Hmm. W opisie USBSmarta można przeczytac między innymi: "Funkcje oprogramowania Cyclone: naprawa 'phone freeze' (takze na serii Sysol)". Ale tak jak piszesz, USBSmartem nie daje się tego zrobic...
Sprawdziłem solucję z GSM Forum i... udało się. Tutaj jest opis, sprawa jest dośc prosta:
The explanation for how to do is already on this forum but to make it easier for everyone to find it, I'm making my 1 for all (Z series phones) post.
The supported phones for this process are (the Z series phones):
(as listed in the program)
SGH-Z140
SGH-Z140V
SGH-Z300
SGH-Z300M
SGH-Z500
SGH-Z500V
SGH-ZM60
SGH-ZV30
SGH-ZX10
To unlock and/or unfreeze these phones you must follow the next steps:
- Download and install QUALCOMM UNLOCKER (http://www.megaupload.com/?d=39RITNDZ)
- Install the propper USB drivers for your mobile (if it comes with CD, if that CD has the USB drivers, it's those ones that you should use, otherwise, download:
http://org.downloadcenter.samsung.co...USBDriver.exe).
- Have the proper USB cable for your mobile (if it comes with one, it's that one that you should use).
- After having your phone correctly connected to your computer (using the USB cable) and turned ON (with or without the SIM inserted), set the mobile modem COM port as one between port 2 to port 9 (ports 2 and 9 included). [Note]
- Connect (with something like a metallic wire for example) the 2nd and 3rd pins of the COM1 port (behind your computer), like the example below (imagine it like a COM - 9 pinned - port):
…………………………………………... ______
- Before attempting to unlock your mobile (though everything looks OK), click on the "Read Settings" to be completely sure that the program is completely detecting your mobilephone and to make it able to unlock it (by reading the phone's internal codes).
- After all the previous steps... Press UNLOCK. It will remove all the phone locks and the phone freeze (if needed).
Dołączam program, gdyby link nie działał. Sterowniki do Samsunga radzę poszukac gdzie indziej, w linku wyświetlają się jakieś krzaki, ja miałem je po prostu w zestawie do USBSmarta.
