Jak wgrać patch miniGPS i ExtraInfo na Siemens C65 przerobiony na SL65?
emilio86 07 Kwi 2006 13:57 1296 4
  • #1 2502774
    emilio86
    Ocena: 7
    Witam!
    mam przerobionego siemens c65 na sl65 i najpierw wgralem patch:
    ;* Extra info on the main screen v3 *
    ; © avkiev, § AsteriX
    16EA952: 051C0020 26F055FB
    #pragma enable old_equal_ff
    1711000: 01B53D4E04273F020737FA2412253949
    1711010: 0A889120FF2A00D39220B047897900F0
    1711020: 4FF89320B0479420B0470A20B0471C24
    1711030: 1225012003212D4A90470A210902AA31
    1711040: 401A0F210A061116091802D59120B047
    1711050: 49420A20A1F7EEEB00F02FF89520B047
    1711060: 081CB0479620B0479720B0470A20B047
    1711070: 44241225002009211C4A9047011C0320
    1711080: 0002E830A1F7D6EBB0479520B0476420
    1711090: A1F7D0EBB04700F013F89820B0470A20
    17110A0: B0476E2412251248018800F009F89920
    17110B0: B0470A20B047002020BD02B5011C00E0
    17110C0: 02B50A20A1F7B6EB0A2802D3FFF7F5FF
    17110D0: 00E0B047081CB04702BD02B53A182106
    17110E0: 0816291CF5F7E4EF063402BDD0EF13A1
    17110F0: 648766A8084D67A8DB1071A1
    #pragma disable old_equal_ff
    ;To hide any element you have to define its y-coordinate to more than 176 (for example C0)
    ;171100A: FA,24,12 xx,24,yy ;Net (FA=-6)
    ;171102E: 1C,24,12 xx,24,yy ;Temperature
    ;1711070: 44,24,12 xx,24,yy ;Voltage
    ;17110A2: 6E,24,12 xx,24,yy ;Capacity
    ;1711042: 0F 0i030 ;Adjust temperature in function B by 0.1°C: 000 - TBA, 030 - TEN, 015 - (TBA+TEN)/2, -010 - TBA-1
    0DA24E4: 3214 0609
    0DA24EC: 3113 0609
    0DA24F4: 3113 0609
    0DA24FC: 3214 0609
    0DA2504: 3113 0609
    0DA250C: 3113 0609
    0DA2514: 3113 0609
    0DA251C: 3113 0609
    0DA2524: 3113 0609
    0E72744: 7FFFE403FFF7FF6EBF 0303037F7F03030303 ;4DD - "-"
    0E727D0: 00000E3800007F0000 037F7F03037F7F0303 ;4DE - "="
    0E72858: C701C300E0007F5FC7 0F0F0F0F3F6F6F3F03 ;4DF - "d"
    0E728E0: 00008002403D3F3C01 7B6F6F7B7B6F6F7B03 ;4E0 - "B"
    0E7296C: FFFFFFFFFFFFFF8FFF 0303030303031B1B33 ;4E1 - ","
    0E729F4: 0000000000007F07FF 1B27271B0303030303 ;4E2 - "'"
    0E72A7C: 0100102000007F01C0 3B6F676363676F3B03 ;4E3 - "C"
    0E72B04: 0001F0F0C8107F0001 6F6F6F6F6F7F3B1303 ;4E4 - "V"
    0E72B8C: 0000400080007F0007 676F0F1B33236F4F03 ;4E5 - "%"
    ;01 - black
    ;02 - red (base)
    ;03 - navy (base)
    ;04 - green (base)
    ;05 - magenta (base)
    ;06 - aqua (base)
    ;07 - yellow (base)
    ;08 - red (light)
    ;09 - navy (light)
    ;0A - green (light)
    ;0B - magenta (light)
    ;0C - aqua (light)
    ;0D - yellow (light)
    ;0E - red (dark)
    ;0F - navy (dark)
    ;10 - green (dark)
    ;11 - magenta (dark)
    ;12 - aqua (dark)
    ;13 - yellow (dark)
    ;14-17 - clean
    i pozniej:
    ;*** Mini GPS with GSM Data Logger ***
    ;v0.8
    ;(c)ACiD[mrp], arsh0r
    ;thx to: bennie, SiNgle
    ;SL65v50 (p)(i)KiRiK
    >Not fully compatible with *Dynamic Provider v5* and patches that replace provider name
    with some functions. You may use simultaneously screensaver in one patch and mainscreen
    in the other, or viceversa
    >Remove your operator logo first
    >Create a folder 0:\Misc\gps
    >Network change and new networks will be logged in \Misc\gps\_logfile.txt
    Network files can be directly edited on phone.
    You can change the default name of an network by editing the network file stored in \Misc\gps\*
    >Use this String:
    [action][space][text to be displayed]
    action:
    0 - do nothing
    1-8 - switch to profile 1-8
    a - Alarm
    q - shutdown phone
    v - vibrate two times
    >Example:
    "0 home" will display "home" on screen and not change the profile
    "1 work" will display "work" on screen and change profile to normal environment
    16464F4: F7B52E4E0C1CB079 004B9F46F71480A0 ;screensaver
    165F9C4: 6FB9B4A0 071580A0 ;mainscreen
    00800F00: 10B5C0460378002B07D0037801300B80
    00800F10: 0231137801331370F4E710BDF1B58CB0
    00800F20: 2020E74909688847061C4020E4490968
    00800F30: 8847051C1020E2490968884707901020
    00800F40: DF4909688847069008A90AA8DD4A1268
    00800F50: 9047DDA1301CE34A1268904705ABFF22
    00800F60: 0132FF210A31301CDF4F3F68B847041C
    00800F70: 631C35D008AB9A785978187801900291
    00800F80: 03920A9A0092187B04905A7B031CD7A1
    00800F90: 281CD44F3F68B847281CDA4909688847
    00800FA0: 049005AB021C291C201CD74F3F68B847
    00800FB0: D4490C9809688847049005AB021C201C
    00800FC0: D14F0C993F68B84705AB0222CFA1201C
    00800FD0: CD4F3F68B84705A9201CCD4A12689047
    00800FE0: 301CCC4909688847281CCA4909688847
    00800FF0: C849079809688847C649069809688847
    00801000: 0DB0F0BDF1B584B02020AD4909688847
    00801010: 051CC1A1281CB34A1268904703A9281C
    00801020: C44A12689047029000260298431C0FD0
    00801030: 03984078000203990978411801910498
    00801040: 0199884200D00126BB49039809688847
    00801050: 002E02D10298431C27D16B46FF220132
    00801060: 511C281CA04F3F68B847041C631C1CD0
    00801070: 02209349096888470390049803990870
    00801080: 04980004000E039948706B460222201C
    00801090: 9D4F03993F68B8476946201C9C4A1268
    008010A0: 90479C49039809688847281C99490968
    008010B0: 8847301C05B0F0BD10B5037800229A42
    008010C0: 07D201E00132FAE754002418A4788C54
    008010D0: F8E70024CC5410BD30B500230022C046
    008010E0: C45C002C08D01C1C0133045D8C540024
    008010F0: 8D186C700232F3E730BD10B5021C0020
    00801100: 0021C046535C002B04D00B1C0131D35C
    00801110: 5840F7E710BDF3B583B0FF2001306849
    00801120: 09688847061C0220654909688847041C
    00801130: 0020607073490498096888470006000E
    00801140: 02900498FFF7D9FF029948400190311C
    00801150: 0498FFF7C1FF6B46FF220132511C624F
    00801160: 03983F68B847051C6B4600220021281C
    00801170: 724F3F68B847029921706B460222211C
    00801180: 281C614F3F68B84702994A006B46311C
    00801190: 281C5D4F3F68B847019820706B460222
    008011A0: 211C281C584F3F68B8476946281C584A
    008011B0: 12689047301C574909688847201C5549
    008011C0: 0968884705B0F0BDF1B58CB0012008AB
    008011D0: 18700C99086807905948069006988688
    008011E0: 06984588202036490968884709904020
    008011F0: 3349096888470A904020314909688847
    00801200: 0B9040202E4909688847041C4DA1354A
    00801210: 099812689047331C4EA1324F0A98099A
    00801220: 3F68B84700962B1C4CA12E4F0B980A9A
    00801230: 3F68B84703A93F4A0B98126890470290
    00801240: 0298431C3BD1002D22D0331C2A1C47A1
    00801250: 201C244F3F68B84704AA0120474B0A99
    00801260: 1B689847211C0B98FFF755FF331C2A1C
    00801270: 43A1201C1B4F3F68B847201CFFF74EFE
    00801280: 331C2A1C48A1201C164F3F68B8470CE0
    00801290: 281CFFF7B7FE002807D047A1201C114A
    008012A0: 12689047201CFFF739FE08AB18784000
    008012B0: 079A811808AA201CFFF722FE04E181E0
    008012C0: B81580A0C41580A0303A5C4D6973635C
    008012D0: 6770735C5F6C6F6766696C652E747874
    008012E0: 00000000DC1580A0A01580A05B25692E
    008012F0: 25692E2569202D2025693A25693A2569
    00801300: 5D200000C81580A0A41580A00D0A0000
    00801310: AC1580A0BC1580A0303A5C4D6973635C
    00801320: 6770735C6C6173746E65742E746D7000
    00801330: 00000000B01580A0C01580A0A81580A0
    00801340: 4C4C67A8303A5C4D6973635C67707300
    00801350: 0000000025735C256900000025735C25
    00801360: 692D25692E746D6F0000000030206365
    00801370: 6C6C3A25692D256900000000B41580A0
    00801380: 6E6577206E6574776F726B20666F756E
    00801390: 64205B43656C6C2049443A25692C204C
    008013A0: 41433A25695D0000736176696E672025
    008013B0: 692D2569000000006E6F206E6574776F
    008013C0: 726B00000399081CFFF776FE281CFFF7
    008013D0: 19FE002840D0039A02320092331C2A1C
    008013E0: 4CA1201C564F3F68B847201CFFF796FD
    008013F0: 039800783138082811D2039800783138
    00801400: 059050490598096888474FA1201C4C4B
    00801410: 059A1B689847201CFFF780FD1CE00398
    00801420: 0078612803D003980078412806D14BA0
    00801430: FFF774FD4D48006880470DE003980078
    00801440: 712803D003980078512806D148A0FFF7
    00801450: 65FD4E480068804728E0039800787628
    00801460: 03D003980078562806D1022201212F20
    00801470: 474B1B68984719E003980078652803D0
    00801480: 03980078452811D108AB18784000079A
    00801490: 811808AA0B98FFF733FD08AB18780138
    008014A0: 0C9948603B490C980968884708AB1878
    008014B0: 4000079A811808AA03980230FFF720FD
    008014C0: 354903980968884708AB18780138079A
    008014D0: 1080324909980968884730490A980968
    008014E0: 88472E490B9809688847201C2B490968
    008014F0: 88470DB0F0BD70B5051C0C1C161C201C
    00801500: FFF762FE70BD10B5041C201CFFF75CFE
    00801510: 10BD00004E6574776F726B206368616E
    00801520: 67653A205B43656C6C2049443A25692C
    00801530: 204C41433A25695D2028257329000000
    00801540: DC1580A0E81580A050726F66696C6520
    00801550: 6368616E67653A2025690000416C6172
    00801560: 6D20436C6F636B0000000000E01580A0
    00801570: 537769746368696E6720746865207068
    00801580: 6F6E65206F66660000000000E41580A0
    00801590: F01580A0EC1580A0C01580A0BC1580A0
    008015A0: 40C021A168C121A1F4BF21A194BF21A1
    008015B0: 4FD0BBA0B0BF26A1980F82A0001082A0
    008015C0: 2D06BCA09365B2A0D5A154A175A054A1
    008015D0: 95A054A1B8A054A155A154A1F19F54A1
    008015E0: FF51B7A0789924A11BBA8CA0DDC4A2A0
    008015F0: 707393A0
    080136C: 30 76 ;default vibra on network change
    ;08012C8: 30 00 ;disable logfile
    i teraz nie wiem jak zmienic pozycje wyswietlanych informacji... :/ a chciałbym kozystac z obu patchy... bo na info GPS naklada sie patch ExtraInfo:/
    moze ktos wie jak zrobic aby na miniGPS byl wyswietlany kilka pixeli nizej???
  • #2 2505273
    emilio86
    Ocena: 7
    Juz załapałem :D
    Trzeba było zmienic wartosci tych danych:
  • #3 2506773
    epol
    Ocena: 13
    hmm. Mozesz mi wyjasnić na jakiej niby zasadzie działa ten twoj "miniGPS" i co on potrafi, i co masz na mysli przerobiony C65 na SL65? Ssuwak zamontowałes??:|
  • #4 2507217
    ZAHYR
    Poziom 33  
    Ocena: 179
    Ten miniGPS spelnia chyba taka sama funkcje jak kod 050 na kanalach informacyjnych (pokazuje w jakiej mijscowosci / na jakim osiedlu jestes). C65 da się przerobić na SL65 po sofcie (odpowiedni patch i swup SL65), ale oczywiście nie bedzie miał wszystkich funkcji które ma sl65 (ograniczenia HW).
  • #5 2528241
    emilio86
    Ocena: 7
    ten miniGps dziala na takiej zasadzie ze wyswietlany jest numer stacji BTS czyli tej do ktorej aktualnie zalogowany jest telefon. ten ze kod mozna pozniej zamienic na dowolna nazwe ktora bedzie wyswietlana na glownym ekranie. mozna wpisac np. Dom gdy bedziesz w domu lub Szkola w szkole... tylko jest problem bo przewaznie w jednym miejscu loguje do kilku BTS'ow i wybiera najsilniejszy sygnal... ja np. wpisalem nazwy miejsc w ktorych sa nadajniki :) i do kazdej nazwy mozna ustawic automatyczna zmiane profilu. np. gdy jestem na uczelni to loguje mi do 3 stacji i wtedy automatycznie np. wycisza mi telefon ;)
    www.btsearch.org na tej stronie sa informacje o poszczegolnych nadajnikach
