Witam mam płytę główną J-7XAN i nie mogę zdobyć informacji na temat proesora, jaki maksymalnie tam mogę włożyć i jakie ona ma parametry.
Szukałem już w internecie i nic.
Proszę o pomoc.
Uzupełniłem tytuł /post był raportowany/. [h]
Processor
Support 66.6 , 68.5 , 75 , 83 MHZ CPU CLOCK
Support CPU Ratio : 3 , 3.5 , 4 , 4.5 , 5
Support Intel PentiumÒII Processor CPU (233MHz ~ 333MHz)
Support Intel CELERON Slot 1 Processor CPU (233MHz ~ 333MHz)
Expansion Slot
One AGP Slot
Two 16-bit ISA Bus Slots
Three 32-bit PCI Bus Slots
Slot 1 for Pentium II CPU & CELERON CPU
System Memory
Support 3 Banks of DRAM 16MBytes up to 384MBytes Main Memory
Support 3 X 168-pin DIMM Socket (3.3V)
Support EDO & SDRAM
Support ECC or parity check
On Board IDE
Support 2 X IDE Connectors for up to 4 IDE Drives
Support PIO and Bus Master IDE Uup to Mode 4 Timing
Support Ultra DMA33 Synchronous DMA mode for to 33 Mbytes/s
Bundle with "TRIONES" Ultra DMA33 Driver to improve IDE transfer rate for up to 33Mbyte/sec
On Board Ultra I/O
2 X Serial Ports (16550 Fast UART Compatible)
1 X Parallel Port (EPP and ECP capabilities)
1 X Floppy Disk Connector (Supports 2 Floppy Drives)
1 X PS2 Mouse Connector
1 X Keybord Cnnector
3 X Three-Wire CPU FAN Connectors
1 X Standard IR Connector (Infrared)
AGP SLOT
Support AGP VGA Card for 533Mbytes/sec data transfer rate and 66MHz Bus clock improve graphic function
On Board USB
2 X USB Connectors
Support USB Mouse (Win98)
Support USB Keyboard Function
Power Saving
ACPI/APM power management
Modem Ring remote wake up
RTC alarm wake up
CPU fan auto-stopping in suspend mode
Support software power off
Wake on LAN For OS
Power Support
Efficient PWM switching power instead of traditional Linear Voltage Regulator to prevent power component from being burned-out
Support 20-pin ATX power supply (ATX-PW)
BIOS
Support DMI function, Green function, Plug and Play Function
1Mbyte BIOS Flash ROM support
CPU Ratio Selector U19
RATIO #1 #2 #3 #4
3.0X ON ON ON OFF
3.5X ON ON OFF OFF
4.0X ON OFF ON ON
4.5X ON OFF OFF ON
5.0X ON OFF ON OFF
5.5X ON OFF OFF OFF
6.0X OFF ON ON ON
6.5X OFF ON OFF ON
7.0X OFF ON ON OFF
