zamieszczam listing ktory przeklepalem zgazety Nowy elektronik:
$regfile = "m8def.dat"
$crystal = 800000
Config Lcdpin = Pin , Db4 = Portd.4 , Db5 = Portd.3 , Db6 = Portd.2 , Db7 = Portd.1 , E = Portd.5 , Rs = Portd.7
Config Lcd = 16 * 2
Config Adc = Single , Prescaler = Auto , Reference = Off
Ddrb = &B00000000
Ddrc = &B00000000
Ddrd = &B10111110
Portc.0 = 1
Config Pinb.0 = Input
Config Pinb.1 = Input
Config Pinb.2 = Input
Config Pinb.3 = Input
Config Pinb.4 = Input
Config Pinb.5 = Input
Config Pinb.6 = Input
Config Pinb.7 = Input
Config Pinc.0 = Input
Config Pinc.1 = Input
Config Pinc.2 = Input
Config Pinc.3 = Input
Config Pinc.4 = Input
Config Pinc.5 = Input
Config Pinc.6 = Input
Config Pind.0 = Input
Config Pind.1 = Output
Config Pind.2 = Output
Config Pind.3 = Output
Config Pind.4 = Output
Config Pind.5 = Output
Config Pind.6 = Input
Config Pind.7 = Output
S1 Alias Pinc.0
Dim Adc1 As Word
Dim Adc2 As Word
Dim Adc3 As Word
Dim Xadc1 As Byte
Dim Xadc3 As Byte
Dim Temp As Single
Dim Rx As Single
Dim Volt As String * 8
Dim Amper As String * 8
Dim Rx_mem As Byte
Dim Xword As Word
Dim Adj As Byte
Start Adc
Cursor Off
Cls
Lcd "Nowy ele"
Locate 2 , 1
Lcd "ktronik"
Wait 1
Cls
Lcd " V & A "
Locate 2 , 1
Lcd " Meter"
Wait 1
Adj = 0
Readeeprom Bajt , 3
If Bajt = 128 Then
Readeeprom Rx_mem , 1
Readeeprom Bajt , 4
Xadc1 = Bajt
If Rx_mem < 70 Or Rx_mem > 130 Then
Rx_mem = 100
Writeeeprom Rx_mem , 1
End If
If Xadc1 > 10 Or Xadc3 > 10 Then
Xadc1 = 0
Xadc3 = 0
Bajt = Xadc1
Writeeeprom Bajt , 4
Bajt = Xadc3
Writeeeprom Bajt , 5
End If
Else
Rx_mem = 100
Xadc1 = 0
Xadc3 = 0
Bajt = Xadc1
Bajt = Xadc3
End If
Rx_mem = Rx_mem / 1000
If S1 = 0 Then
Waitms 40
Cls
Lcd " Relase"
Locate 2 , 1
Lcd " Button"
Do
Loop Until S1 = 1
Waitms 40
Cls
Lcd "Set Rx"
Volt = Fusing(rx , "#.###")
Locate 2 , 1
Lcd Volt
Do
If S1 = 0 Then
Readeeprom Bajt , 3
If Bajt <> 128 Then
Bajt = 128
Writeeeprom Bajt , 3
End If
Waitms 40
Rx = Rx + 0.001
If Rx > 0.130 Then Rx = 0.070
Temp = Rx * 1000
Rx_mem = Round(temp)
Rx = Rx_mem / 1000
Locate 2 , 1
Lcd Volt
Do
Loop Until S1 = 1
Waitms 40
End If
Loop
End If
Cls
Do
If S1 = 0 Then
Waitms 40
Cls
Lcd " Relase"
Locate 2 , 1
Lcd " Button"
Do
Loop Until S1 = 1
Waitms 40
Cls
Lcd " Adj"
Locate 2 , 1
Lcd "ust"
Adj = 1
Xadc1 = 0
Xadc3 = 0
Wait 1
End If
Xword = 0
For Bajt = 0 To 49
Adc1 = Getadc(2)
Xword = Xword + Adc1
Next Bajt
Adc1 = Xword / Bajt
If Adc1 >= Xadc1 Then Adc1 = Adc1 - Xadc1
Xword = 0
For Bajt = 0 To 49
Adc2 = Getadc(1)
Xword = Xword + Adc2
Next Bajt
Adc2 = Xword / Bajt
Xword = 0
For Bajt = 0 To 49
Adc3 = Getadc(3)
Xword = Xword + Adc3
Next Bajt
Adc3 = Xword / Bajt
If Adc3 >= Xadc3 Then Adc3 = Adc3 - Xadc3
If Adj = 1 Then
Adj = 0
Xadc1 = Adc1
If Adc1 > 10 Then
Cls
Lcd " Adj E"
Locate 2 , 1
Lcd "rror 3"
Wait 2
Cls
Else
Bajt = Xadc3
End If
Bajt = 128
End If
If Adc1 < 1001 Then
Temp = Adc1 / 100
Volt = Fusing(temp , "#.##")
Else
Temp = Adc2 / 10
Volt = Fusing(temp , "#.#")
End If
Temp = Adc3
Temp = Temp / Rx
Temp = Temp / 1000
Amper = Fusing(temp , "#.##")
Locate 1 , 1
Lcd Volt ; "V "
Locate 2 , 1
Lcd Amper ; "A "
Loop
End
co w nim jest nietak mam cala liste bledow :
Error : 93 Line : 59 Variable not dimensioned [ 0-> 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 31 Line : 59 Invalid datatype [ 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 31 Line : 60 Invalid datatype , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 93 Line : 62 Variable not dimensioned [ 0-> 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 31 Line : 62 Invalid datatype [ 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 242 Line : 63 Source variable does not match the target variable [ 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 46 Line : 71 Assignment error [BAJT: 0 XADC1: 2] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 93 Line : 72 Variable not dimensioned [ 0-> 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 31 Line : 72 Invalid datatype [ 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 46 Line : 73 Assignment error [BAJT: 0 XADC3: 2] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 93 Line : 74 Variable not dimensioned [ 0-> 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 31 Line : 74 Invalid datatype [ 0] , in File : C:\DOCUMENTS AND SETTINGS\DAMIAN.XXX-A8F59D44F93\PULPIT\VA\VA.BAS
Error : 7 Line : 0 IF THEN expected [ 74] , in File :
Error : 123 Line : 0 END IF expected , in File :
czy moglby mi ktos pomoc ? poprawic te bledy?
$crystal = 800000
Config Lcd = 16 * 2
Ddrb = &B00000000
Ddrc = &B00000000
Ddrd = &B10111110
Portc.0 = 1
S1 Alias Pinc.0
Dim Adc1 As Word
Dim Adc2 As Word
Dim Adc3 As Word
Dim Xadc1 As Byte
Dim Xadc3 As Byte
Dim Temp As Single
Dim Rx As Single
Dim Rx_mem As Byte
Dim Xword As Word
Dim Adj As Byte
Start Adc
Cursor Off
Cls
Lcd "Nowy ele"
Locate 2 , 1
Lcd "ktronik"
Wait 1
Cls
Lcd " V & A "
Locate 2 , 1
Lcd " Meter"
Wait 1
Adj = 0
Readeeprom Bajt , 3
If Bajt = 128 Then
Readeeprom Bajt , 4
Xadc1 = Bajt
Rx_mem = 100
End If
Xadc1 = 0
Xadc3 = 0
Bajt = Xadc1
Bajt = Xadc3
End If
Else
Rx_mem = 100
Xadc1 = 0
Xadc3 = 0
Bajt = Xadc1
Bajt = Xadc3
End If
If S1 = 0 Then
Waitms 40
Cls
Lcd " Relase"
Locate 2 , 1
Lcd " Button"
Do
Loop Until S1 = 1
Waitms 40
Cls
Lcd "Set Rx"
Locate 2 , 1
Lcd Volt
Do
If S1 = 0 Then
Readeeprom Bajt , 3
If Bajt <> 128 Then
Bajt = 128
End If
Waitms 40
Rx = Rx + 0.001
Temp = Rx * 1000
Rx = Rx_mem / 1000
Locate 2 , 1
Lcd Volt
Do
Loop Until S1 = 1
Waitms 40
End If
Loop
End If
Cls
Do
If S1 = 0 Then
Waitms 40
Cls
Lcd " Relase"
Locate 2 , 1
Lcd " Button"
Do
Loop Until S1 = 1
Waitms 40
Cls
Lcd " Adj"
Locate 2 , 1
Lcd "ust"
Adj = 1
Xadc1 = 0
Xadc3 = 0
Wait 1
End If
Xword = 0
For Bajt = 0 To 49
Adc1 = Getadc(2)
Next Bajt
Adc1 = Xword / Bajt
Xword = 0
For Bajt = 0 To 49
Adc2 = Getadc(1)
Next Bajt
Adc2 = Xword / Bajt
Xword = 0
For Bajt = 0 To 49
Adc3 = Getadc(3)
Next Bajt
Adc3 = Xword / Bajt
If Adj = 1 Then
Adj = 0
Xadc1 = Adc1
If Adc1 > 10 Then
Cls
Lcd " Adj E"
Locate 2 , 1
Lcd "rror 3"
Wait 2
Cls
Else
Bajt = Xadc3
End If
Bajt = 128
End If
If Adc1 < 1001 Then
Temp = Adc1 / 100
Else
Temp = Adc2 / 10
End If
Temp = Adc3
Temp = Temp / Rx
Temp = Temp / 1000
Locate 1 , 1
Lcd Volt ; "V "
Locate 2 , 1
Lcd Amper ; "A "
Loop
End
