: RR_TBF_RELEASE_RSP = 13944
RLC: RR_DOWNLINK_ACK_NACK_REQ = 13945
RLC: RLC_RR
RLC: RR_TBF_ESTABLISH_CNF = 13950
RLC: RR_UPLINK_TBF_RELEASE_CNF = 13952
RLC: RR_DOWNLINK_TBF_RELEASE_CNF = 13953
RLC: RR_TBF_ESTABLISH_IND = 13951
RLC: RR_TBF_RELEASE_IND = 13954
RLC: RR_UPLINK_ACK_NACK_IND = 13955
RLC: PH_RLC
RLC: PH_RLC_DATA_REQ = 14260
RLC: PH_RLC_DATA_RELEASE_REQ = 14261
RLC: PH_RLC_CONTROL_REQ = 14262
RLC: PH_RLC_CONTROL_CONTROL_0_REQ = 14264
RLC: PH_RLC_CONTROL_CONTROL_1_REQ = 14265
RLC: PH_RLC_CONTROL_CONTROL_2_REQ = 14266
RLC: PH_RLC_CONTROL_CONTROL_3_REQ = 14267
RLC: PH_RLC_CONTROL_CONTROL_4_REQ = 14268
RLC: PH_RLC_CONTROL_CONTROL_5_REQ = 14269
RLC: PH_RLC_CONTROL_DATA_0_REQ = 14270
RLC: PH_RLC_CONTROL_DATA_1_REQ = 14271
RLC: PH_RLC_CONTROL_DATA_2_REQ = 14272
RLC: PH_RLC_CONTROL_DATA_3_REQ = 14273
RLC: PH_RLC_CONTROL_DATA_4_REQ = 14274
RLC: PH_RLC_CONTROL_DATA_5_REQ = 14275
RLC: PH_RLC_RELEASE_REQ = 14276
RLC: RLC_PH
RLC: PH_RLC_DATA_CNF = 14280
RLC: PH_RLC_DATA_IND = 14281
RLC: PH_RLC_DATA_RTS_IND = 14282
RLC: PH_RLC_DATA_RELEASE_CNF = 14283
RLC: PH_RLC_CONNECT_IND = 14284
RLC: PH_RLC_CONTROL_CNF = 14285
RLC: PH_RLC_CONTROL_IND = 14286
RLC: PH_RLC_RELEASE_CNF = 14287
RLC: RLC_TIMER
RLC: RLC_TIMER_T3164 = 14430
RLC: RLC_TIMER_T3166 = 14431
RLC: RLC_TIMER_T3180 = 14432
RLC: RLC_TIMER_T3182 = 14433
RLC: RLC_TIMER_T3190 = 14434
RLC: RLC_TIMER_T3192 = 14437
RLC_UL: S I
RLC_DL: S I
LLC: PID 53
LLC: <SMS 10867
LLC: >SMS 10863
LLC: <SNDCP 14330 14338
LLC 1: state 0
LLC 3: state 0
LLC 5: state 0
LLC 7: state 0
LLC 9: state 0
LLC 11: state 0
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 260 bytes requested in total ****RLP: process started
RLP: state changed to 'S0_ADMandDetached'
ConnHandler: process started
ConnHandler: state changed to 'NoNetwork'
L2RCOP: process started
L2RCOP: state changed to 'Initial'
MM reset TMSI
MM state 0
SIM state 0
GMM: ResetSIM_Data
* CC0 state 0
* CC1 state 0
* CC2 state 0
* CC3 state 0
* CC4 state 0
* CC5 state 0
* CC6 state 0
* CC7 state 0
QRY QRY
PrimVendorCmdCtrlID 0x3
PrimAlgQTBL 0x39
AltVendorCmdCtrlID 0x0
AltAlgQTBL 0x0
DeviceSize 8388608 bytes
DeviceInterfaceDescription 0x1
MaxBytesInMultiWrite 0
NumberOfEraseBlockRegions 2
0x800000-0xFEFFFF 127 blocks x 65536 bytes
0xFF0000-0xFFFFFF 8 blocks x 8192 bytes
SMC_MO_1 (99) state 0
SMC_MO_2 (100) state 0
SMC_MT (101) state 0
DC state 0
PCM_OTD: Entering state PCM_OTD_STATE_IDLE.
POP3 started process id: 119
FIRST_POP3_REQ_SIGNAL: 18500
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 279 bytes requested in total ****
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 327 bytes requested in total ****
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 467 bytes requested in total ****
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 647 bytes requested in total ****
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 797 bytes requested in total ****
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 966 bytes requested in total ****
MALL: **** NEW MAXIMUM XRAM HEAP USAGE: 1130 bytes requested in total ****
GDFS open failed
E2_Read error 5
Wrong generation of EEPROM. GD will not start.
