Firmware do Sharp 32FH8EA – gdzie znaleźć plik OTA lub zrzut, TV wisi w U-Boot, log błędów
dgnd3700v1 13 Lip 2025 19:44 534 0
  • #1 21605785
    dgnd3700v1
    Witam potrzebuje firmware ablo z OTA albo ze zrzutu jak ktoś ma bo mi wisi w U-boocie.
    << MT5867 >># reset
    [AT][MB][start do_reset]
    do_reset: Using RIU_MAP: 0x1F000000, at 55
    UART_115200
    AC_ON
    01-2L-SM-04-20211227
    1ST
    MIU0_DQS-OK
    BIST0-OK
    BAP=1
    BAP=1
    optee teeloader entry
    CusConfig
    eMMC_RPMB_Check_Program_Key
    BAP=1
    BAP=1
    ree_opt=0000007B
    BAP=1
    Auth reeloader...
    Decrypt reeloader...
    Check reeloader magic ID...
    Version check on reeloader...
    BAP=1
    BAP=1
    Auth CKB...
    Decrypt CKB...
    Check CKB magic ID...
    ns_uboot_boot
    NOTICE:  BL3-1: v1.1(debug):
    NOTICE:  BL3-1: Built : 09:54:47, Jun 17 2024
    INFO:    BL3-1: Initializing runtime services
    INFO:     [Booting] mstar_send_magic_ATF 508
    INFO:    BL3-1: Initializing BL3-2
    [Ramlog] ramlog_init init success
    INFO:    BL3-1: Preparing for EL3 exit to normal world
    INFO:    BIN1_32bit mode Jun 17 2024 09:54:46
    INFO:    R1 0
    INFO:    R2 0
    INFO:    R3 0
    ree_entry
    Start load avbab data.
    Try virtual ab bootloader_control...
    avb_ab_flow.c:426: ERROR: No bootable slots found.
    Select mboot Error.
    avb_ab_flow.c:476: ERROR: Not bootable slot, boot from default MBOOT
    Select mboot Error.
    avb_ab_flow.c:511: ERROR: Not bootable slot, boot from default MBOOT
    U[AT][MB][start ub][604]
    dalsza część, nie wiem po co chce ładować pliki
    U-Boot 2011.06-00000-gce556a18-dirty (Oct 19 2023 - 18:45:28)
    [Mboot] ===== sw IR Config Register =====
    [Mboot] ===== Attach IR Interrupt  ======
    Uboot Relocation:  152 MiB
    eMMC HS400 5.1 200MHz
    eMMC 7.28 GB
    eMMC used life: 0~10%
     CID
      0x008A4F93
      0x9DD50652
      0x34465447
      0x38000115
    DRAM : 1024MB
    Writing to MMC(0)... 128 blocks written: OK
    done
    SAR5=ON
    In:    serial
    Out:   serial
    Err:   serial
    Net:   No ethernet found.
    MAC:  0x5C: 0x85: 0x7E: 0xDA:0xAE: 0x65
    [AT][MBoot][Driver Init][672]
    mmc change mount : tvconfig
    ** File not found model.info
    [ERROR] vfs_getsize:412: ext4filesize mmc fail
    No enough buffer or path fail(model.info) :
    [src/MsUtility.c] [loadscript]
    model.info not find !! Clean model_info env
    done
    avb_ab_interface.c:91: There is no bootable slot.
    mmc change mount : project_id
    ** File not found config/project_id.ini
    Size of file "/project_id.ini" from mmc device 0 partition project_id: 296 bytes
    the abspath is /project_id.ini
    Loading file "/project_id.ini" at offset 0x0 from mmc device 0 partition project_id
    296 bytes read
    sizeof( project_id ini script ) --------> 296 bytes
    old projectID --> 851
    Get projectID from INI 851
    Get cusdata mountpoint on /vendor/cusdata/
    projectID --> 851
    set cusdata_projectid=851 to bootargs OK
    Expect dataIndex path=cusdata/config/dataIndex/dataIndex_851.ini
    Size of file "/config/sys.ini" from mmc device 0 partition tvconfig: 1763 bytes
    Loading file "/config/sys.ini" at offset 0x0 from mmc device 0 partition tvconfig
    1763 bytes read
    sizeof( sys ini script ) --------> 1763 bytes
    set platform=mi to bootargs OK
    Can't get audio_amp_config.ini from /config/sys.ini
    OsdConfig.ini path --> /vendor/tvconfig/config/OSD/OsdConfig.ini
    mmc change mount : cusdata
    Size of file "config/dataIndex/dataIndex_851.ini" from mmc device 0 partition cusdata: 9370 bytes
    Loading file "config/dataIndex/dataIndex_851.ini" at offset 0x0 from mmc device 0 partition cusdata
    9370 bytes read
    sizeof( config/dataIndex/dataIndex_851.ini dataindex_script ) --------> 9370 bytes
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini" from mmc device 0 partition cusdata: 24248 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini
    Full model.ini  path --> /bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini" at offset 0x0 from mmc device 0 partition cusdata
    24248 bytes read
    24248 bytes read
    sizeof( model ini script ) --------> 24248 bytes
    sizeof(dataindex_script ) --------> 9370 bytes
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/board_rt710.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/board_rt710.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/board_rt710.ini" from mmc device 0 partition cusdata: 74362 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/board_rt710.ini
    Can't get audio_amp_config.ini from /bsp/board/BD_MT5867-H1V1-B2-S_UK/model/Customer_1.ini
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/gamma_cfg.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/gamma_cfg.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/gamma_cfg.ini" from mmc device 0 partition cusdata: 153 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/gamma_cfg.ini
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/gamma_cfg.ini" at offset 0x0 from mmc device 0 partition cusdata
    153 bytes read
    sizeof( /bsp/board/BD_MT5867-H1V1-B2-S_UK/gamma_cfg.ini script ) --------> 153 bytes
    not found GAMMA_BIN path.
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini" from mmc device 0 partition cusdata: 691 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini" at offset 0x0 from mmc device 0 partition cusdata
    691 bytes read
    sizeof( /bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini script ) --------> 691 bytes
    ** File not found /vendor/cusdata/bsp/common/TCON_BIN/TCON20.bin
    ** File not found /cusdata/bsp/common/TCON_BIN/TCON20.bin
    ** File not found /bsp/common/TCON_BIN/TCON20.bin
    ** File not found /common/TCON_BIN/TCON20.bin
    TCON path --> /vendor/cusdata/bsp/common/TCON_BIN/TCON20.bin
    No enough buffer or path fail(/vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini) :
    No enough buffer or path fail(/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/tcon_cfg.ini) :
    691 bytes read
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini
    No enough buffer or path fail(/vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini) :
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini
    No enough buffer or path fail(/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini) :
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini" from mmc device 0 partition cusdata: 42 bytes
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini" at offset 0x0 from mmc device 0 partition cusdata
    42 bytes read
    sizeof( /bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini script ) --------> 42 bytes
    swing_level -> [250]
    9370 bytes read
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/panel_swing_cfg.ini
    42 bytes read
    SKEW_CONF_ENABLE -> [0]
    9370 bytes read
    42 bytes read
    MPLL_BW_BW -> [0]
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/mirror_cfg.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/mirror_cfg.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/mirror_cfg.ini" from mmc device 0 partition cusdata: 530 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/mirror_cfg.ini
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/mirror_cfg.ini" at offset 0x0 from mmc device 0 partition cusdata
    530 bytes read
    sizeof( /bsp/board/BD_MT5867-H1V1-B2-S_UK/mirror_cfg.ini script ) --------> 530 bytes
    MIRROR_OSD is  --> False
    MIRROR_VIDEO -> [False]
    InPath=config/dataIndex/dataIndex_851.ini
    ** File not found /vendor/cusdata/bsp/common/misc/boot_SHARP.ini
    ** File not found /cusdata/bsp/common/misc/boot_SHARP.ini
    Size of file "/bsp/common/misc/boot_SHARP.ini" from mmc device 0 partition cusdata: 241 bytes
    the abspath is /bsp/common/misc/boot_SHARP.ini
    Loading file "/bsp/common/misc/boot_SHARP.ini" at offset 0x0 from mmc device 0 partition cusdata
    241 bytes read
    sizeof( /bsp/common/misc/boot_SHARP.ini script ) --------> 241 bytes
    MUSIC_ON -> [0]
    m_u32MusicVol -> [0x14]
    ** File not found /vendor/cusdata/bsp/common/misc/bootlogo_SHARP.jpg
    ** File not found /cusdata/bsp/common/misc/bootlogo_SHARP.jpg
    Size of file "/bsp/common/misc/bootlogo_SHARP.jpg" from mmc device 0 partition cusdata: 74645 bytes
    the abspath is /bsp/common/misc/bootlogo_SHARP.jpg
    ** File not found /vendor/cusdata/bsp/common/misc/boot0.mp3
    ** File not found /cusdata/bsp/common/misc/boot0.mp3
    Size of file "/bsp/common/misc/boot0.mp3" from mmc device 0 partition cusdata: 59952 bytes
    the abspath is /bsp/common/misc/boot0.mp3
    gMusicPath --> /bsp/common/misc/boot0.mp3
    gLogoPath --> /bsp/common/misc/bootlogo_SHARP.jpg
    Half panelConf.ini path --> /vendor/cusdata/bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini
    Full panelConf.ini  path --> /vendor/cusdata/bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini
    Half keypadConf.ini path --> /vendor/cusdata/apollo/common/keypad/keypad.ini
    Full keypadConf.ini  path --> /vendor/cusdata/apollo/common/keypad/keypad.ini
    Full irConf.ini path --> /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini
    Half irConf.ini  path --> /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini
    530 bytes read
    Half Customer_Module.ini path --> /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini
    Full Customer_Module.ini  path --> /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini
    691 bytes read
    691 bytes read
    153 bytes read
    [ERROR] parse_data_ini_cusdata:1072: Can't get gCodecs_variant info from config/dataIndex/dataIndex_851.ini
    [ERROR] parse_data_ini_cusdata:1101: Can't get gAudiopolicy_variant info from config/dataIndex/dataIndex_851.ini
    ** File not found /vendor/cusdata/apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini
    ** File not found /cusdata/apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini
    Size of file "/apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini" from mmc device 0 partition cusdata: 200 bytes
    the abspath is /apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini
    [ERROR] __parse_bootcfg_path_from_dataindex:4109: not found DateIndex->m_pboot_mode_File.
    Loading file "/apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini" at offset 0x0 from mmc device 0 partition cusdata
    200 bytes read
    /apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini(200 byptes):boot_cfg:boot_ctrl -> 0
    /apollo/common/misc/ST4251B03-2_UK/boot_cfg.ini(200 byptes):boot_cfg:factory_poweron_mode -> 1
    set env boot_ctrl to [0x0]
    set env factory_poweron_mode to [secondary]
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini" from mmc device 0 partition cusdata: 2505 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/module/Customer_Module.ini" at offset 0x0 from mmc device 0 partition cusdata
    2505 bytes read
    sizeof( module ini script ) --------> 2505 bytes
    get tcon_size fail...>>>:0
    ** File not found 284DBCE4
    gRGBWPath=
    gstDbtable.dbdata[E_DB_RGBW].Size=0x0
    ** File not found config/3DLUT.bin
    g3DLUTBinPath=config/3DLUT.bin
    gstDbtable.dbdata[E_DB_3DLUT].Size=0x0
    MPOOL size : 0x300000
    Loading file "/bsp/common/misc/bootlogo_SHARP.jpg" at offset 0x0 from mmc device 0 partition cusdata
    74645 bytes read
    ** Bad Signature on 0:46: expected 0x5840, got 0x0000
    ** File not found /vendor/cusdata/bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini
    ** File not found /cusdata/bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini
    Size of file "/bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini" from mmc device 0 partition cusdata: 37808 bytes
    the abspath is /bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini
    Loading file "/bsp/common/panel/FullHD_32V_ST3151B07_2_JF.ini" at offset 0x0 from mmc device 0 partition cusdata
    37808 bytes read
    sizeof( panel ini script ) --------> 37808 bytes
    u32PeriodPWM = 479
    u32DutyPWM = 0x172
    m_32Shift = 0
    sizeof(dataindex_script ) --------> 0 bytes
    get sector MISC_MIRROR_CFG->m_pIniMirrorCfgFile fail.
    [ERROR] parse_panel:6937: parseMirro Mode fail !! parse_panel src/bootlogo/MsPoolDB.c 6937
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/board_rt710.ini" at offset 0x0 from mmc device 0 partition cusdata
    74362 bytes read
    sizeof( board ini script ) --------> 74362 bytes
    MODEL_ID =255
    done
    ProjectID.Model_ID=255
    ModelConfig=ModelConfig_255
    board ini MAP Path=
    [ERROR] parse_board_ini:7294: ModelConfig = ModelConfig_255
    Size of file "/config/dfbrc.ini" from mmc device 0 partition tvconfig: 1494 bytes
    Loading file "/config/dfbrc.ini" at offset 0x0 from mmc device 0 partition tvconfig
    1494 bytes read
    sizeof( dfb ini script ) --------> 1494 bytes
    logo -> [1]
    ** File not found /vendor/tvconfig/config/OSD/OsdConfig.ini
    ** File not found /tvconfig/config/OSD/OsdConfig.ini
    Size of file "/config/OSD/OsdConfig.ini" from mmc device 0 partition tvconfig: 1083 bytes
    the abspath is /config/OSD/OsdConfig.ini
    Loading file "/config/OSD/OsdConfig.ini" at offset 0x0 from mmc device 0 partition tvconfig
    1083 bytes read
    sizeof( OsdConfig ini script ) --------> 1083 bytes
    ** File not found /vendor/cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini
    ** File not found /cusdata/bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini
    Size of file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini" from mmc device 0 partition cusdata: 10247 bytes
    the abspath is /bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini
    Loading file "/bsp/board/BD_MT5867-H1V1-B2-S_UK/ir_config_sharp.ini" at offset 0x0 from mmc device 0 partition cusdata
    10247 bytes read
    sizeof( ir_config ini script ) --------> 10247 bytes
    section = MIR_IRCX611
    section = MIR_IRFAC
    10247 bytes read
    ** File not found 284DC504
    Loading file "0" at offset 0x0 from mmc device 0 partition cusdata
    ** File not found 0 **
    [ERROR] vfs_read:464: ext4load mmc fail, try again!
    [ERROR] vfs_read:468: ext4load mmc fail
    74362 bytes read
    sizeof( /bsp/board/BD_MT5867-H1V1-B2-S_UK/board_rt710.ini script ) --------> 74362 bytes
    [ERROR] Load_3DLUTBinToFlash:8824: vfs_getsize error: config/3DLUT.bin !
    74362 bytes read
    150 blocks written: OK
    [ERROR] write_dbtable:5545: There is no bootable slot
    ** File not found 284DBF44
    No enough buffer or path fail() :
    Size of file "/bsp/common/MMAP_MI.h" from mmc device 0 partition cusdata: 35166 bytes
    Loading file "/bsp/common/MMAP_MI.h" at offset 0x0 from mmc device 0 partition cusdata
    35166 bytes read
    no miu_setting information in mmap.ini
    No E_LX_MEM3_ADR information
    No E_LX_MEM4_ADR information
    [ERROR] _get_new_map_format_from_env:529: get GMAC_MEM_ADR fail
    [ERROR] get_map_ID:490: Map ID maping to [40] a null pointer !!
    [ERROR] _get_new_map_format_from_env:523: One of the parameters is a null pointer
    [ERROR] do_sync_mmap_to_env:2284: There is no bootable slot
    0:MCP_N_D3_2133_8G_4x
    1:MCP_N_D3_2133_0G_4x
    DRAM Channel 0 Size = [2048MB]
    Changelist:     24543697
    do not first setup(first_setup=1), skip self adaption.
    ============= set bootargs ===============
    Hit any key to stop autoboot:  0
    << MT5867 >>#
    Próbowałem zrootować Magiskiem i tak to się skończyło
