Sanyo PLC-SU50S - Lampa nie włącza się, dioda miga na czerwono po uruchomieniu
sawwa7 06 Kwi 2006 17:42 2935 4
  • #1 2500011
    sawwa7
    hi all colleagues
    i have this sanyo LCD projector with the following fault ...
    when u press the power button the power led lights green and the cooling fans start to work but the main projector lamp didn't light on , after a few seconds ( 5-10) the green led lights red but flashing ( on-off) for about one min , during this one min the cooling fans work properly and can hear them before the unit go into stand by with a steady red led power indicator .
    if u turned the projector on again it do the same trip but never have the main lamp work.
    i have both 15.5V and 6V outputs from power supply , so i assume that the main switching power supply based on Ic631 = STR-Z2156A is working properly and the problem may be in one of the following :
    defect Lamp
    defect lamp ballast circuit wich include the inverter
    defect power fail control circuit based on IC621=FA5502M
    this is the first time i work with such a multimedia projector and just need any help or tips if any one has work with that before .
    wanna know how to isolate the faulty stage here and if there any tips that may help in that .
    i do appreciate any help or response and i do have the service manual for this unit
    thanks in advance
    Kind Regards
  • #2 2505042
    sawwa7
    hi
    come on guys , i need ur help please
    Regards
  • #4 2509684
    sawwa7
    satgal napisał:
    First of all check lamp (vacuum or heater) how long time you using this projector because is short limit of life lamp.
    hi satgal
    first of all i'd like to thank u much for response and trying to help me .
    i do already suspect the lamp or inverter circuit , but don't have any high voltage prob to test the ballaster circuit output and also don't know how to test the lamp itself .
    using multimeter on ohms range didn't give any reading and i'm not sure about this kind of lamps .
    also , i don't know the time this projector work for , i have got it for repair from a company who also got from a medicine colleage for repair , also this is the first time i work with that kind of equipments .
    i do monitor and tv repairs but never come across things like that projector before , also still didn't work on the new LCD and tft or plasma things .
    we still have tubes for at least the next 30 years :lol:
    if u or any one else know how to test this lamp or inverter circuit with a simple multimeter or using a general purpose 20Mhz scope , please tell or if u do have any documents related to that uplod please
    thanks to any help
    Regards
  • #5 2516383
    sawwa7
    hi all colleagues
    well , does any one know where can i got a lamp for this unit?
    and how much does it cost ? please
    the lamp i have here in this model is made by OSRAM , germany and has the following info
    p-vip 200/1.0 p215
    1AV 4T 30B08100
    any help would be highly appreciated
    Kind Regards
    hi all
    it's ok for the price of this lamp assembly u can check here :
    http://www.audiogeneral.com/Sanyo/Accessories.html
    http://www.beamershop.com/bs_neu/main/suche_lampen.php?&hersteller=sanyo
    and i think this unit will not be repaired :lol:
    thanks all
    Regards
